Blue button - D series
With my Harmony, I have implemented jump forward 3 minutes and 9 minutes, and back 2 minutes buttons using the tools/time menu which allows me to move within videos that support jump.
Hope that helps.
jhb50 wrote:My D series experience is that the TV will provide the Resume D button, and provide accellerated ff/rew when direction keys are held down, but that the BR players do not support the Resume D button function, and only jump 10 seconds with eack direction key press.
Hope that helps.
jhb50 wrote:What do you mean by sketchie. It either works or it does not. I have a 2011 D model BR player and they all use the same firmware and the "D Button" resume feature does not appear when restarting the play back of any video.
Perhaps you would post the model number that you have where the D button prompt does appear on restart. I'd love to buy one.
<DeviceDescription>
<ExtraElements><sec:ProductCap>smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec</sec:ProductCap> <sec:X_ProductCap>smi,DCM10,getMediaInfo.sec,getCaptionInfo.sec</sec:X_ProductCap></ExtraElements>
</DeviceDescription>
<ContentDirectoryDefinitionFilter>org.serviio.upnp.service.contentdirectory.definition.SamsungContentDirectoryDefinitionFilter</ContentDirectoryDefinitionFilter>
jhb50 wrote:Just to confirm, this profile change does nothing to enable Resume on D series BR players simply because the Blue Button support that is on the C Series BR Players that the profile change helps, has been removed from the D Series BR players, so the profile has no impact on that function.
jhb50 wrote:I did not say devices. I said BR. The TV works fine. You might want to get one and see for yourself. I can only report on the actual function of the devices I have and have tested. Blue (D) button support is definitely not on the 2011 D series BR devices, and there is no reference in the manual that it is there, as the TV manual has.
