Samsung Q can't see some videos
yksvatla
Post Sun Feb 06, 2022 7:16 pm
Hi.
I have a strange behavior with my Samsung QE43Q60. TV just does not see some videos when I'm connecting to Serviio. Video format is supported by TV and can be played from flash card or hard drive or through Windows default DLNA server, but it simply not displayed in Serviio. And this is not a single problem - I have a lot of such videos from different sources.
In serviio I just took Samsung TV (NU) profile and in transcoding just for test leave only next rows(as I understand now it must transcode any video file):
         <Video targetContainer="mpegts" targetACodec="ac3" aBitrate="512">
            <Matches container="*"/>
Here is file info:
Unique ID                   : 215677653089158757674845025800569820546 (0xA242014A6E01BE24BFF447D457691582)
Complete name               : E:\Video\xdvvv.mkv
Format                      : Matroska
Format version              : Version 4
File size                   : 1.99 GiB
Duration                    : 1 h 0 min
Overall bit rate            : 4 743 kb/s
Movie name                  : Dope.WEB-DL(1080p).[MVO] / Dope - S0- Hammer
Encoded date                : UTC 2021-11-04 12:22:37
Writing application         : mkvmerge v6.1.0 ('Old Devil') built on Mar  2 2013 14:32:37
Writing library             : libebml v1.3.0 + libmatroska v1.4.0
IMDB                        : tt9174558
TMDB                        : tv/110695
Format                      : AVC
Format/Info                 : Advanced Video Codec
Format profile              : High@L4
Format settings             : CABAC / 4 Ref Frames
Format settings, CABAC      : Yes
Format settings, Reference  : 4 frames
Codec ID                    : V_MPEG4/ISO/AVC
Bit rate                    : 3 945 kb/s
Width                       : 1 920 pixels
Height                      : 1 080 pixels
Display aspect ratio        : 16:9
Frame rate mode             : Constant
Frame rate                  : 24.000 FPS
Color space                 : YUV
Chroma subsampling          : 4:2:0
Bit depth                   : 8 bits
Scan type                   : Progressive
Bits/(Pixel*Frame)          : 0.079
Stream size                 : 1.65 GiB (83%)
Title                       : Dope.S0.WEB-DL(1080p).[MVO].xz
Default                     : Yes
Forced                      : No
Statistics Tags Issue       : mkvmerge v62.0.0 ('Apollo') 64-bit 2021-11-03 04:00:24 / mkvmerge v6.1.0 ('Old Devil') built on Mar  2 2013 14:32:37 2021-11-04 12:22:37
FromStats_BitRate           : 4037153
FromStats_Duration          : 01:00:02.875000000
FromStats_FrameCount        : 86469
FromStats_StreamSize        : 1818169840
Audio #1
Format                      : AC-3
Format/Info                 : Audio Coding 3
Commercial name             : Dolby Digital
Codec ID                    : A_AC3
Bit rate mode               : Constant
Bit rate                    : 448 kb/s
Channel(s)                  : 6 channels
Channel layout              : L R C LFE Ls Rs
Sampling rate               : 48.0 kHz
Frame rate                  : 31.250 FPS (1536 SPF)
Bit depth                   : 16 bits
Compression mode            : Lossy
Stream size                 : 192 MiB (9%)
Title                       : HDRezka Studio
Language                    : Russian
Service kind                : Complete Main
Default                     : Yes
Forced                      : No
Audio #2
Format                      : E-AC-3
Format/Info                 : Enhanced AC-3
Commercial name             : Dolby Digital Plus
Codec ID                    : A_EAC3
Bit rate                    : 256 kb/s
Stream size                 : 110 MiB (5%)
Title                       : Eng
Language                    : English
Default                     : No
Forced                      : No
FromStats_BitRate           : 256000
FromStats_Duration          : 01:00:02.976000000
FromStats_FrameCount        : 112593
FromStats_StreamSize        : 115295232
Text #1
Format                      : UTF-8
