Unreadable files?
sam_1421
Post Fri Mar 09, 2012 6:19 am
Unreadable files?
I'm using Serviio on my Sony BDP-S850 and it works pretty good so far with a little tweaking, but there are still some files I can't play ... I have for example this mkv that cannot play, but another one pretty similar will play perfectly (both are OK on my computer). Here are the two files mediainfo:
This one doesn't work :
Unique ID                                : 189543998283447271388424701117282494222 (0x8E98D8A10A9BF0A8A55A52A6F545A70E)
Complete name                            : L:\Movies\Blockbusters\HD\300 (2006).mkv
Format version                           : Version 1
File size                                : 4.37 GiB
Duration                                 : 1h 56mn
Overall bit rate                         : 5 371 Kbps
Movie name                               : 300 hd dvd rip (x264;ac3 vo+vf;srt vo+vf)-by team  GAÏA-for hdfrench
Encoded date                             : UTC 2007-07-26 05:38:52
Writing application                      : mkvmerge v2.0.2 ('You're My Flame') built on Feb 21 2007 23:40:55
Writing library                          : libebml v0.7.7 + libmatroska v0.8.1
Format profile                           : High@L5.1
Format settings, ReFrames                : 11 frames
Duration                                 : 1h 56mn
Bit rate                                 : 4 088 Kbps
Bits/(Pixel*Frame)                       : 0.185
Stream size                              : 3.24 GiB (74%)
Title                                    : x264 720p
Writing library                          : x264 core 56 svn-667C
Encoding settings                        : cabac=1 / ref=8 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=6 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=21,11 / chroma_qp_offset=0 / threads=3 / nr=0 / decimate=0 / mbaff=0 / bframes=3 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=4088 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.3:15.0
Language                                 : French
This one does:
Unique ID                                : 212726359333165641035903355314150223331 (0xA0099B4634F76E44ABB0E35FDC2EADE3)
Complete name                            : L:\Movies\Blockbusters\HD\Kingdom of Heaven (2005).mkv
File size                                : 7.95 GiB
Duration                                 : 3h 9mn
Overall bit rate                         : 6 004 Kbps
Encoded date                             : UTC 2009-01-30 01:23:03
Writing application                      : mkvmerge v2.4.2 ('Oh My God') built on Jan 18 2009 17:30:28
Format profile                           : Main@L3.1
Format settings, ReFrames                : 1 frame
Duration                                 : 3h 9mn
Bit rate                                 : 5 360 Kbps
Frame rate                               : 24.000 fps
Bits/(Pixel*Frame)                       : 0.242
Stream size                              : 6.94 GiB (87%)
Writing library                          : x264 core 66 r1088M 71ac0a3
Encoding settings                        : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=6 / psy_rd=1.0:0.0 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-2 / threads=3 / nr=0 / decimate=1 / mbaff=0 / bframes=0 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=5360 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
What should I edit in my player profile to add support for this file?
Thank you!
Sam
Post Fri Mar 09, 2012 10:52 am
Re: Unreadable files?
sam_1421 wrote:I have for example this mkv that cannot play, but another one pretty similar will play perfectly (both are OK on my computer).
1-Files are not similar, will explain
2-Do not compare your computer (VLC, Windows Media Player) and your Sony device. A computer use software library very permissive, and your device use hardware decoding with very limited format.
sam_1421 wrote:Here are the two files mediainfo:
See following differences
This one does:
The Big difference is the AVC Profile Level:
- 1280x720, 11 Refframe => Profile level 5.1 not supported by the Sony device => must be transcode
- 1280x720, 1 Refframe => Profile level 3.1 supported by the Sony device in native format.
sam_1421 wrote:What should I edit in my player profile to add support for this file?
You don't have to edit the plyaer profile.
The first file should be detected as not compatible AVC Profile level => transcode to MPEG2VIDEO over MPEGTS stream
The second is detected as compatible => delivered in native format.
