1 file works, 2 doesn't... same codec and profile
CarlosC
Post Tue Oct 11, 2011 12:35 am
Here's a weird one. From the Matrix trilogy, only the 1st one is working even though the 3 of them have the same properties:
Working:
Unique ID                        : 187041213802133635042493551974511623682 (0x8CB6D3D3BCC6B6F7851A65A5493D3E02)
Complete name                    : D:\Películas\The Matrix\The Matrix\The Matrix.mkv
Format                           : Matroska
File size                        : 7.34 GiB
Duration                         : 2h 16mn
Overall bit rate                 : 7 706 Kbps
Movie name                       : The Matrix 1080p (DVXA/BD9)
Encoded date                     : UTC 2009-03-05 00:03:46
Writing application              : mkvmerge v2.4.2 ('Oh My God') built on Jan 18 2009 17:30:28
Writing library                  : libebml v0.7.7 + libmatroska v0.8.1
Format profile                   : High@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 3 frames
Format settings, GOP             : M=1, N=48
Codec ID                         : V_MPEG4/ISO/AVC
Duration                         : 2h 16mn
Bit rate mode                    : Variable
Bit rate                         : 6 350 Kbps
Maximum bit rate                 : 15.0 Mbps
Width                            : 1 920 pixels
Height                           : 1 080 pixels
Frame rate                       : 23.976 fps
Bits/(Pixel*Frame)               : 0.128
Stream size                      : 5.91 GiB (81%)
Title                            : English 1080p (AVC 6.35 Mbps)
Writing library                  : x264 core 66 r1093M 1df50b9
Encoding settings                : cabac=1 / ref=3 / deblock=1:-1:-1 / analyse=0x3:0x113 / me=hex / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=48 / keyint_min=4 / scenecut=40(pre) / rc=2pass / bitrate=6350 / ratetol=1.0 / qcomp=0.50 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=15000 / vbv_bufsize=15000 / ip_ratio=1.10 / pb_ratio=1.20 / aq=1:1.00
Language                         : English
Audio #1
Format                           : AC-3
Format/Info                      : Audio Coding 3
Mode extension                   : CM (complete main)
Codec ID                         : A_AC3
Duration                         : 2h 16mn
Bit rate                         : 640 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Side: L R, LFE
Bit depth                        : 16 bits
Stream size                      : 624 MiB (8%)
Title                            : English Dolby Digital 5.1 (AC3 640 Kbps)
Language                         : English
Audio #2
Format                           : AC-3
Format profile                   : Dolby Digital
Codec ID                         : A_AC3
Duration                         : 2h 16mn
Bit rate                         : 192 Kbps
Channel(s)                       : 2 channels
Channel positions                : Front: L R
Bit depth                        : 16 bits
Stream size                      : 187 MiB (2%)
Title                            : Español Dolby Surround 2.0 (AC3 192 Kbps)
Language                         : Spanish
Audio #3
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 2h 16mn
Bit rate                         : 128 Kbps
Bit depth                        : 16 bits
Stream size                      : 125 MiB (2%)
Title                            : English Editor's Comments 2.0 (AC3 128 Kbps)
Language                         : English
Audio #4
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 2h 16mn
Bit rate                         : 128 Kbps
Bit depth                        : 16 bits
Title                            : English Composer's Comments 2.0 (AC3 128 Kbps)
Language                         : English
Audio #5
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 2h 16mn
Bit rate                         : 128 Kbps
Bit depth                        : 16 bits
Title                            : English Critics's Comments 2.0 (AC3 128 Kbps)
Language                         : English
Audio #6
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 2h 16mn
Bit rate                         : 128 Kbps
Bit depth                        : 16 bits
Title                            : English Philosophers's Comments 2.0 (AC3 128 Kbps)
Language                         : English
Text #1
Format                           : UTF-8
Codec ID                         : S_TEXT/UTF8
