Samsung B with no sound on .mts files
baldas
Post Mon Jan 06, 2014 10:03 am
Hi all
Can you help me on this?
What can I do to have sound when I want to see .mts files with sound?
I already try several config but nothing, What option can I use or what command can i use in the profile.xml file to solve the problem?
Thanks in advance.
Post Mon Jan 06, 2014 10:46 am
Re: Samsung B with no sound on .mts files
Could you provide more information about your file ? (see signature links)
baldas
Post Mon Jan 06, 2014 11:43 am
Hi Illico,
here the information that you ask.
C:\Program Files\Serviio\lib>ffmpeg.exe -i D:\Noite.mts
[mpegts @ 01CAE2E0] max_analyze_duration 5000000 reached at 5000000 microseconds
Input #0, mpegts, from 'D:\Noite.mts':
Duration: 00:13:48.45, start: 1.000000, bitrate: 6970 kb/s
Program 1
Stream #0:0[0x1011]: Video: h264 (High) (HDMV / 0x564D4448), yuv420p, 1440x1
080 [SAR 4:3 DAR 16:9], 25 fps, 25 tbr, 90k tbn, 50 tbc
Stream #0:1[0x1100]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp,
256 kb/s
Post Mon Jan 06, 2014 12:36 pm
This file seems good. It should be delivered in native format. Could you confirm this ? (enable detailed logging and check the serviio.log file)
baldas
Post Mon Jan 06, 2014 2:30 pm
The info that I have on the log is this:
2014-01-06 14:23:01,822 INFO [WebServer] WebServer starting on port 8895
2014-01-06 14:23:02,068 INFO [Device] Updated bound IP address of Device with UUID: bbc6a524-57f0-35ff-81b1-3e1398669727, bound address: 192.168.1.66
2014-01-06 14:23:02,069 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2014-01-06 14:23:02,069 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2014-01-06 14:23:02,069 INFO [EventDispatcher] Starting EventDispatcher
2014-01-06 14:23:02,117 INFO [RendererSearchSender] Searching for Renderer devices
2014-01-06 14:23:02,121 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface eth3 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.1.66, timeout = 0
I made the change in the log config to DEBUG but i only get this info.
To restart the serviio service I only need to stop/Start it on the console or I need to restart the CPU on Windows?
baldas
Post Tue Jan 07, 2014 3:10 pm
Any help on this please?
Post Tue Jan 07, 2014 11:30 pm
To enable debugging mode you need to either restart your PC, or restart the Windows service (in Windows, start services.msc and the stop and start the Serviio Service). Stop/Starting it on the console won't do it.
....or you can use my Winhelper tool (viewtopic.php?f=17&t=12136) which includes some quick access tools to set debug mode, stop and start the service, and other niceties..... :)
baldas
Post Wed Jan 08, 2014 2:24 pm
In attach is the DEBUG log File.
Can you take a look and help me put the .mts files running on my Samsung B with sound?
serviio.log.txt
(172.08 KiB) Downloaded 714 times
Post Wed Jan 08, 2014 10:56 pm
I'll leave it with Illico, but I think he needs a log file showing you playing the file Noite.mts :)
baldas
Post Wed Jan 08, 2014 11:56 pm
But i put all info that it is on the log after playing the file.
Post Thu Jan 09, 2014 2:43 am
I see that you used a different file this time 'Natal de 2013.mts' (I searched the log for 'Noite.mts'). This is delivered in native format (ie. no transcoding).
2014-01-08 13:20:09,374 DEBUG [VideoDeliveryEngine] Delivering file 'Natal de 2013.mts' in native format
It suggests that your TV doesn't like something in the AC3 stream within the file. You may need to transcode it (change your profile to transcode AC3 audio), or you could see if remuxing the file helps. Illico has much more knowledge on Sony systems than I, so he may come up with other ideas.
baldas
Post Thu Jan 09, 2014 7:31 pm
Thanks for the tips, but is a Samsung B and not a Sony. But i agree with you.
how can i Transcode the audio to other format?
can you help me???
Post Thu Jan 09, 2014 11:02 pm
doh.... I am doing too many at once :oops:
How many files are we talking about?
Firstly try remuxing the file, either using my WinHelper tool mentioned previously or by running the command (from a command line -you will also need to reference your ffmpeg location, usually "C:\Program Files\Serviio\lib\ffmpeg.exe"):
    ffmpeg -i "file name.mts" -map 0 - c copy "file name remux.mts"
This will simply copy the existing audio and video into a new package - will test if the container was corrupt.
If that doesn't work re-transcode the audio (to AC3):
    ffmpeg -i "original file name.mts" -map 0 - vcodec copy -acodec ac3 -ab 192k "file name ac3.mts"
and if that doesn't work try transcoding audio to another format (and in this case, to stereo):
    ffmpeg -i "original file name.mts" -map 0 - vcodec copy -acodec mp2 -ac 2 -ab 192k "file name mp2.mts"
Take note of any errors or warnings.
baldas
Post Thu Jan 09, 2014 11:14 pm
If i understand i need to make that command to all .mts files that i want to play? :?
Can i do or put any command on the serviio so the program do that automatic during the stream?
Because i have many files in .mts from my video camera ;) .
Post Thu Jan 09, 2014 11:21 pm
Hopefully, just one for now - once we work out which one fixes the issue we'll try and get Serviio to do it automajically.
baldas
Post Fri Jan 10, 2014 9:31 am
OK
I will try and then I give a feedback
thanks
baldas
Post Tue Jan 14, 2014 12:58 pm
dont work i have this error that is attach in the image file
What is wrong on the command??
baldas
Post Thu Jan 16, 2014 3:24 pm
Any Help??
Post Fri Jan 17, 2014 12:44 am
Can you please PM me a small video sample.
