Low Voices and Loud Music?
gosku
Post Thu Feb 21, 2013 7:22 pm
I'm running serviio server to play movies from a Samsung Smart TV ES7500. Everything works very well except one aspect: When I play some movies, I often get the track sound with a lot of volume for the fx effects and music, but very low volume for the voices.
I know the problem comes from trying to play 6 channels sound tracks in a stereo TV (I suffered before playing ACC tracks in a computer).
I was wondering if it is possible to fix this annoying thing. Right now I have the transcoding disabled in the server configuration, so I guess the DTS sound is sent directly to the TV...
Any advice? Will the sound improve if I enable the transcoding? "Keep original" or "Downmix to stereo" option?
Thank you on advance :)
Post Fri Feb 22, 2013 1:57 pm
Re: Low Voices and Loud Music?
try Downmix to stereo - but it'll only work for files that have to be transcoded. For those that the device plays natively you won't see any difference.
jlwasmer
Post Mon Mar 02, 2015 9:53 pm
Is it possible to always transcode the file and only change the audio track (downmix to stereo) but leave the video as-is?