Could you enable detailed logging file (see signature link) and check if first file is transcoded?
sam_1421
Post Fri Mar 09, 2012 7:36 pm
I enabled it and can confirm the file is delivered in native format. Here is the log section when reading the first file, and the second : http://pastebin.com/RxK26p2Y
Post Fri Mar 09, 2012 9:02 pm
The profile level detection did not work.
Could you remove this file from library, then re-add it, and check the log file?
sam_1421
Post Fri Mar 09, 2012 9:27 pm
I get this in the log file when adding the file again :
2012-03-09 16:20:39,491 DEBUG [LibraryAdditionsCheckerThread] Found file '300 (2006).mkv', checking if it's already in the Library
2012-03-09 16:20:39,491 DEBUG [MediaItemDAOImpl] Checking if DB already contains media item 300 (2006).mkv
2012-03-09 16:20:39,491 DEBUG [MediaItemDAOImpl] Media item 300 (2006).mkv doesn't exist in DB yet
2012-03-09 16:20:39,491 DEBUG [LibraryAdditionsCheckerThread] File not in Library, will add it
2012-03-09 16:20:39,491 DEBUG [VideoExtractionStrategy] Extracting metadata of video file: L:\test2\300 (2006).mkv
2012-03-09 16:20:39,491 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve media information for file: L:\test2\300 (2006).mkv
2012-03-09 16:20:39,491 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i L:\test2\300 (2006).mkv
2012-03-09 16:20:39,528 DEBUG [MediaItemDAOImpl] Getting file of media item 704
2012-03-09 16:20:39,546 DEBUG [FFmpegMetadataRetriever] Retrieving H264 profile/level for file 'L:\test2\300 (2006).mkv'
2012-03-09 16:20:39,546 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve H264 header for file: L:\test2\300 (2006).mkv
2012-03-09 16:20:39,547 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -i L:\test2\300 (2006).mkv -vframes 1 -vcodec copy -f h264 -vbsf h264_mp4toannexb -an pipe:
2012-03-09 16:20:39,578 DEBUG [MediaItemDAOImpl] Getting file of media item 705
2012-03-09 16:20:39,609 DEBUG [FFmpegMetadataRetriever] H264 Level value stored in the AVC header (5.1) is different than one based on ref_frames value (5 will be stored)
2012-03-09 16:20:39,609 DEBUG [FFmpegMetadataRetriever] File 'L:\test2\300 (2006).mkv' has H264 profile HIGH and level 5.1
2012-03-09 16:20:39,609 DEBUG [FFMPEGWrapper] Invoking FFMPEG to retrieve thumbnail for file: L:\test2\300 (2006).mkv
2012-03-09 16:20:39,610 DEBUG [ProcessExecutor] Starting C:\Program Files\Serviio\bin\\..\lib/ffmpeg.exe -ss 120 -i L:\test2\300 (2006).mkv -an -vframes 1 -f image2 pipe:
2012-03-09 16:20:39,628 DEBUG [MediaItemDAOImpl] Getting file of media item 706
2012-03-09 16:20:39,678 DEBUG [MediaItemDAOImpl] Getting file of media item 707
2012-03-09 16:20:39,728 DEBUG [MediaItemDAOImpl] Getting file of media item 708
2012-03-09 16:20:39,778 DEBUG [MediaItemDAOImpl] Getting file of media item 709
2012-03-09 16:20:39,828 DEBUG [MediaItemDAOImpl] Getting file of media item 710
2012-03-09 16:20:39,878 DEBUG [MediaItemDAOImpl] Getting file of media item 711
2012-03-09 16:20:39,928 DEBUG [MediaItemDAOImpl] Getting file of media item 712
