What is the difference between these 2 files?
hemlock
Post Sun Apr 03, 2016 3:56 pm
I' streaming to a Samsung BluRay player with the Samsung C/D Profile. I having some issues with some 1080p rips. They are getting transcoded and I can't figure out why. Here is a comparison of one that works and one that doesn't:
Works:
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'C:\file1.mp4':
    major_brand     : mp42
    minor_version   : 512
    compatible_brands: isomiso2avc1mp41
    creation_time   : 2016-04-01 07:19:05
    encoder         : HandBrake 0.10.5 2016021100
  Duration: 01:46:43.52, start: 0.000000, bitrate: 2209 kb/s
    Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709
, 1920x1072 [SAR 1:1 DAR 120:67], 2107 kb/s, 23.97 fps, 23.98 tbr, 90k tbn, 180
 tbc (default)
      handler_name    : VideoHandler
    Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fl
p, 95 kb/s (default)
      handler_name    : Stereo
Doesn't work:
[mov,mp4,m4a,3gp,3g2,mj2 @ 0000000002be5fc0] overread end of atom 'colr' by 1 by
tes
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'C:\file2.mp4':
    major_brand     : mp42
    minor_version   : 0
    creation_time   : 2013-07-14 03:24:16
    title           :
    artist          :
    composer        :
    genre           :
    date            :
    synopsis        :
    encoder         : HandBrake 0.9.9 2013051800
  Duration: 01:25:00.09, start: 0.000000, bitrate: 2413 kb/s
  Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709)
, 1920x1080 [SAR 1:1 DAR 16:9], 2248 kb/s, 23.98 fps, 23.98 tbr, 90k tbn, 180k t
bc (default)
      encoder         : JVT/AVC Coding
    Stream #0:1(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, flt
p, 159 kb/s (default)
    Stream #0:2(und): Subtitle: mov_text (text / 0x74786574), 0 kb/s
I see the one that doesn't work has that atom error and the "compatible brands portion is different. Anybody have any idea what the issue is.
Post Sun Apr 03, 2016 5:11 pm
Re: What is the difference between these 2 files?
One major difference is the one that doesn't work has a captions track. There's some minor differences in the video and audio codecs, but nothing that I think would cause an issue. Try enabling the debug log and see if it identifies the error in more detail.
hemlock
Post Sun Apr 03, 2016 7:38 pm
Ok I removed the captions and it's still getting transcoded. Logs don't provide any details.
Does the compatible_brands line have anything to do with it?
hemlock
Post Sun Apr 03, 2016 7:56 pm
Ok I figured it out, the video has an h264 level of 5.0 and the profile is set to transcode anything greater than 4.2.
Post Sun Apr 03, 2016 9:37 pm
I didn't see that in what you posted, only showing High. Yep, if they're 5.0 that profile will transcode. in fact, most profiles will, as there aren't a lot of devices that support levels above 4.1. Those are most likely 4K capable devices.
