Re: TV/stream keeps dropping out
Not just BZ then
Wingsgb wrote:The other two streams i tried both crashed out too after 10min, once they crash they crash every min then.
Not just BZ then
henri wrote:Wingsgb wrote:The other two streams i tried both crashed out too after 10min, once they crash they crash every min then.
Not just BZ then
I also tried other streams before, all with the same issue.. strange, really strange..
jhb50 wrote:I'm trying to test these as well. What/where are BZ and YES streams? They are not on SOPCAST list.
Wingsgb wrote:Would be nice for someone with a TV other than samsung to try, proves its not the tv then.
henri wrote:Result:
Via FANTEC TV-FHDS: 70 minutes without interruption. I switched to Samsung now.
[h264 @ 0232f8c0] non-existing PPS referenced
[h264 @ 0232f8c0] non-existing PPS 0 referenced
[h264 @ 0232f8c0] decode_slice_header error
[h264 @ 0232f8c0] no frame!
[mpegts @ 0232bce0] max_analyze_duration 5000000 reached at 5016000
[mpegts @ 0232bce0] decoding for stream 0 failed
[mpegts @ 0232bce0] Could not find codec parameters for stream 0 (Video: h264 ([
27][0][0][0] / 0x001B)): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[mpegts @ 0232bce0] Estimating duration from bitrate, this may be inaccurate
Input #0, mpegts, from 'http://127.0.0.1:8902':
Duration: N/A, start: 29974.226511, bitrate: 96 kb/s
Program 1
Stream #0:0[0x44]: Video: h264 ([27][0][0][0] / 0x001B), 25 tbr, 90k tbn, 18
0k tbc
Stream #0:1[0x45]: Audio: mp3 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16
, 96 kb/s
C:\Program Files\Serviio\lib>Wingsgb wrote:henri wrote:If the Samsung crashes out you will need to try the BZ stream + streams that never worked out on your media player
Wingsgb wrote:Did the TV crash out last night after your media player played the stream fine?
Wingsgb wrote:Looking more like the TV then, something to do with the transcoding maybe.
C:\Program Files\Serviio\lib>ffmpeg -i "http://127.0.0.1:8902"
ffmpeg version N-43594-gf0896a6 Copyright (c) 2000-2012 the FFmpeg developers
built on Aug 15 2012 21:25:48 with gcc 4.7.1 (GCC)
configuration: --enable-gpl --enable-version3 --disable-pthreads --enable-runt
ime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass -
-enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-l
ibfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libopenj
peg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheo
ra --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-li
bvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --ena
ble-zlib
libavutil 51. 69.100 / 51. 69.100
libavcodec 54. 52.100 / 54. 52.100
libavformat 54. 23.101 / 54. 23.101
libavdevice 54. 2.100 / 54. 2.100
libavfilter 3. 9.100 / 3. 9.100
libswscale 2. 1.101 / 2. 1.101
[asf @ 01fabcc0] freeing incomplete packet size 5174, new 5156
[asf @ 01fabcc0] Estimating duration from bitrate, this may be inaccurate
Input #0, asf, from 'http://127.0.0.1:8902':
WMFSDKVersion : 12.0.7600.16385
WMFSDKNeeded : 0.0.0.0000
IsVBR : 0
Duration: N/A, start: 7313.635000, bitrate: 1296 kb/s
Stream #0:0(eng): Audio: wmapro (b[1][0][0] / 0x0162), 44100 Hz, stereo, flt
, 96 kb/s
Stream #0:1(eng): Video: vc1 (Advanced) (WVC1 / 0x31435657), yuv420p, 960x54
0, 1200 kb/s, 1k tbr, 1k tbn, 1k tbc
posejdon wrote:Hello,
try to check the manual if your TV can play 50 fps in HD resolution, this should be the problem, my C6000 cannot play 50 fps in full HD (I think max resolution with 50 fps is 720) I decreased the frame rate on the camcorder and recoded existing files and it works
Wingsgb wrote:Right YES didnt go online so i have been watching the chelsea match on the below link
sop://broker.sopcast.com:3912/131822
This stream has been running on my TV now for 12min then it crashed. It also had NO sound, it said as the stream started on the TV "audio codec not supported" but had stayed running until disconnected.
