Synology DS214play transcoding
Uran255
Post Thu Dec 26, 2019 6:49 pm
I just discovered Serviio, and everything works good with one exception.
When i stream video with DTS by DLNA to my Samsung TV, i receive the audio as DTS even when i'm have activated "Downmix to stereo"
Is the transcoding supposed to work with DLNA or only when using the build in "media-browser" from a browser?
Uran255
Post Thu Dec 26, 2019 6:52 pm
Re: Synology DS214play transcoding
I just saw this text in the transcoding tab "When enabled, transcoding enables you to play media files that would not normally be playable by your device. Transcoding only works with a specific Renderer Profile (not the Generic DLNA profile)."
So does it mean i need a special DLNA profile with transcoding? how do i load such a profile?
Uran255
Post Thu Dec 26, 2019 10:37 pm
I found the profiles in the device list. so far so good.
But how do i add new profiles?
Post Fri Dec 27, 2019 3:06 am
Transcoding requirements are based on the player, not what Serviio is running on. So depending on your player, they may already be a profile that works well for your device. You can try any profile, not specifically one named for your player. If you find you can't play something, try a different profile. We can help you with profile selection if you let us know what player(s) you are trying to use.
As to adding new profiles, you can certainly make changes to the existing profiles file. However, it's recommended that any user created profile be stored in a different file, so that any update you apply to Serviio doesn't wipe out your changes. Each update always replaces the profiles file with a new version, which often contains updates or new profiles.
Uran255
Post Fri Dec 27, 2019 10:56 am
Thank you for the reply. I have tried different profiles, for my players which is all samsung TV's, but none are transconding the DTS audio, so i only have sound on the one TV i have which is supporting DTS.
I like to have a profile transcoding DTS and transcoding the new video codec to something older devices understand, any of the existing profiles able to do that?
Uran255
Post Fri Dec 27, 2019 1:59 pm
another problem i have ran into,
after i have tried transcoding with a couple of different profiles for the same device, the NAS is non responsive, and i need power off and on again.
Anyone have the Serviio working properly on Synology DS214Play?
Post Sat Dec 28, 2019 3:03 am
Uran255 wrote:Thank you for the reply. I have tried different profiles, for my players which is all Samsung TV's, but none are transcoding the DTS audio, so i only have sound on the one TV I have which is supporting DTS.
The Roku TV profile (not the 4K version) decodes DTS with both H.264 and MPEG2 video. For the Roku 4K TV profile, it only captures DTS if the video is H.264/265. I overlooked MPEG2 in that profile, so I'll have to update it. Both profiles are transcoding using AppleHTTP, which the TV should see as MOV, and should be supported. But if you try the Roku TV profile and the videos don't appear, then we'll have to tweak the profile to use MPEGTS instead, which I know for a fact that Samsung supports.
Uran255
Post Sat Dec 28, 2019 2:54 pm
I have tested so far:
Roku Media Player:
- h264 with DTS fails
- hecv with DTS XLL play as apple format after a couple of tries, but it will only play for less than 1 min, and then it will buffer for more than 1 min.
Roku TV (non 4K):
- h264 with DTS works with sound
- HEVC with DTS XLL can not load the tv reports an error
Roku 4K Media Player w/MPEG2
- h264 with DTS no sound
Roku 4K Media Player (2016+)
Roku 1080 Media Player (2016+)
Yamaha BD-A1020/BD-A1010
- HEVC with DTS XLL can no sound
Chaneru
- h264 with DTS works with sound (apple format)
Samsung TV / player (M-series)
Samsung TV / player (J-series)
Samsung TV / player (H-series)
- hecv with DTS XLL play as mpeg/DD format, but it will only play for less than 1 min, and then it will buffer for more than 1 min.
for some profiles as soon as i have tried to play a HEVC file, the CPU load will remain 98% mostly on ffmpg until i stop the server and start it again.
I can test more if you need, but to me it looks like i just need a profile, where no video is touched but all DTS are converted to the apple format?
could such a NO-DTS profile be included in the next release?
Post Sun Dec 29, 2019 3:59 am
OK, since I'm the author of the Roku profiles, I can explain some of those issues. With the "Roku Media Player" profile, it transcodes almost everything with a bitrate limit, as the early Roku players had a bitrate limit of around 16 Mbps. That's a bad profile to try for your use, and it really requires a strong CPU. I'm not knowledgeable enough about Synology products to say how much power it has, but I would guess that this profile works the box too hard.
"Roku TV (non4K)", like all the other Roku profiles, uses the HLS/AppleHTTP protocol for transcoding. My guess is that the HLS protocol isn't working well with the Samsung TV, based on your earlier comment. But I am surprised that the H.265 video wouldn't load, while H.264 would. My guess is your NAS isn't powerful enough to transcode H.265.
