Can't see folders
DANNY24
Post Sun Aug 07, 2011 9:07 pm
Can't see folders
Hi Guys
I have a Samsung BD-C6500 and I'm trying to connect it to my PC. It's all setup and I can see movies which are in my standard Videos folder (the one created with Windows), but I don;t seem to be able to see any other folders.
I opened the Library tab in the Serviio software and browsed for the folders I usually keep my movies in, but I don't see these folders on my TV, just a load of generic ones. It's obviously working, so why can't I see the other folders?
I have made sure they are shared, and as I am the only user of this PC (administrator) I should have all the rights I need
Any ideas?
Post Sun Aug 07, 2011 10:21 pm
Re: Can't see folders
DANNY24 wrote:Hi Guys
Any ideas?
serviio can take 24+ hours to fully build the library for the first time, also if you want to see your movies in there original folder structure rather than the serviio sorted folders you have to select the FOLDER catagory. :)
DANNY24
Post Mon Aug 08, 2011 11:49 am
Thanks Cerberus
I'll change the way I view folders and I'll leave the PC switched on for 24+ hours when I get home tonight
It seems like a long time to build the library, but as long as it works it;s ok
Cheers
Post Mon Aug 08, 2011 6:40 pm
DANNY24 wrote:Thanks Cerberus
Cheers
yer library refresh/build speed is improved in the next release :)
DANNY24
Post Tue Aug 09, 2011 9:13 pm
iT'S STILL NOT WORKING UNFORTUNATELY.
I can still only see movies which are placed in the Windows Movie folder. No other folders are being picked up by the software.
I have two folders showing in the Library, each of which has one movie. It can#t take 24 hours to refresh this surely???
Post Tue Aug 09, 2011 9:26 pm
DANNY24 wrote:iT'S STILL NOT WORKING UNFORTUNATELY.
please post a serviio detailed log file.
Post Wed Aug 10, 2011 7:19 am
DANNY24 wrote:...I can still only see movies which are placed in the Windows Movie folder. No other folders are being picked up by the software.
To resume:
Only local folder works.
Remote folder failed.
:arrow: Check the user access, and used UNC path for remote folder ( \\Buffalo\Share\Movie....., not Z:\Movie)
-->http://www.serviio.org/component/content/article/21#q5
DANNY24
Post Wed Aug 10, 2011 4:53 pm
Hi Guys
Just to be perfectly honest I haven't read any manuals on how to set this up. However, the software seems very intuitive so unless I'm being a muppet (if I am I'd like to be Beaker please) there is definatley something wrong.
As I say I have placed one video file in the standard Windows Video folder <C:\Users\Danny\My Videos> which I can see on my TV through the BluRay player. I can play this without issue. I have now added a second full length movie which I can also play without issue, so the connection between my PC and BluRay player is cleary working (with the C:\drive).
I should point out when I talk about 'other drives' I'm not connected to a network, rather these are physical disks in the same PC as my C:\drive. There therefore isn't a UNC path as far as I'm aware? Even so I am selecting them from the Library tab using the Add Local command button. I then browse to where my movies are stored, tick all the checkboxes to share movies, pictures, music etc and finally Save.
When I then go to my TV and boot up the Bluray I change the device to Danny-PC, select Videos which takes me to a lot of generic folders. One of these is called All Videos so I select that one and I just see the two movie files on my C:\drive. I've made sure there are no spaces in the folder path (just in case) but it just isn't working for me.
Do I need to do something else?
Post Wed Aug 10, 2011 6:06 pm
Serviio doesn't have a folder called All Videos. Are you sure you're browsing Serviio on the player and not (for example) Windows media Player?
DANNY24
Post Wed Aug 10, 2011 7:12 pm
Really? Hmmm....that's strange
As far as I'm aware the only two DNLA applicaitons I have installed are Samsung PC Share Manager (which used to work before I had to reformat my hard drive and now doesn't find my BluRay player) and Serviio. With Samsung PC Manager switched off I assumed what I was seeing on my TV must be coming from Serviio. Maybe not???
OK....this points to me having set the software up incorrectly in the first place. What I did was opened the administrator console of my Virgin router to find out which devices were connected. They are;
6c:f0:49:e9:17:62 192.168.0.3 Danny-PC 0days 2hrs 34mins 53s
00:23:99:53:30:66 192.168.0.7 0days 0hrs 8mins 47s
The first address is my PC, and the second is my BluRay player. I added this second IP address (192.168.0.7) to the Renderer Profile section on the Status tab, which appears with an amber light on the left. I leave the Profile as Generic DNLA Profile before finally carrying out a Save
Is this correct?
DANNY24
Post Fri Aug 12, 2011 5:53 pm
Bump
Post Fri Aug 12, 2011 6:07 pm
On my Samsung D5300 Serviio comes up with something containing "Share" but then if I remember right it says Serviio and the computer name.
janaz
Post Fri Sep 09, 2011 8:49 am
I had serviio version 5 and downloaded the 52 version. Everything was working fine prior to the download.
I have not adjusted any folders, nor changed any settings on either the laptop or serviio or samsung Tv.
it recognises serviio with no problem.
But the samsung series C is only bringing up 2 folders of the 5 that the previous one was bringing up.
I have even tried adding the individual folder itself but this didnt work either.
The videos are all avi but only 2 folders come up. Before the downloaded it had no problems.
Now the old version is doing the same thing.
I left serviio to add new files for over 24 hours now and still only 2 folders come up. I saw on the forum it says to look up the log.. I have no idea how to do this or where to find this.
It always stays in checking for new files.. but its not because nothing comes up after 48 hours now.
Are you able to try assist me with this please?
Post Fri Sep 09, 2011 7:32 pm
janaz wrote:I had serviio version 5 and downloaded the 52 version. Everything was working fine prior to the download.
do a complete reinstall of serviio, uninstall serviio remove all folders that are left thebn reinstall. if that doesnt work post a detailed lgo file (howto in my signiture )..