2012-03-09 16:20:39,978 DEBUG [MediaItemDAOImpl] Getting file of media item 713
2012-03-09 16:20:40,028 DEBUG [MediaItemDAOImpl] Getting file of media item 714
2012-03-09 16:20:40,079 DEBUG [MediaItemDAOImpl] Getting file of media item 715
2012-03-09 16:20:40,138 DEBUG [MediaItemDAOImpl] Getting file of media item 716
2012-03-09 16:20:40,188 DEBUG [MediaItemDAOImpl] Getting file of media item 717
2012-03-09 16:20:40,238 DEBUG [MediaItemDAOImpl] Getting file of media item 718
2012-03-09 16:20:40,288 DEBUG [MediaItemDAOImpl] Getting file of media item 719
2012-03-09 16:20:40,338 DEBUG [MediaItemDAOImpl] Getting file of media item 720
2012-03-09 16:20:40,388 DEBUG [MediaItemDAOImpl] Getting file of media item 721
2012-03-09 16:20:40,438 DEBUG [MediaItemDAOImpl] Getting file of media item 722
2012-03-09 16:20:40,488 DEBUG [MediaItemDAOImpl] Getting file of media item 723
2012-03-09 16:20:40,538 DEBUG [MediaItemDAOImpl] Getting file of media item 724
2012-03-09 16:20:40,588 DEBUG [MediaItemDAOImpl] Getting file of media item 725
2012-03-09 16:20:40,638 DEBUG [MediaItemDAOImpl] Getting file of media item 726
2012-03-09 16:20:40,688 DEBUG [MediaItemDAOImpl] Getting file of media item 727
2012-03-09 16:20:40,738 DEBUG [MediaItemDAOImpl] Getting file of media item 728
2012-03-09 16:20:40,788 DEBUG [MediaItemDAOImpl] Getting file of media item 729
2012-03-09 16:20:40,838 DEBUG [MediaItemDAOImpl] Getting file of media item 730
2012-03-09 16:20:40,888 DEBUG [MediaItemDAOImpl] Getting file of media item 731
2012-03-09 16:20:40,938 DEBUG [MediaItemDAOImpl] Getting file of media item 732
2012-03-09 16:20:40,990 DEBUG [MediaItemDAOImpl] Getting file of media item 733
2012-03-09 16:20:41,041 DEBUG [MediaItemDAOImpl] Getting file of media item 734
2012-03-09 16:20:41,098 DEBUG [MediaItemDAOImpl] Getting file of media item 735
2012-03-09 16:20:41,149 DEBUG [MediaItemDAOImpl] Getting file of media item 736
2012-03-09 16:20:41,199 DEBUG [MediaItemDAOImpl] Getting file of media item 737
2012-03-09 16:20:41,249 DEBUG [MediaItemDAOImpl] Getting file of media item 738
2012-03-09 16:20:41,299 DEBUG [MediaItemDAOImpl] Getting file of media item 739
2012-03-09 16:20:41,350 DEBUG [MediaItemDAOImpl] Getting file of media item 740
2012-03-09 16:20:41,400 DEBUG [MediaItemDAOImpl] Getting file of media item 741
2012-03-09 16:20:41,450 DEBUG [MediaItemDAOImpl] Getting file of media item 742
2012-03-09 16:20:41,500 DEBUG [MediaItemDAOImpl] Getting file of media item 743
2012-03-09 16:20:41,550 DEBUG [MediaItemDAOImpl] Getting file of media item 744
2012-03-09 16:20:41,554 DEBUG [LibraryManager] Metadata found via extractor EMBEDDED: VideoMetadata [title=300 (2006), filePath=L:\test2\300 (2006).mkv, fileSize=4695315039, audioBitrate=640, audioCodec=AC3, audioStreamIndex=1, bitrate=5371, channels=6, container=MATROSKA, contentType=UNKNOWN, coverImage=org.serviio.library.local.metadata.ImageDescriptor@66b1a500, duration=6992, episodeNumber=null, fps=23.976, frequency=48000, h264Level=5.1, h264Profile=HIGH, ftyp=null, height=720, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=H264, videoStreamIndex=0, width=1280]