Codec ID                    : S_TEXT/UTF8
Codec ID/Info               : UTF-8 Plain Text
Title                       : rus (forced)
Language                    : Russian
Default                     : Yes
Forced                      : No
Text #2
Format                      : UTF-8
Language                    : English
Default                     : No
Forced                      : No
FromStats_BitRate           : 72
FromStats_Duration          : 00:57:55.125000000
FromStats_FrameCount        : 962
FromStats_StreamSize        : 31621
Text #3
Format                      : UTF-8
Title                       : SDH
Language                    : English
Default                     : No
Forced                      : No
FromStats_BitRate           : 76
FromStats_Duration          : 00:59:54.125000000
FromStats_FrameCount        : 1052
FromStats_StreamSize        : 34510
Menu
00:11:11.000                : en:Chapter 1
00:22:25.000                : en:Chapter 2
00:35:51.000                : en:Chapter 3
00:49:09.000                : en:Chapter 4
00:57:58.000                : en:Chapter 5 - Credits
And here is full Profile code:
<Profile id="Samsung_NUnn" name="Samsung TV (NU-111)" extendsProfileId="1">
      <ContentDirectoryMessageBuilder>org.serviio.upnp.service.contentdirectory.SamsungTizenDLNAMessageBuilder</ContentDirectoryMessageBuilder>
      <ResourceTransportProtocolHandler>org.serviio.upnp.protocol.http.transport.SamsungWiseLinkProtocolHandler</ResourceTransportProtocolHandler>
      <Detection>
         <UPnPSearch>
            <ModelName>(^[A-Z]{2}\d{2}N[A-Z]?\d{3,4}.*)</ModelName>
            <ModelNumber>(1\.0)|(AllShare1\.0)</ModelNumber>
         </UPnPSearch>
         <HttpHeaders>
            <!-- some models only support headers -->
            <User-Agent>(.*SEC_HHP_\[TV\] [A-Z]{2}\d{2}N[A-Z]?\d{3,4}.*)</User-Agent>
         </HttpHeaders>
      </Detection>
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/x-matroska">MATROSKA</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-flac">FLAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-wav">WAV</MediaFormatProfile>
      </MediaFormatProfiles>
      <ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.SamsungContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
      <H264LevelCheck>FILE_ATTRIBUTES</H264LevelCheck>
      <OnlineTranscoding>
         <Video targetContainer="applehttp"> <!-- dont transcode to ac3 -->
            <Matches container="mp4" />
      </OnlineTranscoding>
      <GenericTranscoding>
         <Video targetContainer="mpegts" targetVCodec="h264" targetACodec="aac" />
      </GenericTranscoding>
      <ThumbnailsResolution>HD</ThumbnailsResolution>
      <AllowChunkedTransfer>true</AllowChunkedTransfer>
      <MultipleAudioTrackAware>true</MultipleAudioTrackAware>
      <Subtitles>
         <SoftSubs mime-type="smi/caption" type="srt" />
         <HardSubs>
            <TextBased supported="false" />
         </HardSubs>
      </Subtitles>
Help
Post Mon Feb 07, 2022 1:53 am
Re: Samsung Q can't see some videos
First, Samsung DLNA support is terrible. I quit using the internal player on my sets years ago, because there are so many inexpensive players that work far better.
Next, just because something plays via USB doesn't mean it will play via DLNA. Manufacturers can (and do) support DLNA differently than directly connected media.
However, your TV should play that video without transcoding, so in theory the generic profile should work for that particular title. You might give it a go as a test. I wrote the Samsung NU profile, but no longer have the TV because I wasn't impressed at all with its HDR quality. My daughter has it now, but she uses either a Fire TV or Roku as the player for that TV with Serviio.
As a test, you could try some of the other TV profiles in Serviio, such as Sony, LG or Roku TVs. One of them might provide a better experience. But let us know if that file plays with the generic profile, and if it does then see if there are other files that won't play.
