Best profile for performance
bagualas
Post Wed May 24, 2017 11:26 pm
Hello!!
I would like to know what is the best performance transconding profile I can find.
I have a slow PC, i3...so it kinda freeezes the stremming during transcoding, and I need subtitles, so I expect to need the transcoding right? Also a profile set? Am i correct?
Im transcoding to a DLNA receptor that its kind of old one too.
Thanks!!
Post Thu May 25, 2017 1:00 am
Re: Best profile for performance
What would most likely work best for you would be to convert your video into a format that your player can handle without transcoding. For most players that would likely be MP4. Then your computer won't have to transcode. Adding captions can be done via transmuxing, which requires very little computer power. So it really depends on what sort of player you are trying to use.