2012-03-09 16:20:41,559 DEBUG [TheMovieDBSourceAdaptor] Searching for movie '300' 2006 (language: en)
2012-03-09 16:20:41,600 DEBUG [MediaItemDAOImpl] Getting file of media item 745
2012-03-09 16:20:41,650 DEBUG [MediaItemDAOImpl] Getting file of media item 746
2012-03-09 16:20:41,669 DEBUG [TheMovieDBSourceAdaptor] Found 1 matches
2012-03-09 16:20:41,672 DEBUG [TheMovieDBSourceAdaptor] Found a suitable movie match, id = 1271
2012-03-09 16:20:41,672 DEBUG [TheMovieDBSourceAdaptor] Retrieving details of movie (movieId = 1271, language = en)
2012-03-09 16:20:41,700 DEBUG [MediaItemDAOImpl] Getting file of media item 747
2012-03-09 16:20:41,750 DEBUG [MediaItemDAOImpl] Getting file of media item 748
2012-03-09 16:20:41,800 DEBUG [MediaItemDAOImpl] Getting file of media item 749
2012-03-09 16:20:41,850 DEBUG [MediaItemDAOImpl] Getting file of media item 750
2012-03-09 16:20:41,900 DEBUG [MediaItemDAOImpl] Getting file of media item 751
2012-03-09 16:20:41,950 DEBUG [MediaItemDAOImpl] Getting file of media item 752
2012-03-09 16:20:42,000 DEBUG [MediaItemDAOImpl] Getting file of media item 753
2012-03-09 16:20:42,050 DEBUG [MediaItemDAOImpl] Getting file of media item 754
2012-03-09 16:20:42,100 DEBUG [MediaItemDAOImpl] Getting file of media item 755
2012-03-09 16:20:42,150 DEBUG [MediaItemDAOImpl] Getting file of media item 756
2012-03-09 16:20:42,200 DEBUG [MediaItemDAOImpl] Getting file of media item 757
2012-03-09 16:20:42,221 DEBUG [TheMovieDBSourceAdaptor] Retrieved poster: http://cf2.imgobject.com/t/p/w185/z6hyEVenS957hIbaxIM4tQ6kGsT.jpg
2012-03-09 16:20:42,221 DEBUG [LibraryManager] Metadata found via extractor ONLINE_VIDEO_SOURCES: VideoMetadata [title=300, filePath=null, fileSize=0, audioBitrate=null, audioCodec=null, audioStreamIndex=null, bitrate=null, channels=null, container=null, contentType=MOVIE, coverImage=org.serviio.library.local.metadata.ImageDescriptor@4691fd4c, duration=null, episodeNumber=null, fps=null, frequency=null, h264Level=null, h264Profile=null, ftyp=null, height=null, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=null, videoStreamIndex=null, width=null]
2012-03-09 16:20:42,222 DEBUG [VideoService] Adding video into database: 300
2012-03-09 16:20:42,234 DEBUG [GenreDAOImpl] Reading a Genre (name = Fantasy)
2012-03-09 16:20:42,239 DEBUG [GenreService] Genre Fantasy found
2012-03-09 16:20:42,239 DEBUG [CoverImageService] Resizing and storing cover art image
2012-03-09 16:20:42,240 DEBUG [ImageUtils] Starting image resize, size = 32684 bytes
2012-03-09 16:20:42,250 DEBUG [MediaItemDAOImpl] Getting file of media item 758
2012-03-09 16:20:42,301 DEBUG [MediaItemDAOImpl] Getting file of media item 759
2012-03-09 16:20:42,305 DEBUG [ImageUtils] Returning resized image, size = 6860 bytes
2012-03-09 16:20:42,305 DEBUG [CoverImageService] Image successfully resized
2012-03-09 16:20:42,305 DEBUG [CoverImageDAOImpl] Creating a new ImageCover (length = 6860)
