Can't control (pause/resume/seek) transcoded h264 mkv's
I'm running Serviio 1.4 Pro on my Synology NAS with my Samsung UNF7500 using the Samsung E/F Profile.
When I try to play transcoded h264 mkv's (anime) I'm unable to pause/resume/FF/REW/seek. Pretty much once it starts I can't do anything to it, the TV just says "Not available" when I try any of these things. I've seen that it's a common problem that you can't FF/REW transcoded files and I can live with that but the lack of pausing is killing me. I've also tried adding the --clusters-in-meta-seek to get seeking to work as seen in the stickies but to no avail. Unfortunately the TV can't play these files natively.
Here's an example of a file that shows this behavior:
- Code:
ffmpeg version 2.0.2 Copyright (c) 2000-2013 the FFmpeg developers
built on Jan 11 2014 02:32:36 with gcc 4.6.3 (crosstool-NG 1.17.0)
configuration: --prefix=/usr/syno --incdir='${prefix}/include/ffmpeg' --arch=i 686 --target-os=linux --cross-prefix=/usr/local/i686-pc-linux-gnu/bin/i686-pc-li nux-gnu- --enable-cross-compile --enable-optimizations --enable-pic --enable-gpl --enable-shared --disable-static --enable-version3 --enable-nonfree --enable-li bfaac --enable-encoders --enable-pthreads --disable-bzlib --disable-protocol=rtp --disable-muxer=image2 --disable-muxer=image2pipe --disable-swscale-alpha --dis able-ffserver --disable-ffplay --disable-devices --disable-bzlib --disable-altiv ec --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libmp3lame --d isable-decoder=amrnb --disable-encoder=zmbv --disable-encoder=dca --disable-enco der=ac3 --disable-encoder=ac3_fixed --disable-encoder=eac3 --disable-decoder=dca --disable-decoder=eac3 --disable-decoder=truehd --cc=/usr/local/i686-pc-linux-g nu/bin/i686-pc-linux-gnu-ccache-gcc --enable-yasm --enable-libx264 --enable-enco der=libx264
libavutil 52. 38.100 / 52. 38.100
libavcodec 55. 18.102 / 55. 18.102
libavformat 55. 12.100 / 55. 12.100
libavdevice 55. 3.100 / 55. 3.100
libavfilter 3. 79.101 / 3. 79.101
Input #0, matroska,webm, from 'Hajime no Ippo - Rising - 20.mkv':
creation_time : 2014-02-24 20:27:44
Duration: 00:22:49.94, start: 0.000000, bitrate: 2839 kb/s
Chapter #0.0: start 0.000000, end 36.994000
title : Intro
Chapter #0.1: start 36.995000, end 116.991000
title : Opening
Chapter #0.2: start 116.992000, end 1284.991000
title : Episode 20
Chapter #0.3: start 1284.992000, end 1364.988000
title : Ending
Chapter #0.4: start 1364.989000, end 1369.869000
title : Next Episode Preview
Stream #0:0(jpn): Video: h264 (High 10), yuv420p10le, 1280x720 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
title : Video
Stream #0:1(jpn): Audio: aac, 48000 Hz, stereo, fltp (default)
title : Audio
Stream #0:2(eng): Subtitle: ssa (default)
Codec 0x18000 is not in the full list.
Stream #0:3: Attachment: unknown_codec
filename : DFHSG9.TTC
mimetype : application/x-truetype-font
Stream #0:4: Attachment: unknown_codec
filename : DFLis6.ttc
Stream #0:5: Attachment: unknown_codec
filename : negotiate free.ttf
Stream #0:6: Attachment: unknown_codec
filename : BlackMetalSans.ttf
Stream #0:7: Attachment: unknown_codec
filename : BorisBlackBloxx.ttf
Can anyone provide any insight?
Thanks!
