TV/stream keeps dropping out
Wingsgb
Post Mon Aug 20, 2012 7:24 pm
Re: TV/stream keeps dropping out
The other two streams i tried both crashed out too after 10min, once they crash they crash every min then.
Not just BZ then
henri
Post Mon Aug 20, 2012 7:49 pm
Wingsgb wrote:The other two streams i tried both crashed out too after 10min, once they crash they crash every min then.
Not just BZ then
I also tried other streams before, all with the same issue.. strange, really strange..
Wingsgb
Post Mon Aug 20, 2012 9:01 pm
Not just BZ then
Atleast its not to do with the streams. This puts me back to believing its whatever is happening after sopcast. Something must of changed or is doing something different. As you say, very strange indeed.
Any more input on this master Zip :)
Post Tue Aug 21, 2012 1:32 am
I'm trying to test these as well. What/where are BZ and YES streams? They are not on SOPCAST list.
pcblues
Post Tue Aug 21, 2012 12:41 pm
They are listed on here: http://www.wiziwig.tv/competition.php?p ... e=football
Clicking on the match you want then displays a list of streams and you then click on "play now" for the chosen stream and it opens Sopcast or you can cut n' paste the url.
Cheers
John
henri
Post Tue Aug 21, 2012 4:26 pm
jhb50 wrote:I'm trying to test these as well. What/where are BZ and YES streams? They are not on SOPCAST list.
BZ and YES are mostly streaming on EPL match days.
Wingsgb
Post Tue Aug 21, 2012 4:28 pm
BZ is offline now untill the next premier league game at the weekend. His sop link is always the same (sop://broker.sopcast.com:3912/132927)
As for YES that was the first time i used them so i never saved it.
Chelsea are playing tomorrow being wednesday so ill give you some links if you would like to test them.
Would be nice for someone with a TV other than samsung to try, proves its not the tv then.
henri
Post Tue Aug 21, 2012 4:33 pm
Wingsgb wrote:Would be nice for someone with a TV other than samsung to try, proves its not the tv then.
I could try my media streaming device which I used before the Samsung telly. Will check it and let you know.
Testing it right now with this stream: sop://broker.sopcast.com:3912/126767
Result:
Via FANTEC TV-FHDS: 70 minutes without interruption. I switched to Samsung now.
Wingsgb
Post Tue Aug 21, 2012 7:00 pm
henri wrote:Result:
Moment of truth :p
If the Samsung crashes out you will need to try the BZ stream + streams that never worked out on your media player
For anyone that has more knowledge than me, heres the info on the stream henri is playing
[h264 @ 0232f8c0] non-existing PPS referenced
[h264 @ 0232f8c0] non-existing PPS 0 referenced
[h264 @ 0232f8c0] decode_slice_header error
[h264 @ 0232f8c0] no frame!
[mpegts @ 0232bce0] max_analyze_duration 5000000 reached at 5016000
[mpegts @ 0232bce0] decoding for stream 0 failed
[mpegts @ 0232bce0] Could not find codec parameters for stream 0 (Video: h264 ([
27][0][0][0] / 0x001B)): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
[mpegts @ 0232bce0] Estimating duration from bitrate, this may be inaccurate
Input #0, mpegts, from 'http://127.0.0.1:8902':
  Duration: N/A, start: 29974.226511, bitrate: 96 kb/s
  Program 1
    Stream #0:0[0x44]: Video: h264 ([27][0][0][0] / 0x001B), 25 tbr, 90k tbn, 18
0k tbc
    Stream #0:1[0x45]: Audio: mp3 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, s16
, 96 kb/s
C:\Program Files\Serviio\lib>
henri
Post Tue Aug 21, 2012 7:33 pm
Wingsgb wrote:
henri wrote:If the Samsung crashes out you will need to try the BZ stream + streams that never worked out on your media player
To be honest: since I'm only interested in the BZ stream, I will definitely try it on Saturday during the EPL broadcast :D If that old little device plays the stream without interruption, we can screw Samsung :mrgreen:
Wingsgb
Post Wed Aug 22, 2012 8:48 am
Did the TV crash out last night after your media player played the stream fine?
henri
Post Wed Aug 22, 2012 4:37 pm
Wingsgb wrote:Did the TV crash out last night after your media player played the stream fine?
Unfortunately I had to stop it after 10 minutes.. but will try again today for a longer period (in case that there is a useable stream available)
Update:
I'm currently testing the same stream as yesterday on the Samsung: disconnect after 13 minutes.
Currently playing via Media Streaming device since 32 minutes and counting...
Wingsgb
Post Wed Aug 22, 2012 5:58 pm
Looking more like the TV then, something to do with the transcoding maybe.
@JHB50 if you want to test the YES stream that will be live in 30min or so
sop://broker.sopcast.com:3912/6816
henri
Post Wed Aug 22, 2012 6:30 pm
Streaming device was on for 90 minutes. The real test will follow once BZ is streaming again :D
henri
Post Wed Aug 22, 2012 6:31 pm
Wingsgb wrote:Looking more like the TV then, something to do with the transcoding maybe.