2012-03-09 16:20:42,313 DEBUG [VideoDAOImpl] Creating a new Video (title = 300)
2012-03-09 16:20:42,335 DEBUG [PersonDAOImpl] Adding a Person Zack Snyder to media item 1880 as DIRECTOR
2012-03-09 16:20:42,335 DEBUG [PersonDAOImpl] Reading a Person (name = Zack Snyder)
2012-03-09 16:20:42,341 DEBUG [PersonDAOImpl] Checking if person 352 has a role DIRECTOR for media item 1880
2012-03-09 16:20:42,352 DEBUG [MediaItemDAOImpl] Getting file of media item 760
2012-03-09 16:20:42,355 DEBUG [PersonDAOImpl] Adding a Person Gianni Nunnari to media item 1880 as PRODUCER
2012-03-09 16:20:42,355 DEBUG [PersonDAOImpl] Reading a Person (name = Gianni Nunnari)
2012-03-09 16:20:42,356 DEBUG [PersonDAOImpl] Creating a new Person (name = Gianni Nunnari)
2012-03-09 16:20:42,360 DEBUG [PersonDAOImpl] Checking if person 3802 has a role PRODUCER for media item 1880
2012-03-09 16:20:42,362 DEBUG [PersonDAOImpl] Adding a Person Gerard Butler to media item 1880 as ACTOR
2012-03-09 16:20:42,362 DEBUG [PersonDAOImpl] Reading a Person (name = Gerard Butler)
2012-03-09 16:20:42,362 DEBUG [PersonDAOImpl] Checking if person 330 has a role ACTOR for media item 1880
2012-03-09 16:20:42,364 DEBUG [PersonDAOImpl] Adding a Person Lena Headey to media item 1880 as ACTOR
2012-03-09 16:20:42,364 DEBUG [PersonDAOImpl] Reading a Person (name = Lena Headey)
2012-03-09 16:20:42,364 DEBUG [PersonDAOImpl] Checking if person 354 has a role ACTOR for media item 1880
2012-03-09 16:20:42,367 DEBUG [PersonDAOImpl] Adding a Person David Wenham to media item 1880 as ACTOR
2012-03-09 16:20:42,367 DEBUG [PersonDAOImpl] Reading a Person (name = David Wenham)
2012-03-09 16:20:42,367 DEBUG [PersonDAOImpl] Checking if person 355 has a role ACTOR for media item 1880
2012-03-09 16:20:42,369 DEBUG [PersonDAOImpl] Adding a Person Dominic West to media item 1880 as ACTOR
2012-03-09 16:20:42,369 DEBUG [PersonDAOImpl] Reading a Person (name = Dominic West)
2012-03-09 16:20:42,370 DEBUG [PersonDAOImpl] Checking if person 356 has a role ACTOR for media item 1880
2012-03-09 16:20:42,372 DEBUG [PersonDAOImpl] Adding a Person Michael Fassbender to media item 1880 as ACTOR
2012-03-09 16:20:42,372 DEBUG [PersonDAOImpl] Reading a Person (name = Michael Fassbender)
2012-03-09 16:20:42,372 DEBUG [PersonDAOImpl] Checking if person 357 has a role ACTOR for media item 1880
2012-03-09 16:20:42,374 DEBUG [PersonDAOImpl] Adding a Person Vincent Regan to media item 1880 as ACTOR
2012-03-09 16:20:42,374 DEBUG [PersonDAOImpl] Reading a Person (name = Vincent Regan)
2012-03-09 16:20:42,374 DEBUG [PersonDAOImpl] Creating a new Person (name = Vincent Regan)
2012-03-09 16:20:42,376 DEBUG [PersonDAOImpl] Checking if person 3803 has a role ACTOR for media item 1880
2012-03-09 16:20:42,377 DEBUG [PersonDAOImpl] Adding a Person Rodrigo Santoro to media item 1880 as ACTOR
2012-03-09 16:20:42,378 DEBUG [PersonDAOImpl] Reading a Person (name = Rodrigo Santoro)
2012-03-09 16:20:42,378 DEBUG [PersonDAOImpl] Checking if person 148 has a role ACTOR for media item 1880
