unrecognized file
Elvis71
Post Sun Aug 29, 2010 9:32 am
unrecognized file
I am using Samsung B-series.
I have a file that plays natively when on usb stick, but serviio tries to transcode and then it becomes an unrecognized file format. What should I do to prevent the transcoding?
Details:
Input #0, avi, from 'g:\gm.avi':
ISFT : FairUse Wizard - http://fairusewizard.com
Duration: 00:34:52.76, start: 0.000000, bitrate: 2803 kb/s
Stream #0.0: Video: h264, yuv420p, 720x384 [PAR 1:1 DAR 15:8], 25 fps, 25 tb
r, 25 tbn, 50 tbc
Stream #0.1: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
Post Tue Aug 31, 2010 9:09 am
Re: unrecognized file
It's an AVI with H264, which apparently doesn't work on the TV. You can try removing this line from profiles.xml (in Series B profile):
Then restart the Serviio service and try playing again.
