Can't control (pause/resume/seek) transcoded h264 mkv's
charsher47
Post Thu Feb 27, 2014 12:05 am
Serviio has really been awesome for streaming practically everything I have but there is one problem that's bugging me.
I'm running Serviio 1.4 Pro on my Synology NAS with my Samsung UNF7500 using the Samsung E/F Profile.
When I try to play transcoded h264 mkv's (anime) I'm unable to pause/resume/FF/REW/seek. Pretty much once it starts I can't do anything to it, the TV just says "Not available" when I try any of these things. I've seen that it's a common problem that you can't FF/REW transcoded files and I can live with that but the lack of pausing is killing me. I've also tried adding the --clusters-in-meta-seek to get seeking to work as seen in the stickies but to no avail. Unfortunately the TV can't play these files natively.
Here's an example of a file that shows this behavior:
ffmpeg version 2.0.2 Copyright (c) 2000-2013 the FFmpeg developers
  built on Jan 11 2014 02:32:36 with gcc 4.6.3 (crosstool-NG 1.17.0)
  configuration: --prefix=/usr/syno --incdir='${prefix}/include/ffmpeg' --arch=i        686 --target-os=linux --cross-prefix=/usr/local/i686-pc-linux-gnu/bin/i686-pc-li        nux-gnu- --enable-cross-compile --enable-optimizations --enable-pic --enable-gpl        --enable-shared --disable-static --enable-version3 --enable-nonfree --enable-li        bfaac --enable-encoders --enable-pthreads --disable-bzlib --disable-protocol=rtp        --disable-muxer=image2 --disable-muxer=image2pipe --disable-swscale-alpha --dis        able-ffserver --disable-ffplay --disable-devices --disable-bzlib --disable-altiv        ec --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libmp3lame --d        isable-decoder=amrnb --disable-encoder=zmbv --disable-encoder=dca --disable-enco        der=ac3 --disable-encoder=ac3_fixed --disable-encoder=eac3 --disable-decoder=dca        --disable-decoder=eac3 --disable-decoder=truehd --cc=/usr/local/i686-pc-linux-g        nu/bin/i686-pc-linux-gnu-ccache-gcc --enable-yasm --enable-libx264 --enable-enco        der=libx264
  libavutil      52. 38.100 / 52. 38.100
  libavcodec     55. 18.102 / 55. 18.102
  libavformat    55. 12.100 / 55. 12.100
  libavdevice    55.  3.100 / 55.  3.100
  libavfilter     3. 79.101 /  3. 79.101
Input #0, matroska,webm, from 'Hajime no Ippo - Rising - 20.mkv':
    creation_time   : 2014-02-24 20:27:44
  Duration: 00:22:49.94, start: 0.000000, bitrate: 2839 kb/s
    Chapter #0.0: start 0.000000, end 36.994000
      title           : Intro
    Chapter #0.1: start 36.995000, end 116.991000
      title           : Opening
    Chapter #0.2: start 116.992000, end 1284.991000
      title           : Episode 20
    Chapter #0.3: start 1284.992000, end 1364.988000
      title           : Ending
    Chapter #0.4: start 1364.989000, end 1369.869000
      title           : Next Episode Preview
    Stream #0:0(jpn): Video: h264 (High 10), yuv420p10le, 1280x720 [SAR 1:1 DAR        16:9], 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
      title           : Video
    Stream #0:1(jpn): Audio: aac, 48000 Hz, stereo, fltp (default)
      title           : Audio
    Stream #0:2(eng): Subtitle: ssa (default)
Codec 0x18000 is not in the full list.
    Stream #0:3: Attachment: unknown_codec
      filename        : DFHSG9.TTC
      mimetype        : application/x-truetype-font
    Stream #0:4: Attachment: unknown_codec
      filename        : DFLis6.ttc
    Stream #0:5: Attachment: unknown_codec
      filename        : negotiate free.ttf
    Stream #0:6: Attachment: unknown_codec
      filename        : BlackMetalSans.ttf
    Stream #0:7: Attachment: unknown_codec
      filename        : BorisBlackBloxx.ttf
Can anyone provide any insight?
Thanks!
