Xbox360 Transcoding issues?
Doward
Post Thu Sep 11, 2014 1:09 am
Hey all, Serviio 1.4.1.2 running on Fedora 20, Core i5-3470K / 8GB ram / 6TB Raid 5 array.
Archer C7, Xbox 360S, wirelessly connected.
Ran the ffmpeg command, and getting ~146fps.
Now, when I stream to the Xbox 360, runs smooth for ~1 minute, then stutters. Play smooth for a bit, then stutters again. I checked, and Serviio is only sending ~700KB/second while streaming (720p MKV) - my server has no issue sending 15-18MB/s, so I can't figure that the issue is bandwidth....
Any ideas?
keaza
Post Thu Sep 11, 2014 11:56 am
Re: Xbox360 Transcoding issues?
it may be the audio causing it lagg behind, if you are having to re-encode audio as well as video it can cause issues.
Doward
Post Thu Sep 11, 2014 10:02 pm
ffmpeg can't handle audio and video transcoding?
