An unexpected error occurred (500). Check the log.
DangeR
Post Sat Apr 13, 2013 9:32 pm
Hi guys, i'm a new user of Serviio and i must say it's cool. I always used Samsung Allshare from Windows 8 with my Samsung TV UE40D5500.
Now i bought a MacBook and installed Serviio. Also i set it to automatically start Serviio on Mac. I started to use Serviio and everything was ok before the free trial expired.
Now every time i power on the macbook i can't open serviio on tv. If i try to open the app from the folder i have this error An unexpected error occurred (500). Check the log.. Any idea please?
Here is the code:
2013-04-14 00:27:50,968 WARN  [LibraryAdditionsCheckerThread] Cannot add file The.Walking.Dead.S03E13.1080p.WEB-DL.AAC2.0.H.264-Cyphanix.mkv because of an unexpected error. Message: null
   at org.serviio.library.dao.MediaItemDAOImpl.getMediaItem(MediaItemDAOImpl.java:79)
   at org.serviio.library.dao.MediaItemDAOImpl.isMediaItemPresent(MediaItemDAOImpl.java:59)
   at org.serviio.library.local.service.MediaService.isMediaPresentInLibrary(MediaService.java:37)
   at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.addNewMediaFile(LibraryAdditionsCheckerThread.java:172)
   at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:145)
   at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.searchForNewFiles(LibraryAdditionsCheckerThread.java:134)
   at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:83)
2013-04-14 00:27:50,969 WARN  [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
java.sql.SQLException: No suitable driver found for jdbc:derby:db;create=true
   at java.sql.DriverManager.getConnection(DriverManager.java:602)
   at java.sql.DriverManager.getConnection(DriverManager.java:207)
   at org.serviio.db.DBConnectionPool.newConnection(DBConnetionPool.java:186)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:123)
   at org.serviio.db.DBConnectionPool.getConnection(DBConnetionPool.java:149)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:66)
   at org.serviio.db.DatabaseManager.getConnection(DatabaseManager.java:59)
   at org.serviio.library.dao.MediaItemDAOImpl.getMediaItem(MediaItemDAOImpl.java:78)
2013-04-14 00:27:52,970 WARN  [LibraryAdditionsCheckerThread] Cannot add file The.Walking.Dead.S03E14.1080p.WEB.DL.AAC2.0.H.264.Cyphanix.mkv because of an unexpected error. Message: null
2013-04-14 00:27:52,971 WARN  [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
2013-04-14 00:27:54,972 WARN  [LibraryAdditionsCheckerThread] Cannot add file The.Walking.Dead.S03E15.1080p.WEB-DL.AAC2.0.H.264-Cyphanix.mkv because of an unexpected error. Message: null
2013-04-14 00:27:54,973 WARN  [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
2013-04-14 00:27:56,974 WARN  [LibraryAdditionsCheckerThread] Cannot add file The.Walking.Dead.S03E16.1080p.WEB-DL.AAC2.0.H264-Cyphanix.mkv because of an unexpected error. Message: null
2013-04-14 00:27:56,975 WARN  [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
2013-04-14 00:27:58,980 WARN  [LibraryAdditionsCheckerThread] Cannot add file Without.A.Paddle.2004.720p.BluRay.x264-SiNNERS.mkv because of an unexpected error. Message: null
2013-04-14 00:27:58,980 WARN  [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
   at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:166)
   at org.serviio.library.local.service.RepositoryService.markRepositoryAsScanned(RepositoryService.java:112)
   at org.serviio.library.local.metadata.LibraryAdditionsCheckerThread.run(LibraryAdditionsCheckerThread.java:84)
2013-04-14 00:28:00,982 WARN  [LibraryAdditionsCheckerThread] An error occured while scanning for item to be added, will continue
   at org.serviio.library.dao.RepositoryDAOImpl.markRepositoryAsScanned(RepositoryDAOImpl.java:167)
2013-04-14 00:30:39,618 WARN  [DBConnectionPool] Can't create a new connection for jdbc:derby:db;create=true
   at org.serviio.library.dao.PlaylistDAOImpl.findAll(PlaylistDAOImpl.java:239)
   at org.serviio.library.local.service.PlaylistService.getAllPlaylists(PlaylistService.java:46)
   at org.serviio.library.local.metadata.PlaylistMaintainerThread.run(PlaylistMaintainerThread.java:72)
2013-04-14 00:31:04,439 INFO  [LibraryAdditionsCheckerThread] Finished looking for newly added files
2013-04-14 00:31:04,538 INFO  [LibraryUpdatesCheckerThread] Finished looking for updates to currently shared files
2013-04-14 00:31:04,639 INFO  [PluginCompilerThread] Finished looking for plugins
2013-04-14 00:31:04,743 INFO  [WebServer] WebServer shutting down
2013-04-14 00:31:04,743 INFO  [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-04-14 00:31:04,744 INFO  [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-04-14 00:31:04,744 INFO  [EventDispatcher] Leaving EventDispatcher
2013-04-14 00:31:04,744 INFO  [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-04-14 00:31:04,749 INFO  [DatabaseManager] Shutting down database
2013-04-14 00:31:04,750 INFO  [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
Thanks in advance!
slyguy42o
Post Sun Apr 14, 2013 2:24 am
Re: An unexpected error occurred (500). Check the log.
i think something might be wrong with java, can you try removing and reinstalling it?
Post Mon Apr 15, 2013 12:33 pm
Looks like your installation is broken, possibly access rights. It can't find the .jar files under lib folder. Check those or reinstall.
DangeR
Post Wed Apr 17, 2013 7:29 am
Thanks. I've reinstalled java and looks like the error disappeared but sometimes when i power on the macbook serviio doesn't autostart and i have to open the console and type
"# sudo launchctl load /Library/LaunchDaemons/org.serviio.server.plist"
Any ideea what can i do so that Serviio to start ALWAYS :) ? Thank you in advance.
DangeR
Post Tue Apr 23, 2013 1:20 pm
Nobody?
slyguy42o
Post Tue Apr 23, 2013 2:50 pm
did you go through the guide on how to auto start serviio on your mac?
DangeR
Post Wed Apr 24, 2013 3:05 pm
Of course! It's already set...
Mica
Post Sat Oct 19, 2013 12:19 am
When I got this error I found that it was a permissions problem (Ubuntu Box)
I made sure that the files contained in the library sub directory were writeable by the serviio user and this solved the issue.
The symptom that was fixed with this change was inability to save settings in the serviio console.
HTH
Mica