- Code:
ble-zlib
IsVBR : 0
, 96 kb/s
At least one output file must be specifiedposejdon wrote:Hello,
Just noticed the above reply on another topic which isnt related but dosent BZ stream at 50fps? still dosent explain all the other streams that disconnect
As to your timeout problem, it may be tied to the fact that Serviio caches the attributes of a stream the first time it is added in the console, and those values are used to transcode the stream from then on. Once set there is no way to change those values other than by deleting the Cache folder.
You will need to examine the ffmpeg transcoding statement in your debug log to see what rule is being used for your streams, and ffmpeg -i http://localhost:8902 to determine the attributes of the streams you are playing back, and see if that is a problem.
C:\Program Files\Serviio\lib>ffmpeg.exe -i "http://localhost:8902"
ffmpeg version N-43804-g780bf75 Copyright (c) 2000-2012 the FFmpeg developers
built on Aug 21 2012 21:16:09 with gcc 4.7.1 (GCC)
ble-zlib
libavutil 51. 70.100 / 51. 70.100
libavcodec 54. 54.100 / 54. 54.100
libavformat 54. 25.104 / 54. 25.104
libavfilter 3. 13.100 / 3. 13.100
[NULL @ 0000000000313e00] non-existing PPS referenced
[h264 @ 0000000000313e00] non-existing PPS 0 referenced
[h264 @ 0000000000313e00] decode_slice_header error
[h264 @ 0000000000313e00] no frame!
[h264 @ 0000000000313e00] non-existing PPS referenced
[mpeg @ 000000000227eba0] max_analyze_duration 5000000 reached at 5016000
[mpeg @ 000000000227eba0] Estimating duration from bitrate, this may be inaccura
te
Input #0, mpeg, from 'http://localhost:8902':
Duration: N/A, start: 70981.413667, bitrate: 192 kb/s
Stream #0:0[0x1c0]: Audio: mp2, 48000 Hz, stereo, s16, 192 kb/s
Stream #0:1[0x1e0]: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9]
, 28.17 fps, 25 tbr, 90k tbn, 50 tbc
At least one output file must be specifiedWhat you could do is setup http://localhost:8902 numerous times in a "LiveFeed" folder and use it for playback, so if the feed drops out it will immediately restart because it will go to the next item. 25 items will handle 25 drops before you need to start the menu item again.
2012-08-25 14:14:34,703 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-25 14:14:34,703 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-25 14:14:34,704 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2012-08-25 14:14:34,705 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2012-08-25 14:14:34,706 DEBUG [OnlineLibraryManager] Resource https://sites.google.com/site/wingsgb22/LiveFeeds_iPlayer.rss not in cache yet, loading it
2012-08-25 14:14:34,706 DEBUG [FeedParser] Parsing feed 'https://sites.google.com/site/wingsgb22/LiveFeeds_iPlayer.rss'
2012-08-25 14:14:35,599 DEBUG [FeedParser] Found matching url extractor (LiveFeeds) for resource https://sites.google.com/site/wingsgb22/LiveFeeds_iPlayer.rss
2012-08-25 14:14:35,599 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.lang.IllegalArgumentException: URI is not absolute
at java.net.URI.toURL(Unknown Source)
at org.serviio.library.online.feed.MediaFeedEntryParser.setThumbnail(MediaFeedEntryParser.java:150)
at org.serviio.library.online.feed.MediaFeedEntryParser.parseFeedEntry(MediaFeedEntryParser.java:68)
at org.serviio.library.online.feed.FeedParser.addEntryToFeed(FeedParser.java:166)
at org.serviio.library.online.feed.FeedParser.parse(FeedParser.java:100)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:169)
2012-08-25 14:14:56,379 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.1.109, timeout = 0
2012-08-25 14:14:56,380 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c3ae39b6-2030-3c75-8667-79c385656f9b
2012-08-25 14:14:58,188 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:38<?xml version="1.0" encoding="UTF-8" ?>
<rss version="2.0" xmlns:media="http://search.yahoo.com/mrss/">
<channel>
<title>Sports Live Channels</title>
<link>https://sites.google.com/site/wingsgb22/LiveFeeds_iPlayer.rss</link>
<description>Live Channels from sop</description>
<item>
<title>BloodZeed</title>
<link>http://sopcast</link>
<media:stream url="http://localhost:8902" type="video" />
<media:thumbnail url="" />
</item>
</channel>
</rss>Users browsing this forum: No registered users and 40 guests
