No sound from some MKV files
cool_dave
Post Sat Sep 08, 2012 5:34 am
I have a Samsung PN64D8000 TV. I am using Serviio to stream videos from my computer to the TV. However, there have been some MKV files that play with sound just fine on my computer, but when I play them on my TV through Serviio there is no sound. What can I do about this? Is there a transcoding profile you would suggest I use to get sound from the MKV files on my TV like I do on my computer? Thanks!
-Dave
Post Sat Sep 08, 2012 7:22 am
Re: No sound from some MKV files
Please provide details of the file that has problems (see my sig), and confirm which profile your using (it will be listed in the console).
cool_dave
Post Sat Sep 08, 2012 11:07 pm
Here are the details of one of the files in the series I am having problems with:
built on Jul 10 2012 22:12:54 with gcc 4.0.1 (Apple Inc. build 5493)
configuration: --enable-static --disable-shared --bindir=/tmp/ffmpeg --disable-ffplay --disable-ffserver --enable-libmp3lame --enable-librtmp --enable-pthreads --disable-mmx --extra-ldflags=-L/tmp/static/lib --extra-cflags=-I/tmp/static/include --extra-libs=-lpolarssl
Input #0, matroska,webm, from '/Users/dave/Movies/Mad.Men.S05E03.Tea.Leaves.720p.WEB-DL.AAC2.0.H.264-CtrlHD.mkv':
creation_time : 2012-04-02 11:37:11
Duration: 00:47:45.66, start: 0.000000, bitrate: 3247 kb/s
Stream #0:0(eng): Audio: aac, 48000 Hz, stereo, s16 (default)
Stream #0:1(eng): Video: h264 (High), yuv420p, 1280x720 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 1k tbn, 2k tbc (default)
I am using the "Samsung TV / player (C/D/E-series)" profile. Thanks for your help!
-Dave
Post Sun Sep 09, 2012 7:34 am
Video file seems good.
Could you provide MediaInfo tool result ?
Don't know if AAC audio is support on mkv file with samsung device. Someone could confirm?
cool_dave
Post Sun Sep 09, 2012 10:08 am
How exactly do I get the MediaInfo tool result? If AAC audio isn't supported on MKV files with Samsung devices, is there anything I can do to still get sound from the MKV on my Samsung TV? Thanks!
-Dave
cool_dave
Post Sun Sep 09, 2012 10:18 am
I actually figured out how to get the MediaInfo. I have listed it below. Thanks!
-Dave
Unique ID                                : 245852077538713604344091296047649252644 (0xB8F5634700A393638A43E269F267E524)
Complete name                            : /Volumes/SWISNIFE1/Videos/Mad Men Season 5/Mad.Men.S05E03.Tea.Leaves.720p.WEB-DL.AAC2.0.H.264-CtrlHD.mkv
File size                                : 1.08 GiB
Duration                                 : 47mn 45s
Overall bit rate                         : 3 247 Kbps
Encoded date                             : UTC 2012-04-02 11:37:11
Writing application                      : mkvmerge v5.2.1 ('A Far Off Place') built on Jan  2 2012 23:21:10
Writing library                          : libebml v1.2.3 + libmatroska v1.3.0
Format profile                           : High@L3.1
Format settings, CABAC                   : No
Format settings, ReFrames                : 2 frames
Duration                                 : 47mn 45s
Codec ID                                 : A_AAC
Duration                                 : 47mn 45s
cool_dave
Post Sun Sep 09, 2012 10:42 am
I have done a little more research on the forums and found a topic that solved the problem for me. Here is a link to the topic: viewtopic.php?f=10&t=4143.
The only problem now is I can't fast forward or rewind with the video file. Is there a way to solve that problem? Thanks!
-Dave