Iveky
Post Thu Feb 27, 2014 7:05 am
Re: Can't control (pause/resume/seek) transcoded h264 mkv's
this is reason why it has to be transcoded:
but i think, on my ES Samsung I can pause transcoded videos... but I am not sure 100%, will check tonite.
charsher47
Post Thu Feb 27, 2014 5:25 pm
Iveky wrote:this is reason why it has to be transcoded:
Ya i realize with such a high AVC level it needs transcoding and I prefer the burned in subtitles so it needs to be transcoded anyway. If only the pausing worked it, which I find strange since I scowered the forums and couldn't find any Samsung users with this problem.
FYI I'm on the latest firmware.
Iveky
Post Thu Feb 27, 2014 5:51 pm
as I said this morning, transcoded files (i tested on one 3gp file) I can press pause to stop video.
It doesnt work jumping 30 sec forward/backward as on untranscoded files, only optzion that works is: PAUSE, pressing again continues.
Samsung UE46ES6800
charsher47
Post Thu Feb 27, 2014 8:44 pm
Iveky wrote:as I said this morning, transcoded files (i tested on one 3gp file) I can press pause to stop video.
Samsung UE46ES6800
Thanks for testing that out... I wonder why pausing doesn't work on my unit (UN60F7500). Can anyone with an F-Series chime in?
Would this solely be a Samsung firmware problem?
Iveky
Post Thu Feb 27, 2014 8:59 pm
don't think so.
try mine 3gp file... they are not huge, you can download it and test. only 18MB
http://maliplaninar.net84.net/MOV014.3gp
charsher47
Post Thu Feb 27, 2014 10:54 pm
Iveky wrote:don't think so.
My TV won't play that file, it says the file isn't supported and the log reads:
2014-02-27 17:47:22,424 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.47.81, Profile=Samsung TV / player (E/F-series)'
2014-02-27 17:47:22,424 DEBUG [ResourceDeliveryProcessor] Request for resource 34134 and type 'MEDIA_ITEM' received
2014-02-27 17:47:22,424 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 34134 (local)
2014-02-27 17:47:22,424 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 34134)
2014-02-27 17:47:22,424 DEBUG [VideoDAOImpl] Reading a Video (id = 34134)
2014-02-27 17:47:22,425 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 34134, format MPEG4_P2_TS_ASP_AC3_ISO and profile Samsung TV / player (E/F-series)
2014-02-27 17:47:22,426 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file MOV014.3gp
2014-02-27 17:47:22,426 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MOV014.3gp: MPEG4_P2_TS_ASP_AC3_ISO
2014-02-27 17:47:22,427 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Thu, 27 Feb 2014 22:47:22 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache
2014-02-27 17:47:22,444 DEBUG [ServiioHttpService] Incoming request from /192.168.47.81:33720: GET /resource/34134/MEDIA_ITEM/MPEG4_P2_TS_ASP_AC3_ISO-0/ORIGINAL HTTP/1.0, headers = [getcontentFeatures.dlna.org: 1,transferMode.dlna.org: S
2014-02-27 17:47:22,444 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.47.81
2014-02-27 17:47:22,445 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.47.81
2014-02-27 17:47:22,446 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.47.81, Profile=Samsung TV / player (E/F-series)'
2014-02-27 17:47:22,446 DEBUG [ResourceDeliveryProcessor] Request for resource 34134 and type 'MEDIA_ITEM' received
2014-02-27 17:47:22,446 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 34134 (local)
2014-02-27 17:47:22,446 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 34134)
2014-02-27 17:47:22,447 DEBUG [VideoDAOImpl] Reading a Video (id = 34134)
2014-02-27 17:47:22,448 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 34134, format MPEG4_P2_TS_ASP_AC3_ISO and profile Samsung TV / player (E/F-series)
2014-02-27 17:47:22,448 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file MOV014.3gp
2014-02-27 17:47:22,449 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MOV014.3gp: MPEG4_P2_TS_ASP_AC3_ISO
2014-02-27 17:47:22,449 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 34134 (local)
2014-02-27 17:47:22,449 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 34134)
2014-02-27 17:47:22,449 DEBUG [VideoDAOImpl] Reading a Video (id = 34134)
2014-02-27 17:47:22,450 DEBUG [VideoDeliveryEngine] Delivering item '34134' for client 'Identifier=192.168.47.81, Profile=Samsung TV / player (E/F-series)'
2014-02-27 17:47:22,450 DEBUG [VideoDeliveryEngine] Delivering file 'MOV014.3gp' using transcoding
2014-02-27 17:47:22,451 DEBUG [AbstractTranscodingDeliveryEngine] No other client uses transcoding job of file 'transcoding-temp-34135-sam_ef-ORIGINAL.stf', will stop the job
