Serviio can't find my HT-C5900
st2430
Post Sun Jan 30, 2011 1:18 pm
I'm trying out Serviio but can't get it to connect to my Samsung HT-C5900 BD player. I'm using a fixed IP address for the player. The console status field shows a yellow dot. I've tried refresh and server restarts with no success. The firewall ports 8895 and 1900 are open on my Windows XP SP3 system. Any hints what to try next?
Post Sun Jan 30, 2011 1:31 pm
Re: Serviio can't find my HT-C5900
try pluging pc directly to the tv and see if it works then.
st2430
Post Sun Jan 30, 2011 1:42 pm
Sorry, can't do that as they are not close to each other. They communicate via wifi.
Post Sun Jan 30, 2011 1:47 pm
and there in could lie your issue, check your router is configured correctly and that there is good signal strengh
Post Sun Jan 30, 2011 4:35 pm
Yellow dot is weird, as this device should respond to the UPnP search and therefore should be either green or red (active/inactive). Yellow dot is for devices that don't support this.
Can you see the player in DeviceSpy?
tomhoh
Post Wed Feb 02, 2011 12:21 am
I am having the same issue. My samsung LN52a750 was working great with 0.4 but appears with a yellow dot in serviio console. My TV does not see the server either. It does however see the 0.4 server. The TV is using a fixed IP address that I must enter into serviio 0.5 as it does not find it automatically. It does manage to find my sony bravia and works as expected.
Post Wed Feb 02, 2011 12:29 am
Does the Samsung show in Intel's DeviceSpy?
tomhoh
Post Wed Feb 02, 2011 1:20 am
It does not show up in devicespy
tomhoh
Post Wed Feb 02, 2011 1:54 am
OK when I ran DeviceSpy I realized that I have another instance of serviio (0.4) on another system. Now serviio 0.5 shows up and works as expected. However, the console shows a yellow dot for the tv.
Post Wed Feb 02, 2011 9:57 am
tomhoh wrote:However, the console shows a yellow dot for the tv.
Thats is correct. Yellow means it cannot decide whether it's on or off as it doesn't support the functionality (as proved by it not showing in DeviceSpy)
