DLNA problem with TV PFL6606H
goti80
Post Fri Sep 07, 2012 4:17 pm
Hello all,
I written from Bulgaria and i have the following problem with my TV.
The TV is PHILIPS PFL6606H with software:
- SOFTWARE UPDATE: Q5551-0.14.99.00
- Release for: TV550R3
- Q5551-0.14.99.0_bld78a
The version of SERVIIO IS:
- 1.0.1
The PC have Windows 7
1. I try to connect my TV with PC from one mount ago, but without result. I try with SERVIIO now, but the server cant playing every files.
These files can not playing, do not have any message just do not play...
- The.Avengers.2012.720p.BDRip.XviD.AC3-ASSASSiNS / Video Clip (.avi) - 3.47GB
- Bad.Ass.2012.720p.BRRip.XviD.AC3-NFT / Video Clip (.avi) - 2.34GB
- The.Cold.Light.of.Day.2012.720p.BRRip.XviD.AC3-ASSASSiNS / Video Clip (.avi) - 2.57GB
2. Some of the files playing but not running smoothly, I mean not running well like these format :
- Days.of.Thunder.1990.720p.BluRay.DTS.x264-RuDE / MKV - Matroska Video files (.mkv) - 6.58GB
I try many times on WI-FI connect, but this files and some others like this playing well only with LAN to TV from router, and LAN to PC from router.
This is very uncomfortable, because i have WI-FI TV.
Now i try again with LAN cable, but this time i do not succeed.
And i have another problem now, when i restart the Servio to try again, i do not started now. The have this message:
- Serviio error.Cannot connect to Serviio server,it does not seem to be running.
Can you somebody help me please to enjoy the DLNA connect, i will be great full.
Thanks in advance, and sorry to bother you and for my bad English.....
Best Regards,
Yavor
Post Tue Sep 11, 2012 12:52 pm
Re: DLNA problem with TV PFL6606H
Might be wifi. Are you using the Philips profile?
Post Tue Sep 11, 2012 2:48 pm
If you change from Wifi to LAN, and LAN to Wifi, you probably have to change the serviio server IP address (serviio console, IP Bound field) according to the network used.
To find IP address, execute "ipconfig /all" on windows terminal.
And I also suggest to fix all IP address of your devices.
Wingmann
Post Thu Sep 20, 2012 2:13 pm
Try this profile and see how it works for you. If I understood serviio right it should be much less CPU hungry and would work better with your setup.
<Profile id="20" name="Philips" extendsProfileId="1">
      <Detection>
         <UPnPSearch>
            <FriendlyName>.*PHILIPS.*</FriendlyName>
         </UPnPSearch>
      </Detection>
      <MediaFormatProfiles>
         <MediaFormatProfile mime-type="video/avi" name="">AVI</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-matroska" name="">MATROSKA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">AVC_MP4_MP_SD_AAC_MULT5</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">AVC_MP4_MP_SD_MPEG1_L3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">AVC_MP4_MP_SD_AC3</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">AVC_MP4_MP_HD_720p_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">AVC_MP4_MP_HD_1080i_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">AVC_MP4_HP_HD_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">AVC_MP4_LPCM</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">MPEG4_P2_MP4_ASP_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">MPEG4_P2_MP4_SP_L6_AAC</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">MPEG4_P2_MP4_NDSD</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/h264" name="">FLV</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-ms-wma" name="">WMA_BASE</MediaFormatProfile>
         <MediaFormatProfile mime-type="audio/x-ms-wma" name="">WMA_FULL</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf" name="">VC1_ASF_AP_L1_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf" name="">VC1_ASF_AP_L2_WMA</MediaFormatProfile>
         <MediaFormatProfile mime-type="video/x-ms-asf" name="">VC1_ASF_AP_L3_WMA</MediaFormatProfile>
      </MediaFormatProfiles>
         <Video targetContainer="mpeg" targetACodec="ac3" targetVCodec="mpeg2video">
            <Matches container="asf" />
            <Matches container="ogg" />
            <!-- if audio is DTS, must be transcoded -->
      <OnlineTranscoding>
         <Video targetContainer="mpeg" targetVCodec="mpeg2video" targetACodec="ac3" aBitrate="384">
            <Matches container="mp4" />
            <Matches container="flv" />
            <Matches container="mp3"/>
            <Matches container="flv"/>
            <Matches container="asf"/>
         </Audio>
      </OnlineTranscoding>
Wingmann
Post Mon Oct 15, 2012 9:32 pm
Updated version.
      <Detection>
         <UPnPSearch>
         </UPnPSearch>
      </Detection>
      <!-- if audio is DTS, audio must be transcoded -->
      <OnlineTranscoding>
         </Audio>
mitsucats
Post Wed Jul 11, 2018 6:28 pm
Hallo
i would like to try this, but everytime i put this in end of the profile.xml before the last /profile.
and try to stop and start the serviio server it says error please check log.
Post Wed Jul 11, 2018 11:49 pm
mitsucats wrote:Hallo
Upload the log file, so we can see the error message. Also, attach your profiles.xml file and we can look for typos.
Return to Philips