2012-03-09 16:20:42,380 DEBUG [PersonDAOImpl] Adding a Person Andrew Tiernan to media item 1880 as ACTOR
2012-03-09 16:20:42,380 DEBUG [PersonDAOImpl] Reading a Person (name = Andrew Tiernan)
2012-03-09 16:20:42,380 DEBUG [PersonDAOImpl] Creating a new Person (name = Andrew Tiernan)
2012-03-09 16:20:42,382 DEBUG [PersonDAOImpl] Checking if person 3804 has a role ACTOR for media item 1880
2012-03-09 16:20:42,384 DEBUG [PersonDAOImpl] Adding a Person Andrew Pleavin to media item 1880 as ACTOR
2012-03-09 16:20:42,384 DEBUG [PersonDAOImpl] Reading a Person (name = Andrew Pleavin)
2012-03-09 16:20:42,384 DEBUG [PersonDAOImpl] Creating a new Person (name = Andrew Pleavin)
2012-03-09 16:20:42,385 DEBUG [PersonDAOImpl] Checking if person 3805 has a role ACTOR for media item 1880
2012-03-09 16:20:42,387 DEBUG [PersonDAOImpl] Adding a Person Tom Wisdom to media item 1880 as ACTOR
2012-03-09 16:20:42,387 DEBUG [PersonDAOImpl] Reading a Person (name = Tom Wisdom)
2012-03-09 16:20:42,387 DEBUG [PersonDAOImpl] Creating a new Person (name = Tom Wisdom)
2012-03-09 16:20:42,389 DEBUG [PersonDAOImpl] Checking if person 3806 has a role ACTOR for media item 1880
2012-03-09 16:20:42,391 DEBUG [PersonDAOImpl] Adding a Person Giovani Cimmino to media item 1880 as ACTOR
2012-03-09 16:20:42,391 DEBUG [PersonDAOImpl] Reading a Person (name = Giovani Cimmino)
2012-03-09 16:20:42,391 DEBUG [PersonDAOImpl] Creating a new Person (name = Giovani Cimmino)
2012-03-09 16:20:42,392 DEBUG [PersonDAOImpl] Checking if person 3807 has a role ACTOR for media item 1880
2012-03-09 16:20:42,394 DEBUG [PersonDAOImpl] Adding a Person Tyler Neitzel to media item 1880 as ACTOR
2012-03-09 16:20:42,394 DEBUG [PersonDAOImpl] Reading a Person (name = Tyler Neitzel)
2012-03-09 16:20:42,395 DEBUG [PersonDAOImpl] Creating a new Person (name = Tyler Neitzel)
2012-03-09 16:20:42,397 DEBUG [PersonDAOImpl] Checking if person 3808 has a role ACTOR for media item 1880
2012-03-09 16:20:42,399 DEBUG [PersonDAOImpl] Adding a Person Greg Kramer to media item 1880 as ACTOR
2012-03-09 16:20:42,399 DEBUG [PersonDAOImpl] Reading a Person (name = Greg Kramer)
2012-03-09 16:20:42,400 DEBUG [PersonDAOImpl] Creating a new Person (name = Greg Kramer)
2012-03-09 16:20:42,401 DEBUG [PersonDAOImpl] Checking if person 3809 has a role ACTOR for media item 1880
2012-03-09 16:20:42,402 DEBUG [MediaItemDAOImpl] Getting file of media item 761
2012-03-09 16:20:42,404 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = ONLINE_VIDEO_SOURCES, mediaItemId = 1880)
2012-03-09 16:20:42,409 DEBUG [MetadataDescriptorDAOImpl] Creating a new MetadataDescriptor (type = EMBEDDED, mediaItemId = 1880)
2012-03-09 16:20:42,410 INFO  [LibraryAdditionsCheckerThread] Added file '300 (2006).mkv' (title: 300) to Library
Looks like it detected the profile level, but it still doesnt play!
sam_1421
Post Sat Mar 10, 2012 6:08 pm
Don't have any idea? It really looks like the Sony profile is not correct for this profile level
Post Sat Mar 10, 2012 7:36 pm
This file is stored in library with good profile level.
