profiles.xml editing issue
lockdown
Post Tue Jan 06, 2015 4:11 pm
Everytime I try to edit the xml profile and then restart I always get the 'Cannot start' until I install the serviio program all over again.
Whats going on here?
thanks
:cry:
Post Tue Jan 06, 2015 4:28 pm
Re: profiles.xml editing issue
What changes have you made in the profiles.xml file?
lockdown
Post Tue Jan 06, 2015 4:33 pm
removed a line that a remark said was OK to remove.
Post Tue Jan 06, 2015 6:12 pm
Could you be more explicit ?
lockdown
Post Wed Jan 07, 2015 1:08 am
sure..
I removed the line in the panasonic 2013 profile that said 'if your tv supports xvid delete this'
also is there anyway to make these changes permanent instead of changing them after every install?
what about having seperate profiles for each device?
thanks
Post Wed Jan 07, 2015 7:51 am
I suppose you talk about this
            <!-- AVI files will be transcoded into mpeg-ts, mpeg2 video and ac3 audio.
         This section is NOT inherited by other Panasonic profiles  -->
                <Matches container="avi" />
                <!-- Remove this line for models that natively support AVI's with Xvid video (some ST60's) -->
                <Matches container="avi" vCodec="mpeg4" vFourCC="div3,div4,div5,divx,dm4v,dx50" />
                <Matches container="avi" vCodec="msmpeg4" vFourCC="div3,div4,div5,divx,dm4v,dx50" />
If your device supports avi/xvid video, change by this :
I suggest to use Notepad++ text editor (file should be UTF8 encoded)
Save file, then restart serviio service or reboot pc to reload profiles.
After a serviio update, a profiles.xml backup is done, then you can merge your previous profile modification with latest profiles.xml release.
Seperate profiles for each device was already requested https://bitbucket.org/xnejp03/serviio/i ... r-profiles
lockdown
Post Wed Jan 07, 2015 9:51 am
where is the backup saved to?
Post Wed Jan 07, 2015 10:49 am
In same place after the serviio update.
For windows:
C:\Program Files\Serviio\config\profiles.xml.bak
lockdown
Post Thu Jan 08, 2015 5:06 am
OK. That worked.
How do I merge the profiles together when upgrading?
Post Thu Jan 08, 2015 9:49 am
profiles.xml is an XML text file.
Then you can use, compare text tool to compare both "profiles.xml" and "profile.xml.bak" files, then merge modifications.
Look at:
- WinMerge (OpenSource) : http://winmerge.org/
- ExamDiff (freeware) : http://www.prestosoft.com/edp_examdiff.asp
- KDiff3 (windows/linux) : http://kdiff3.sourceforge.net
- Beyond compare (pay) but very complete : http://www.scootersoftware.com/features.php
lockdown
Post Thu Jan 08, 2015 10:39 am
thanks..
I for one, will be counting down the days till when the profiles are separated into their own 'cannot be over-ridden' directory.