The question would be why I was able to watch the BZ stream showing a French league match a few days ago... :roll: :?:
Wingsgb
Post Wed Aug 22, 2012 7:03 pm
Right YES didnt go online so i have been watching the chelsea match on the below link
sop://broker.sopcast.com:3912/131822
This stream has been running on my TV now for 12min then it crashed. It also had NO sound, it said as the stream started on the TV "audio codec not supported" but had stayed running until disconnected.
C:\Program Files\Serviio\lib>ffmpeg -i "http://127.0.0.1:8902"
ffmpeg version N-43594-gf0896a6 Copyright (c) 2000-2012 the FFmpeg developers
  built on Aug 15 2012 21:25:48 with gcc 4.7.1 (GCC)
  configuration: --enable-gpl --enable-version3 --disable-pthreads --enable-runt
ime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libass -
-enable-libcelt --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-l
ibfreetype --enable-libgsm --enable-libmp3lame --enable-libnut --enable-libopenj
peg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheo
ra --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-li
bvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --ena
ble-zlib
  libavutil      51. 69.100 / 51. 69.100
  libavcodec     54. 52.100 / 54. 52.100
  libavformat    54. 23.101 / 54. 23.101
  libavdevice    54.  2.100 / 54.  2.100
  libavfilter     3.  9.100 /  3.  9.100
  libswscale      2.  1.101 /  2.  1.101
[asf @ 01fabcc0] freeing incomplete packet size 5174, new 5156
[asf @ 01fabcc0] Estimating duration from bitrate, this may be inaccurate
Input #0, asf, from 'http://127.0.0.1:8902':
    WMFSDKVersion   : 12.0.7600.16385
    WMFSDKNeeded    : 0.0.0.0000
    IsVBR           : 0
  Duration: N/A, start: 7313.635000, bitrate: 1296 kb/s
    Stream #0:0(eng): Audio: wmapro (b[1][0][0] / 0x0162), 44100 Hz, stereo, flt
, 96 kb/s
    Stream #0:1(eng): Video: vc1 (Advanced) (WVC1 / 0x31435657), yuv420p, 960x54
0, 1200 kb/s, 1k tbr, 1k tbn, 1k tbc
posejdon wrote:Hello,
try to check the manual if your TV can play 50 fps in HD resolution, this should be the problem, my C6000 cannot play 50 fps in full HD (I think max resolution with 50 fps is 720) I decreased the frame rate on the camcorder and recoded existing files and it works
Just noticed the above reply on another topic which isnt related but dosent BZ stream at 50fps? still dosent explain all the other streams that disconnect
henri
Post Wed Aug 22, 2012 8:02 pm
Wingsgb wrote:Right YES didnt go online so i have been watching the chelsea match on the below link
ble-zlib
    IsVBR           : 0
, 96 kb/s
I really think the best will be to wait until the weekend for the BZ stream. Should give us an answer, hopefully :D
Post Wed Aug 22, 2012 11:05 pm
I have followed these posts with interest, since I just started to use SOPCAST.
I have not yet gotten as far as testing your problem, but I have encountered 2 others which I will advise you of here, and make some suggestions regarding your timeouts.
The SOPCAST streams use various codecs. Seems the ones you are using use wmv, but my Eurosport ones use avc/mp2 in an mpegts wrapper. Turns out there is an ffmpeg bug if you copy the avc when you transcode a ts stream to avc/ac3 mpegts, as the Samsung profile does, and ffmpeg fails. My fix is to also transacode the AVC video to mpeg2video.
The second bug is the playback of http streams with Mediaplayer which includes the Sopcast http://127.0.0.1:8902 streams. The first playback of the stream works, but on the second playback serviio trys to use "the previously transcoded stream" which of course does not exist because these are livestreams. Once the stream is played once mediabrowser keeps failing, even if the SOPCAST source is changed. The workaround is to use http://localhost:8902 which seems to start a new transcode each time. This problem is only with Mediaplayer and not with transcoding to the TV.
As to your timeout problem, it may be tied to the fact that Serviio caches the attributes of a stream the first time it is added in the console, and those values are used to transcode the stream from then on. Once set there is no way to change those values other than by deleting the Cache folder.
This creates a potential problem because Sopcast streams have different attributes. Some are avc/mp2.ts, others are wmv2/wma2.asf, etc but Serviio will transcode them per the transcoding rules in the profile for the stream that was active the first time the SOPCAST stream was added http://localhost:8902 to the console. You will need to examine the ffmpeg transcoding statement in your debug log to see what rule is being used for your streams, and ffmpeg -i http://localhost:8902 to determine the attributes of the streams you are playing back, and see if that is a problem.
I have also found that interruptions of the live SOPCAST streams, particularly wmv type, will cause the TV to drop the playback. What you could do is setup http://localhost:8902 numerous times in a "LiveFeed" folder and use it for playback, so if the feed drops out it will immediately restart because it will go to the next item. 25 items will handle 25 drops before you need to start the menu item again.