So this file must be transcode to mpeg2video into mpeg2ts stream.
Check the detailed logging file when you start to play this file, and find the ffmpeg command line used.
sam_1421
Post Sat Mar 10, 2012 8:28 pm
2012-03-10 15:18:25,711 DEBUG [WebServer] Incoming connection from /192.168.0.115:56849
2012-03-10 15:18:25,711 DEBUG [ResourceTransportRequestHandler] HEAD /resource/1880/MEDIA_ITEM/MATROSKA$0 HTTP/1.1, headers = [User-Agent: UPnP/1.0 DLNADOC/1.50,Host: 192.168.0.102:8895,Accept: */*,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0",getcontentFeatures.dlna.org: 1]]
2012-03-10 15:18:25,711 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.115
2012-03-10 15:18:25,711 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.115, Profile=Sony BD Player / SMP'
2012-03-10 15:18:25,711 DEBUG [ResourceTransportRequestHandler] Request for resource 1880 and type 'MEDIA_ITEM' received
2012-03-10 15:18:25,711 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1880 (local)
2012-03-10 15:18:25,712 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1880)
2012-03-10 15:18:25,712 DEBUG [VideoDAOImpl] Reading a Video (id = 1880)
2012-03-10 15:18:25,712 DEBUG [VideoDeliveryEngine] Retrieving resource information for item 1880, format MATROSKA and profile Sony BD Player / SMP
2012-03-10 15:18:25,712 DEBUG [ResourceTransportRequestHandler] Sending HEAD response back
2012-03-10 15:18:25,712 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 200 OK, headers = [[Content-Type: video/divx,Content-Length: 4695315039,Date: Sat, 10 Mar 2012 20:18:25 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
2012-03-10 15:18:25,741 DEBUG [ResourceTransportRequestHandler] GET /resource/1880/MEDIA_ITEM/MATROSKA$0 HTTP/1.1, headers = [User-Agent: UPnP/1.0 DLNADOC/1.50,Host: 192.168.0.102:8895,Accept: */*,Range: bytes=0-1023,X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player",X-AV-Client-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0",getcontentFeatures.dlna.org: 1,transferMode.dlna.org: Streaming]]
2012-03-10 15:18:25,741 DEBUG [RendererDAOImpl] Reading a Renderer with ip address 192.168.0.115
2012-03-10 15:18:25,741 DEBUG [ResourceTransportRequestHandler] Resource request accepted. Using client 'IPAddress=/192.168.0.115, Profile=Sony BD Player / SMP'
2012-03-10 15:18:25,742 DEBUG [ResourceTransportRequestHandler] Request for resource 1880 and type 'MEDIA_ITEM' received
2012-03-10 15:18:25,742 DEBUG [MediaResourceRetrievalStrategy] Getting information about media item 1880 (local)
2012-03-10 15:18:25,742 DEBUG [MediaItemDAOImpl] Reading a MediaItem (id = 1880)
2012-03-10 15:18:25,742 DEBUG [VideoDAOImpl] Reading a Video (id = 1880)
2012-03-10 15:18:25,742 DEBUG [VideoDeliveryEngine] Delivering item '1880' for client 'IPAddress=/192.168.0.115, Profile=Sony BD Player / SMP'
2012-03-10 15:18:25,742 DEBUG [VideoDeliveryEngine] Delivering file '300 (2006).mkv' in native format
2012-03-10 15:18:25,742 DEBUG [MediaItemDAOImpl] Getting file of media item 1880
2012-03-10 15:18:25,743 DEBUG [MediaItemDAOImpl] Marking MediaItem (id = 1880) as read
2012-03-10 15:18:25,744 DEBUG [LocalContentCacheDecorator] Cleared cache (local_resetafterplay)
2012-03-10 15:18:25,744 DEBUG [ResourceTransportRequestHandler] Creating stream entity with length: 1024
2012-03-10 15:18:25,744 DEBUG [ResourceTransportRequestHandler] Sending file back
2012-03-10 15:18:25,744 DEBUG [ResourceTransportRequestHandler] HTTP/1.1 206 Partial Content, headers = [[Content-Type: video/divx,Content-Range: bytes 0-1023/4695315039,Content-Length: 1024,Date: Sat, 10 Mar 2012 20:18:25 GMT,Server: Windows 7, UPnP/1.0 DLNADOC/1.50, Serviio/0.6.1,Cache-control: no-cache,contentFeatures.dlna.org: DLNA.ORG_PN=MATROSKA;DLNA.ORG_OP=01;DLNA.ORG_CI=0;DLNA.ORG_FLAGS=01500000000000000000000000000000,transferMode.dlna.org: Streaming]]
This seems to be one exchange between the server and the client. I don't see any ffmpeg command line, but I see the "Delivering file '300 (2006).mkv' in native format" line, which indicates the transcoding doesn't work...