2014-02-27 17:47:22,451 DEBUG [AbstractTranscodingDeliveryEngine] Stopping previous transcoding job of file 'transcoding-temp-34135-sam_ef-ORIGINAL.stf'
2014-02-27 17:47:22,451 DEBUG [ProcessExecutor] Stopping external process: Thread[Thread-6162,5,main]
2014-02-27 17:47:22,451 DEBUG [ProcessUtils] Sending kill -9 to the Unix process: 30218
2014-02-27 17:47:22,451 DEBUG [ProcessExecutor] Starting kill -9 30218
2014-02-27 17:47:22,465 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
2014-02-27 17:47:22,466 DEBUG [TranscodingJobListener] Deleted temp file '/volume1/@tmp/Serviio/transcoding-temp-34135-sam_ef-ORIGINAL.stf': true
2014-02-27 17:47:22,466 DEBUG [AbstractTranscodingDeliveryEngine] No suitable transcoding job exists yet, start one for client 'Identifier=192.168.47.81, Profile=Samsung TV / player (E/F-series)'
2014-02-27 17:47:22,466 DEBUG [MediaItemDAOImpl] Getting file of media item 34134
2014-02-27 17:47:22,467 DEBUG [FFMPEGWrapper] Invoking FFmpeg to transcode video file: /volume1/Downloads/MOV014.3gp
2014-02-27 17:47:22,482 DEBUG [ProcessExecutor] Starting /volume1/@appstore/Serviio/bin/ffmpeg -fflags +genpts -threads auto -i /volume1/Downloads/MOV014.3gp -y -threads auto -c:v copy -c:a ac3 -b:a 32k -ar 48000 -ac 1 -map 0:1 -map 0:0
2014-02-27 17:47:22,984 DEBUG [FileBasedTranscodingDeliveryStrategy] Sending transcoding stream
2014-02-27 17:47:22,984 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MOV014.3gp: MPEG4_P2_TS_ASP_AC3_ISO
2014-02-27 17:47:22,984 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 34134) as read
2014-02-27 17:47:23,124 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2014-02-27 17:47:23,124 DEBUG [GETMethodProcessor] Stream entity has length: 50000000000
2014-02-27 17:47:23,125 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Thu, 27 Feb 2014 22:47:23 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache
2014-02-27 17:47:24,287 DEBUG [ServiioHttpService] Incoming request from /192.168.47.81:57132: HEAD /resource/34134/MEDIA_ITEM/MPEG4_P2_TS_ASP_AC3_ISO-0/ORIGINAL HTTP/1.0, headers = [getCaptionInfo.sec: 1]]
2014-02-27 17:47:24,287 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.47.81
2014-02-27 17:47:24,288 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.47.81
2014-02-27 17:47:24,289 DEBUG [ResourceDeliveryProcessor] Resource request accepted. Using client 'Identifier=192.168.47.81, Profile=Samsung TV / player (E/F-series)'
2014-02-27 17:47:24,289 DEBUG [ResourceDeliveryProcessor] Request for resource 34134 and type 'MEDIA_ITEM' received
2014-02-27 17:47:24,289 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 34134 (local)
2014-02-27 17:47:24,289 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 34134)
2014-02-27 17:47:24,290 DEBUG [VideoDAOImpl] Reading a Video (id = 34134)
2014-02-27 17:47:24,290 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 34134, format MPEG4_P2_TS_ASP_AC3_ISO and profile Samsung TV / player (E/F-series)
2014-02-27 17:47:24,291 DEBUG [AbstractTranscodingDeliveryEngine] Getting media info for transcoded version of file MOV014.3gp
2014-02-27 17:47:24,291 DEBUG [VideoDeliveryEngine] Found Format profile for transcoded file MOV014.3gp: MPEG4_P2_TS_ASP_AC3_ISO
2014-02-27 17:47:24,292 DEBUG [VideoDAOImpl] Reading a Video (id = 34134)
2014-02-27 17:47:24,292 DEBUG [MediaItemDAOImpl] Getting file of media item 34134
2014-02-27 17:47:24,294 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/mpeg,Content-Length: 50000000000,Date: Thu, 27 Feb 2014 22:47:24 GMT,Server: Linux, UPnP/1.0 DLNADOC/1.50, Serviio/1.4,Cache
2014-02-27 17:47:27,082 DEBUG [TranscodingJobListener] Transcoding finished; successful: true
Iveky
Post Fri Feb 28, 2014 7:27 am
you need to additionaly change E/F profile:
            <Matches container="3gp" vCodec="h264" aCodec="amrnb" />
            <!--Matches container="3gp" vCodec="mpeg4" aCodec="amrnb" /-->
            <Matches container="wtv" vCodec="h264"/>
        <!-- my phone produces 3gp that don't fit above (i have to diasble 3gp-mpeg4 line above), so needed this section below-->
        <Video targetContainer="mpegts" targetVCodec="mpeg2video" targetACodec="ac3" forceVTranscoding="true" maxVBitrate="4096" aBitrate="192" forceInheritance="true">
            <Matches container="3gp" />
explanation:
find above 2 lines with 3gp ( !--means disable it-- ) , and below them add that section. restart and try again.
