Some MKVs lock up c5500
Post Fri Jul 15, 2011 12:14 pm
Re: Some MKVs lock up c5500
I think you're right, although haven't done it myself so I might be wrong ;-) I'd have thought you don't have to reencode, just remux it into a new mkv without header compression.
kdp99
Post Fri Jul 15, 2011 12:42 pm
zip wrote:I think you're right, although haven't done it myself so I might be wrong ;-) I'd have thought you don't have to reencode, just remux it into a new mkv without header compression.
Thanks I'll give it a go and post the results
kdp99
Post Fri Jul 15, 2011 5:27 pm
I can confirm that reading the file into MKV merge, setting audio and video headers to default and writing it out fixes the problem.
Many thanks
To forum supervisors, is it worth putting the two problems and fixes found in this thread, along with others that must be around, into an FAQ - problems and fixes for files that do not play ?
Keith
Post Fri Jul 15, 2011 7:12 pm
i apologise that was me posting while half asleep i ment to write Remux not reencode very sry for that :(
AndyKnott
Post Fri Jul 15, 2011 7:46 pm
As pointed out to me on another site, the IMMERSE audio problem can be solved within "mkvmerge", without having to resort to "mkvpropedit":
1: Run mkvmerge, click "File" and select "Header editor" (or press CTRL+E)
2: In the Header editor window, click "File" and "Open". Select and load the MKV you wish to fix.
3: From the list, expand "Audio track 2" and click "Audio sampling frequency"
4: Both the "Original value" and the "Current value" will read "0". Set the "Current value" to "48000".
5: Go to "File" and click "Save".
Job done, without all the command window hassle.
Cheers,
Andy
kdp99
Post Sat Jul 16, 2011 7:16 am
AndyKnott wrote:As pointed out to me on another site, the IMMERSE audio problem can be solved within "mkvmerge", without having to resort to "mkvpropedit":
Cheers,
Andy
Great help, much easier, thanks again
Previous