Post Sun Mar 11, 2012 1:32 pm
This file is stored in library as MKV/H264Level=5.1 H264Profile=HIGH/AC3
sam_1421 wrote:2012-03-09 16:20:41,554 DEBUG [LibraryManager] Metadata found via extractor EMBEDDED: VideoMetadata [title=300 (2006), filePath=L:\test2\300 (2006).mkv, fileSize=4695315039, audioBitrate=640, audioCodec=AC3, audioStreamIndex=1, bitrate=5371, channels=6, container=MATROSKA, contentType=UNKNOWN, coverImage=org.serviio.library.local.metadata.ImageDescriptor@66b1a500, duration=6992, episodeNumber=null, fps=23.976, frequency=48000, h264Level=5.1, h264Profile=HIGH, ftyp=null, height=720, seasonNumber=null, seriesName=null, timestampType=null, videoBitrate=null, videoCodec=H264, videoStreamIndex=0, width=1280]
But this file is delivered in native format not supported by your device
sam_1421 wrote:2012-03-10 15:18:25,742 DEBUG [VideoDeliveryEngine] Delivering item '1880' for client 'IPAddress=/192.168.0.115, Profile=Sony BD Player / SMP'
If you look at profiles.xml
<Profile id="10" name="Sony BD Player / SMP" extendsProfileId="1">
         <Video targetContainer="mpegts" targetVCodec="mpeg2video" maxVBitrate="17000" targetACodec="ac3" aBitrate="320">
            <Matches container="matroska" vCodec="h264" profile="high" levelGreaterThan="4.1" />
This file must be transcode to mpegts/mpeg2video/ac3 !!
Is it a serviio BUG ? don't know.
Zip, any idea about that issue ?
Post Mon Mar 12, 2012 5:59 pm
Do you have transcoding enabled in the console?
mdb139
Post Mon Mar 26, 2012 4:10 am
I had a similar issue last night with my Sony BD-S580 -- I had three files that wouldn't play, saying they were unreadable. I was in the process of enabling debug (the only thing in Serviio that I changed) so that I could post some more robust information, but when I tried to play the files a few moments ago, they all played fine. I knew this wasn't an issue with Serviio/compatibility because the files all played fine from a separate instance of Serviio -- I'm moving Serviio to an old Windows XP box that I'm going to dedicate for that purpose. I had tinkered with profiles.xml on my old installation, but comparing between my old and new installations I thought the files should play fine (all were AVC High/4.1 with DCS audio). I was able to play AVC/4.1 with AC3 audio, so I thought it might have something to do with that).
Anyway -- My best guess is that profile detection wasn't working (last night, temporarily) and that the files weren't being transcoded.
As an aside -- I'm trying to optimize this old desktop "Serviio server" as best I can. Will Serviio's ffmpeg processes be detected as foreground "apps" or background services? I'd like Windows to give them as much processing power as they need, since I know I'll need to transcode somewhat frequently.
