YouTube
zolt
Post Thu Nov 15, 2012 2:52 pm
Re: YouTube
jhb50 wrote:Works for me. Did you add it as an RSS-atom?
Yes. It was added as an RSS feed.
zip wrote:And if you are on Linux, do you have the latest FFmpeg, with librtmp ?
I'm using Win7 and 64-bit ffmpeg published on 2012-11-05.
Baumi
Post Fri Nov 16, 2012 1:47 pm
Re: YouTube
Baumi wrote:Hi I'm also having some problems with the Youtube plugin. I have Serviio installed on Synology NAS and music and loval videos works perfectly. When I have added the online souces with proper RSS-atom. Using my LG Home Cinema (BH6520TN) I can see only you tube video, there is no sound! Using Playstation 3 there is nothing. I have tried to play with changing the profile but it didn't help. Maybe I should play with profiles xml file and add some online transcoding info but I have no idea which ones :P Turning on / off transcodig also didn't help.
I would like to use my LG to play it (the one I have only video, no sound) so the problem with PS3 is not so important. Thanks :)
Any clue?
zolt
Post Sun Nov 18, 2012 7:49 am
Re: YouTube
It seems that I have a similar issue as this one: https://github.com/rg3/youtube-dl/issues/303
Post Sun Nov 18, 2012 8:27 pm
Re: YouTube
Are you using the latest plugin?
Xmantium
Post Mon Nov 19, 2012 12:22 am
Re: YouTube
Hi zip, is it possible to add YouTube login.
I've read that when logged in, users in the UK can access full 4oD content (apart from US shows) including Demand Five
Since 4oD are using their new streams format, this seems to be the only way to watch new 4oD content
Without logging in, only selected few shows are displayed in Serviio
zolt
Post Mon Nov 19, 2012 2:51 pm
Re: YouTube
zip wrote:Are you using the latest plugin?
Yes. The one from 29/9/2012. I have enabled full logging and replaced http with https in a single video link, but with no success.
Post Mon Nov 19, 2012 3:29 pm
Re: YouTube
Xmantium wrote:Hi zip, is it possible to add YouTube login.
Remind me in the beta testing phase, when I have a bit more time.
grolschie
Post Mon Nov 19, 2012 6:00 pm
Re: YouTube
Out of interest, is there an estimate of when the next beta phase might be please?
WildRushSykes
Post Mon Nov 26, 2012 3:51 pm
Re: YouTube
I think youtube have changed things there end again as im getting there are no titles on youtube folders via my PS3 damn you google :(
EDIT: Seems to of been an brief hiccup and its all sorted now :)
Yixzon
Post Mon Nov 26, 2012 11:07 pm
Re: YouTube
Hi guys im new in servio´s world, i already paste the youtube plug in but i dont know what to do to stream a youtube video.... i tried with the links on the beginning of the forun and i cannot reach reproduce youtube videos!
Someone can help me please thanks..... if someone knows about VLC plug in for serviio, please let me know where may i find it!
abhu
Post Mon Nov 26, 2012 11:25 pm
Re: YouTube
Yixzon wrote:Hi guys im new in servio´s world, i already paste the youtube plug in but i dont know what to do to stream a youtube video.... i tried with the links on the beginning of the forun and i cannot reach reproduce youtube videos!
See this post which has some examples:
http://forum.serviio.org/viewtopic.php?f=23&t=3279
Serviio on Win7 32-bit
Sony BDV-E370
Post Thu Nov 29, 2012 11:44 pm
Re: YouTube
and look in the wiki
Death
Post Sat Dec 08, 2012 10:39 am
Re: YouTube
Hi Guys!
Thank you for this great plugin.
But i have a problem with it.
First, it workes fine with my Samsung TV with each youtube video.
BUT i can´t get the playlist work.
My generated Link:
http://gdata.youtube.com/feeds/api/play ... BDB2FE7F56
I see the videos on my TV and i also can choose them.
When i click on play it loads and i get after some time a error "Network connection cancel"
Other youtube videos works, only the playlist won´t work :( :(
And it does not generate a log entry.
Any suggestion?
greetings from Austria
Death
Xmantium
Post Sat Dec 08, 2012 12:39 pm
Re: YouTube
Hi erm Death?
Ive tried this playlist, works fine on my Sony TV and MediaBrowser with the following URL
http://gdata.youtube.com/feeds/api/playlists/4CC62CBDB2FE7F56
I always use ServiioTube Chrome extention to add URLs to Serviio
Death
Post Sat Dec 08, 2012 2:02 pm
Re: YouTube
Hi Xmantium,
I tried the chrome plugin.
Same result, i see the videos on my TV when i click play i get network connection fails...
edit:
Okay now i scrolled down, and there is one video with a cover.
http://www.fotos-hochladen.net/view/fotorba9kzi426.jpg
This one, i can play...the others not o.O
I just have the problem with playlists...other added Videos workes fine.
Xmantium
Post Sat Dec 08, 2012 2:09 pm
Re: YouTube
It plays fine on my TV... could it be region locked not to play on your county...
Have you tried other playlists?
Death
Post Sat Dec 08, 2012 2:51 pm
Re: YouTube
Yes i added UKF Dupstep, same.
There is no region lock, or not to austira...i can watch the videos on my PC and even with Mediabrowser from serviio.
I think there is a buffering problem or something else.
Crazy anyway :(
I listining now to:
http://www.youtube.com/results?search_query=ukf+drum+and+bass&oq=ukf+drum+and+bass&gs_l=youtube.3..0l10.139069.141397.0.141602.14.9.0.5.5.1.189.1105.4j5.9.0...0.0...1ac.1.uFqd5oXnGEc
This one i added to serviio and it works, not the same...not the playlist what i want to have.
Well better than nothing.
T68
Post Mon Dec 10, 2012 7:13 am
Re: YouTube
Hi!
I´m a newbie on serviio and DLNA/UPNP-stuff. Hope you guys can help me out here.
Got Serviio running on a Synology ds212j nas and installed the youtube plugin and one rss source.
In my DLNA apps(Bubbleupnp) on my android devices, a TF101 tablet and a MK808 android tv stick, I can play the youtube videos listed by serviio but there´s no audio!
Tried to different videoplayers: MX, Dice and between hardware and software encoding but still no sound.
So what am I doing wrong? Or is there compability problems between serviio and android devices?
Thank´s for any help!
abubin
Post Mon Dec 17, 2012 2:08 pm
Re: YouTube
is there a way to force the video quality in one particular feed? I want all other youtube feeds to remain at standard high quality but this particular feed, the videos just keep on playing with error. All videos from this feed will play for 1 min or so and then get stuck. Wait while later, around 30sec of the video skipped.
http://gdata.youtube.com/feeds/api/play ... PTSMJ_cgrn
Any ideas?
Post Mon Dec 17, 2012 11:44 pm
Re: YouTube
No, there is no way to select quality per URL.
Return to Available plugins
Users browsing this forum: No registered users and 94 guests