Hope that helps.
Wingsgb
Post Sat Aug 25, 2012 1:17 pm
Thanks for the reply jhb50 although it dosen't prove why its not working now when we never had to do these things, it use to work perfectly fine with all streams.
I haven't tried your first suggestion as i always fail when editing the profile.
This cant be the case as i have just built a new server today with a new formatted HDD/ install and the stream i like to use has just been put in first to test and still disconnects even while using localhost as URL.
C:\Program Files\Serviio\lib>ffmpeg.exe -i "http://localhost:8902"
ffmpeg version N-43804-g780bf75 Copyright (c) 2000-2012 the FFmpeg developers
  built on Aug 21 2012 21:16:09 with gcc 4.7.1 (GCC)
ble-zlib
  libavutil      51. 70.100 / 51. 70.100
  libavcodec     54. 54.100 / 54. 54.100
  libavformat    54. 25.104 / 54. 25.104
  libavfilter     3. 13.100 /  3. 13.100
[NULL @ 0000000000313e00] non-existing PPS referenced
[h264 @ 0000000000313e00] non-existing PPS 0 referenced
[h264 @ 0000000000313e00] decode_slice_header error
[h264 @ 0000000000313e00] no frame!
[h264 @ 0000000000313e00] non-existing PPS referenced
[mpeg @ 000000000227eba0] max_analyze_duration 5000000 reached at 5016000
[mpeg @ 000000000227eba0] Estimating duration from bitrate, this may be inaccura
te
Input #0, mpeg, from 'http://localhost:8902':
  Duration: N/A, start: 70981.413667, bitrate: 192 kb/s
    Stream #0:0[0x1c0]: Audio: mp2, 48000 Hz, stereo, s16, 192 kb/s
    Stream #0:1[0x1e0]: Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9]
, 28.17 fps, 25 tbr, 90k tbn, 50 tbc
Cant see the "livefeed" file iv created as suggested. I just used the template over off another topic.
2012-08-25 14:14:34,703 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-08-25 14:14:34,703 DEBUG [OnlineRepositoryDAOImpl] Reading all OnlineRepositories
2012-08-25 14:14:34,704 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 1)
2012-08-25 14:14:34,705 DEBUG [OnlineRepositoryDAOImpl] Reading an OnlineRepository (id = 2)
2012-08-25 14:14:34,706 DEBUG [OnlineLibraryManager] Resource https://sites.google.com/site/wingsgb22/LiveFeeds_iPlayer.rss not in cache yet, loading it
2012-08-25 14:14:34,706 DEBUG [FeedParser] Parsing feed 'https://sites.google.com/site/wingsgb22/LiveFeeds_iPlayer.rss'
2012-08-25 14:14:35,599 DEBUG [FeedParser] Found matching url extractor (LiveFeeds) for resource https://sites.google.com/site/wingsgb22/LiveFeeds_iPlayer.rss
2012-08-25 14:14:35,599 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.lang.IllegalArgumentException: URI is not absolute
   at java.net.URI.toURL(Unknown Source)
   at org.serviio.library.online.feed.MediaFeedEntryParser.setThumbnail(MediaFeedEntryParser.java:150)
   at org.serviio.library.online.feed.MediaFeedEntryParser.parseFeedEntry(MediaFeedEntryParser.java:68)
   at org.serviio.library.online.feed.FeedParser.addEntryToFeed(FeedParser.java:166)
   at org.serviio.library.online.feed.FeedParser.parse(FeedParser.java:100)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:169)
2012-08-25 14:14:56,379 DEBUG [DiscoveryAdvertisementNotifier] Multicasting SSDP alive using interface eth3 (Broadcom NetLink (TM) Gigabit Ethernet) and address 192.168.1.109, timeout = 0
2012-08-25 14:14:56,380 DEBUG [DiscoveryAdvertisementNotifier] Sending 6 'alive' messages describing device c3ae39b6-2030-3c75-8667-79c385656f9b
2012-08-25 14:14:58,188 DEBUG [DiscoveryAdvertisementNotifier] Will advertise again in 00:00:38
<?xml version="1.0" encoding="UTF-8" ?>
<rss version="2.0" xmlns:media="http://search.yahoo.com/mrss/">
<channel>
   <title>Sports Live Channels</title>
   <link>https://sites.google.com/site/wingsgb22/LiveFeeds_iPlayer.rss</link>
   <description>Live Channels from sop</description>
   <item>
      <title>BloodZeed</title>
      <link>http://sopcast</link>
      <media:stream url="http://localhost:8902" type="video" />
      <media:thumbnail url="" />
   </item>
</channel>
</rss>
Back to pluging my laptop into the TV
henri
Post Sat Aug 25, 2012 6:53 pm
Couldn't try it today as I wasn't at home but will check the BZ stream tomorrow.
Users browsing this forum: No registered users and 51 guests