Codec ID/Info                    : UTF-8 Plain Text
Title                            : English (Text)
Language                         : English
Text #2
Format                           : UTF-8
Title                            : Español (Texto)
Language                         : Spanish
Text #3
Format                           : VobSub
Muxing mode                      : zlib
Codec ID                         : S_VOBSUB
Codec ID/Info                    : The same subtitle format used on DVDs
Title                            : English (VobSub)
Language                         : English
Text #4
Format                           : VobSub
Muxing mode                      : zlib
Codec ID                         : S_VOBSUB
Title                            : Español (VobSub)
Language                         : Spanish
Text #5
Format                           : VobSub
Muxing mode                      : zlib
Codec ID                         : S_VOBSUB
Title                            : Português (VobSub)
Language                         : Portuguese
Text #6
Format                           : UTF-8
Title                            : None / Ninguno / Nenhum
Language                         : Auxiliary Language Association
Not working:
Unique ID                        : 201286660455911482454460447522457950875 (0x976E6692D1922723BCF92E4651689A9B)
Complete name                    : D:\Películas\The Matrix\The Matrix Reloaded\The Matrix Reloaded.mkv
Format                           : Matroska
Duration                         : 2h 18mn
Overall bit rate                 : 7 600 Kbps
Movie name                       : The Matrix Reloaded 1080p
Encoded date                     : UTC 2009-03-05 19:17:39
Writing application              : mkvmerge v2.5.2 ('Stranger in your Soul') built on Feb 28 2009 18:58:17
Duration                         : 2h 18mn
Bit rate                         : 6 500 Kbps
Bits/(Pixel*Frame)               : 0.131
Stream size                      : 6.14 GiB (84%)
Title                            : English 1080p (AVC 6.50 Mbps)
Writing library                  : x264 core 66 r1109M 75b495f
Encoding settings                : cabac=1 / ref=3 / deblock=1:-2:-1 / analyse=0x3:0x113 / me=hex / subme=7 / psy_rd=1.0:0.0 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=3 / b_pyramid=0 / b_adapt=2 / b_bias=0 / direct=3 / wpredb=1 / keyint=48 / keyint_min=4 / scenecut=40(pre) / rc=2pass / bitrate=6500 / ratetol=1.0 / qcomp=0.50 / qpmin=10 / qpmax=40 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=15000 / vbv_bufsize=15000 / ip_ratio=1.10 / pb_ratio=1.20 / aq=1:1.00
Language                         : English
Audio #1
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 2h 18mn
Bit rate                         : 640 Kbps
Bit depth                        : 16 bits
Stream size                      : 633 MiB (8%)
Language                         : English
Audio #2
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 2h 18mn
Bit rate                         : 192 Kbps
Bit depth                        : 16 bits
Stream size                      : 190 MiB (3%)
Language                         : Spanish
Audio #3
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 2h 18mn
Bit rate                         : 128 Kbps
Bit depth                        : 16 bits
Stream size                      : 127 MiB (2%)
Language                         : English
Audio #4
Format                           : AC-3
Codec ID                         : A_AC3
Duration                         : 2h 18mn
Bit rate                         : 128 Kbps
Bit depth                        : 16 bits
Language                         : English
Text #1
Format                           : UTF-8
Language                         : English
Text #2
Format                           : UTF-8
Language                         : Spanish
Text #3
Format                           : VobSub
Muxing mode                      : zlib
Codec ID                         : S_VOBSUB
Language                         : English
Text #4
Format                           : VobSub
Muxing mode                      : zlib
Codec ID                         : S_VOBSUB
Language                         : Spanish
Text #5
Format                           : VobSub
Muxing mode                      : zlib
Codec ID                         : S_VOBSUB
Text #6
Format                           : UTF-8
Any tips?
