Re: YouTube
jhb50 wrote:Works for me. Did you add it as an RSS-atom?
Yes. It was added as an RSS feed.
zip wrote:And if you are on Linux, do you have the latest FFmpeg, with librtmp ?
I'm using Win7 and 64-bit ffmpeg published on 2012-11-05.
Baumi wrote:Hi I'm also having some problems with the Youtube plugin. I have Serviio installed on Synology NAS and music and loval videos works perfectly. When I have added the online souces with proper RSS-atom. Using my LG Home Cinema (BH6520TN) I can see only you tube video, there is no sound! Using Playstation 3 there is nothing. I have tried to play with changing the profile but it didn't help. Maybe I should play with profiles xml file and add some online transcoding info but I have no idea which onesTurning on / off transcodig also didn't help.
I would like to use my LG to play it (the one I have only video, no sound) so the problem with PS3 is not so important. Thanks
zolt wrote:jhb50 wrote:Works for me. Did you add it as an RSS-atom?
Yes. It was added as an RSS feed.zip wrote:And if you are on Linux, do you have the latest FFmpeg, with librtmp ?
zip wrote:Are you using the latest plugin?
Xmantium wrote:Hi zip, is it possible to add YouTube login.
I've read that when logged in, users in the UK can access full 4oD content (apart from US shows) including Demand Five
Since 4oD are using their new streams format, this seems to be the only way to watch new 4oD content
Without logging in, only selected few shows are displayed in Serviio
Yixzon wrote:Hi guys im new in servio´s world, i already paste the youtube plug in but i dont know what to do to stream a youtube video.... i tried with the links on the beginning of the forun and i cannot reach reproduce youtube videos!
Users browsing this forum: No registered users and 85 guests