charsher47
Post Fri Feb 28, 2014 10:20 pm
Iveky wrote:you need to additionaly change E/F profile:
explanation:
I modified the E/F Series profile per your instructions and forced the file to be transcoded to play, however, pausing still does not work..
In an effort to narrow down the problem I started another Serviio server on my PC and streamed it from there to my TV and pausing also still does not work :?
Post Fri Feb 28, 2014 10:47 pm
I'm not a Samsung user so I could be way off track, but I do remember reading that the fwd and rewind functions are not available for DLNA, but rather you can use the jump forward/jump back functions by pressing the ">" and "<" instead of FF and REW keys. Press and hold these buttons for faster jumping.
It may be the case they also use a different button for pause? My panasonic uses the up arrow key for example. Anyway just guessing.... What keys is everyone using?
charsher47
Post Fri Feb 28, 2014 10:53 pm
DenyAll wrote:I'm not a Samsung user so I could be way off track, but I do remember reading that the fwd and rewind functions are not available for DLNA, but rather you can use the jump forward/jump back functions by pressing the ">" and "<" instead of FF and REW keys. Press and hold these buttons for faster jumping.
Literally pressed every button available. The only thing I can do is exit the video, everything else just makes the TV display "Not Available". In files that I can play natively I'm able to pause and seek as you described though.
Iveky
Post Fri Feb 28, 2014 11:04 pm
so, you can't pause this video?
now you can try to see if makes difference to use other codec:
instead:
try:
<Video targetContainer="mpegts" targetVCodec="h264" targetACodec="aac" forceVTranscoding="true" maxVBitrate="2048" aBitrate="192" forceStereo="true" forceInheritance="true">
if this doesn't help, I have no idea
Post Fri Feb 28, 2014 11:24 pm
or try a different container (eg. mpeg).
charsher47
Post Fri Feb 28, 2014 11:32 pm
Iveky wrote:so, you can't pause this video?
instead:
try:
Gave that a go but it still doesn't pause or seek...
Thanks for trying at least. I didn't think different models in each series were that different but I don't see any other F-Series users complaining about this.
charsher47
Post Fri Feb 28, 2014 11:38 pm
DenyAll wrote:or try a different container (eg. mpeg).
Forced transcoded an mpeg file... still no dice :( So it seems transcoding ANYTHING won't allow me to pause.
Iveky
Post Sat Mar 01, 2014 6:14 am
try firmware upgrade.... first check with others (Samsung F7XXX) that use similar model which firmware they have
charsher47
Post Sat Mar 01, 2014 3:25 pm
Iveky wrote:try firmware upgrade.... first check with others (Samsung F7XXX) that use similar model which firmware they have
I've got the latest firmware which is 1119.1, it also didn't work on 1118.1. Models F7450/F7500/F7550/F8000 share the same firmware so hopefully someone with these TV's might have some input.
If it matters, I can pause these same transcoded videos using other servers such as PS3 Media Server and Samsung Link (Allshare).
Post Tue Mar 04, 2014 9:14 pm
Samsung AllShare doesnt transcode, so perhaps you can update the profile to play the file natively.
charsher47
Post Wed Mar 05, 2014 5:50 pm
zip wrote:Samsung AllShare doesnt transcode, so perhaps you can update the profile to play the file natively.
Well the problem is I can't pause transcoded files... obviously for files that it can't play natively. I probably streamed something that I force transcoded on serviio to allshare then. But I reconfirmed PS3 Media Server serves it fine with pause and seek working.
Post Wed Mar 05, 2014 7:33 pm
Perhaps PS3MS doesn't transcode the file either?