Player is Sony BDP-S570
Edit: here's some fmmpeg -i for both files:
Working:
C:\Program Files (x86)\Serviio\lib>ffmpeg.exe -i "d:\Películas\The Matrix\The Ma
trix\The Matrix.mkv"
nfig
[matroska,webm @ 014a8b80] max_analyze_duration 5000000 reached at 5024000
[matroska,webm @ 014a8b80] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (200000
00/417083) -> 23.98 (24000/1001)
Input #0, matroska,webm, from 'd:\Películas\The Matrix\The Matrix\The Matrix.mk
v':
    title           : The Matrix 1080p (DVXA/BD9)
  Duration: 02:16:17.87, start: 0.000000, bitrate: 1344 kb/s
    Stream #0.0(eng): Video: h264 (High), yuv420p, 1920x1080, PAR 1:1 DAR 16:9,
23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc (default)
      title           : English 1080p (AVC 6.35 Mbps)
    Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 640 kb/s (default)
      title           : English Dolby Digital 5.1 (AC3 640 Kbps)
    Stream #0.2(spa): Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
      title           : Espa├▒ol Dolby Surround 2.0 (AC3 192 Kbps)
    Stream #0.3(eng): Audio: ac3, 48000 Hz, stereo, s16, 128 kb/s
      title           : English Editor's Comments 2.0 (AC3 128 Kbps)
    Stream #0.4(eng): Audio: ac3, 48000 Hz, stereo, s16, 128 kb/s
      title           : English Composer's Comments 2.0 (AC3 128 Kbps)
    Stream #0.5(eng): Audio: ac3, 48000 Hz, stereo, s16, 128 kb/s
      title           : English Critics's Comments 2.0 (AC3 128 Kbps)
    Stream #0.6(eng): Audio: ac3, 48000 Hz, stereo, s16, 128 kb/s
      title           : English Philosophers's Comments 2.0 (AC3 128 Kbps)
    Stream #0.7(eng): Subtitle: [0][0][0][0] / 0x0000
      title           : English (Text)
    Stream #0.8(spa): Subtitle: [0][0][0][0] / 0x0000
      title           : Espa├▒ol (Texto)
    Stream #0.9(eng): Subtitle: dvdsub
      title           : English (VobSub)
    Stream #0.10(spa): Subtitle: dvdsub
      title           : Espa├▒ol (VobSub)
    Stream #0.11(por): Subtitle: dvdsub
      title           : Portugu├¬s (VobSub)
    Stream #0.12(ina): Subtitle: [0][0][0][0] / 0x0000 (default)
      title           : None / Ninguno / Nenhum
Not working:
trix Reloaded\The Matrix Reloaded.mkv"
nfig
[matroska,webm @ 012c8be0] Invalid stream 11 or size 3
[matroska,webm @ 012c8be0] Could not find codec parameters (Video: h264, 1920x10
80)
[matroska,webm @ 012c8be0] Could not find codec parameters (Audio: ac3, 0 channe
ls, s16)
    Last message repeated 3 times
[matroska,webm @ 012c8be0] Estimating duration from bitrate, this may be inaccur
ate
Seems stream 0 codec frame rate differs from container frame rate: 47.95 (48000/
1001) -> 23.98 (48000/2002)
Input #0, matroska,webm, from 'd:\Películas\The Matrix\The Matrix Reloaded\The
Matrix Reloaded.mkv':
    title           : The Matrix Reloaded 1080p
  Duration: 02:18:15.45, start: 0.000000, bitrate: N/A
    Stream #0.0(eng): Video: h264, 1920x1080, PAR 1:1 DAR 16:9, 23.98 fps, 23.98
      title           : English 1080p (AVC 6.50 Mbps)
    Stream #0.1(eng): Audio: ac3, 0 channels, s16 (default)
    Stream #0.2(spa): Audio: ac3, 0 channels, s16
    Stream #0.3(eng): Audio: ac3, 0 channels, s16
    Stream #0.4(eng): Audio: ac3, 0 channels, s16
    Stream #0.5(eng): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.6(spa): Subtitle: [0][0][0][0] / 0x0000
    Stream #0.7(eng): Subtitle: dvdsub
    Stream #0.8(spa): Subtitle: dvdsub
    Stream #0.9(por): Subtitle: dvdsub
    Stream #0.10(ina): Subtitle: [0][0][0][0] / 0x0000 (default)
Post Tue Oct 11, 2011 7:23 am
Re: 1 file works, 2 doesn't... same codec and profile
this would seem to be either a corrupt file of the fact that it has way to many resources in it and FFmpeg is gettign confused.
Post Tue Oct 11, 2011 7:50 am
CarlosC wrote:...the 3 of them have the same properties
Not 100% same properties:
Working:
Encoding settings                : deblock=1:-1:-1
Not working:
Encoding settings                : deblock=1:-2:-1
But, not sure this is the reason.
As Cerberus, I suggest to remux into m2ts with TsMuxer, or into mkv with mkvmerge by removing extra audio track or subtitles, unnecessary things.
CarlosC
Post Tue Oct 11, 2011 1:14 pm
I did that. I removed some audio tracks and some subtitle tracks, remuxed it with mkvtoolnix and it's working now :D
Weird.