The other Roku profiles are giving you no sound because I wrote those profiles with the assumption that the Roku player would be connected to an AVR or soundbar with DTS support. Roku players will bitstream standard DTS over HDMI, so those profiles don't capture that audio codec. That's why I suggested the TV profiles, as they are designed to capture all versions of DTS.
The one Roku profile you didn't list here was the "Roku 4K TV" profile. That one passes H.264 and H.265 video without transcoding, but does capture all audio except standard Dolby Digital. Although as I mentioned I overlooked MPEG2 video, so any of yours with that and DTS will still not give audio. Otherwise, as long as your TV will work with the HLS protocol, that one should work with both. If HLS is causing problems, I can alter the Roku 4K TV profile to use MPEGTS instead, which I know the TV supports.
I'm trying to remember what TV you have. It is a Samsung 4K set, right? Did you try the user-profiles.xml file I posted in the other thread you posted on? Or are you still trying to figure out how to put that file on your NAS? I'll address that in your other post.
Uran255
Post Sun Dec 29, 2019 9:25 am
Thank you for the answer.
I have a samsung NU8005. (no DTS support)
I gotten a little further this night. I got a Samsung NU profile from a guy which has been using it for a year.
problems:
1) after playing several files with different format ffmpeg will keep having a high cpu load after i ended the movies. a reboot of the Synology box is required to reset the cpu load completely. even after i stop the serviio service the ffmpeg will still use above 80%. (or maybe it only happens when i have tried a video which failed like the one below)
2) HEVC plus DTS XXL does not work, the tv sees them as mkv but it can not load the video it fails with "unexpected error". (this works from my windows10 serviio test server with same tv and profile)
file1
Unique ID : 207882168810303808543094491795812222663 (0x9C64A63DDF3F023B8A076975F8AF86C7)
Complete name : \\192.168.1.200\video\Movies\Harry Potter\Harry Potter And The Deathly Hallows Part 1 (2010 tt1571403).mkv
Format : Matroska
Format version : Version 4
File size : 22.5 GiB
Duration : 2 h 26 min
Overall bit rate : 22.0 Mb/s
Encoded date : UTC 2016-09-15 18:51:11 / UTC 2016-09-14T23:44:22Z
Writing application : mkvmerge v9.4.0 ('Knurl') 64bit
Writing library : libebml v1.3.4 + libmatroska v1.4.5 / Lavf55.12.0
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main@L4.1@Main
Codec ID : V_MPEGH/ISO/HEVC
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Writing library : x265 1.9:[Windows][GCC 4.9.0][64 bit] 8bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / no-fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=240 / min-keyint=24 / scenecut=40 / rc-lookahead=20 / lookahead-slices=5 / bframes=4 / bframe-bias=0 / b-adapt=2 / ref=3 / limit-refs=3 / no-limit-modes / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=3 / psy-rd=2.00 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=2 / pass / bitrate=18432 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Matrix coefficients : BT.709
Statistics Tags Issue : mkvmerge v9.4.0 ('Knurl') 64bit 2016-09-15 18:51:11 / mkvmerge v9.4.0 ('Knurl') 64bit 2016-09-15 18:51:11 / UTC 2016-09-14T23:44:22Z
FromStats_BitRate : 18428867
FromStats_Duration : 02:26:05.257000000
FromStats_FrameCount : 210156
FromStats_StreamSize : 20191720122
Format : DTS XLL
Commercial name : DTS-HD Master Audio
Codec ID : A_DTS
Bit rate mode : Variable
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 93.750 FPS (512 SPF)
Bit depth : 24 bits
Compression mode : Lossless
Delay relative to video : 83 ms
Language : English
Default : Yes
Forced : No
FromStats_BitRate : 3586668
FromStats_Duration : 02:26:05.547000000
FromStats_FrameCount : 821770
FromStats_StreamSize : 3929888792
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Language : Danish
Default : Yes
Forced : No
FromStats_BitRate : 39
FromStats_Duration : 02:11:27.554000000
FromStats_FrameCount : 1006
FromStats_StreamSize : 39192
Menu
00:00:00.000 : :Chapter 1
00:04:26.140 : :Chapter 2
00:09:46.711 : :Chapter 3
00:15:19.168 : :Chapter 4
00:19:19.450 : :Chapter 5
00:26:11.862 : :Chapter 6
