Selecting different audio streams (languages)
TM2002
Post Sun May 26, 2013 1:40 pm
Re: Selecting different audio streams (languages)
remove and reselect folders in library!
MarkusW
Post Sun Jul 20, 2014 8:44 pm
Hi everyone!
Serviio is great, but unfortunately the feature of allowing audio track selection on the TV is still not implemented.
I have played around a little bit with the Windows ffmpeg wrapper, but it did not work perfectly for me.
However, I have realized now, that all that is needed to be changed, is the command "-map 0:1" (where the 1 stands for the first audio track).
By changing it to "-map 0:a", ALL audio tracks are automatically included, so that one can switch the audio track with the TV!
I would really appreciate this feature a lot! I guess, that the "-map 0:a" option should also work for TVs, that dont allow audio track selection. (I suppose they will just use the first audio track - like before).
So this could be really easy and quick to implement. It would maybe be just one letter.
Post Mon Jul 21, 2014 12:44 pm
MarkusW wrote:Hi everyone!
Welcome Markus!
If your files don't require transcoding most players allow selecting different audio channels. I have no experience with this with a TV, as most of my devices are separate, and my Panasonic is too old to play what I have without transcoding. You do bring up an interesting possibility, and the best place to bring this up would be in the Feature Request sub-forum. Serviio also uses Bitbucket for feature requests, http://wiki.serviio.org/doku.php?id=bitbucket
MarkusW
Post Sat Aug 02, 2014 8:28 pm
Ok, I have posted the issue now in the feature request board, as suggested.
I know already about the ticket system - in fact I have read about the -map 0:a command there at first ;) (it is in the comments of a similar ticket)
ehcapnamor
Post Wed May 13, 2015 12:50 pm
Here's a UI mockup I put together in mspaint to visualise what I'm suggesting:
Hello !
Where did you find these options ? ^^
Under the "Transcoding" tab, in video settings, I only have "Produce the best video quality" option and "Audio channels" (Keep Original/Downmix to stereo).
I would like to force the french "audio stream" on my movies but I can't figure out how ^^
Thanks a lot !
Post Wed May 13, 2015 3:33 pm
it's still on open ticket not implemented yet, vote for this feature if you want it.
Previous