00:31:42.025 : :Chapter 7
00:35:45.518 : :Chapter 8
00:41:37.620 : :Chapter 9
00:45:54.418 : :Chapter 10
00:50:22.311 : :Chapter 11
00:55:12.392 : :Chapter 12
00:58:36.179 : :Chapter 13
01:03:51.411 : :Chapter 14
01:10:09.288 : :Chapter 15
01:14:38.432 : :Chapter 16
01:18:56.606 : :Chapter 17
01:22:22.270 : :Chapter 18
01:25:05.141 : :Chapter 19
01:28:11.536 : :Chapter 20
01:32:41.722 : :Chapter 21
01:37:40.312 : :Chapter 22
01:42:46.160 : :Chapter 23
01:48:00.223 : :Chapter 24
01:53:53.910 : :Chapter 25
01:57:41.012 : :Chapter 26
02:01:38.040 : :Chapter 27
02:05:50.209 : :Chapter 28
02:09:52.785 : :Chapter 29
02:13:16.113 : :Chapter 30
02:14:47.204 : :Chapter 31
file 2
Unique ID : 225645424605129185493483639321026935495 (0xA9C1BA5E9B92C852987434480F6CBAC7)
Complete name : \\192.168.1.200\video\Movies\Harry Potter\Harry Potter And The Deathly Hallows Part 2 (2011 tt1680310).mkv
Format : Matroska
File size : 20.3 GiB
Duration : 2 h 10 min
Overall bit rate : 22.3 Mb/s
Encoded date : UTC 2016-09-10 13:50:34
Format : HEVC
Bit rate : 18.4 Mb/s
Height : 800 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.500
Stream size : 16.8 GiB (83%)
Default : Yes
Forced : No
Format : DTS XLL
Codec ID : A_DTS
Bit rate : 3 841 kb/s
Bit depth : 24 bits
Stream size : 3.50 GiB (17%)
Language : English
Default : Yes
Forced : No
Text
Format : UTF-8
Duration : 1 h 55 min
Bit rate : 31 b/s
Count of elements : 735
Stream size : 27.0 KiB (0%)
Language : Danish
Default : Yes
Forced : No
Menu
00:03:08.271 : :Chapter 2
00:06:23.424 : :Chapter 3
00:10:31.214 : :Chapter 4
00:14:32.955 : :Chapter 5
00:20:05.788 : :Chapter 6
00:22:49.952 : :Chapter 7
00:25:42.749 : :Chapter 8
00:30:56.855 : :Chapter 9
00:34:43.706 : :Chapter 10
00:40:42.314 : :Chapter 11
00:46:02.301 : :Chapter 12
00:50:25.522 : :Chapter 13
00:54:51.079 : :Chapter 14
00:59:03.748 : :Chapter 15
01:03:48.783 : :Chapter 16
01:07:16.115 : :Chapter 17
01:11:28.492 : :Chapter 18
01:14:46.648 : :Chapter 19
01:23:50.900 : :Chapter 20
01:29:22.565 : :Chapter 21
01:31:25.104 : :Chapter 22
01:36:41.170 : :Chapter 23
01:41:14.568 : :Chapter 24
01:46:44.231 : :Chapter 25
01:50:28.413 : :Chapter 26
01:54:16.766 : :Chapter 27
01:58:12.960 : :Chapter 28
I have also tried the "Roku 4K TV" profile with the same two files which are also failing with unexpected error.
forum-user- 1year-profiles.xml
(4.26 KiB) Downloaded 1016 times
Post Mon Dec 30, 2019 12:13 am
Well, based on that profile you loaded it should be working. I just tried the NU profile I created on my NU7100, and played Star Wars. This is H.264 with DTS Master Audio, and no problem encountered. This profile uses AppleHTTP as the protocol. I then tried an H.265 video, again with DTS XXL, and it too plays on my set.
I can't say what's going on with your set, but the same sort of media is playing fine on my Samsung NU7100. Perhaps a detailed Serviio log would provide some answers.
Uran255
Post Mon Dec 30, 2019 11:26 am
The most strange part is that the profile works with the TV when using a windows 10 serviio server, but when i use the Synology serviio server it fails, so something most be different between the 2 serviio serverapplications.
On Synology I have selected ffmpg 2.7.1 with Intel SMD stuff during installation, will it be better to select ffmpg 3?
where do i find the logs?
Uran255
Post Mon Dec 30, 2019 11:42 am
logfile from an attempt with attached user-profile ( i think it is your user-profile from another forumpost)
h264 no sound
hevc fails
dlna-master-user-profiles.xml
(2.24 KiB) Downloaded 1009 times
serviio log from 30-12.txt
(70.5 KiB) Downloaded 1014 times
Uran255
Post Thu Jan 23, 2020 4:21 pm
looking forward to a reply from a DLNAMaster ;)
freaknik
Post Sat Jan 25, 2020 6:53 pm
Master just means you post a lot.
Is the nas doing other stuff that is resource heavy at the same time?
I have never used one but used to have a router that had a usb drive connect and would serve dlna and file shares.
There was so little ram on the router it couldn't handle it and corrupted the files (good times keep backups).
What does ram use look like? Do nas OS' have a pagefile?
freaknik
Post Sat Jan 25, 2020 7:00 pm
atc98092 wrote:... works the box too hard.
No such thing imo :mrgreen:
