[SOLVED] How to work regularly with my Bravia ?
sue27
Post Tue May 08, 2012 3:06 am
I installed Serviio to work with my Sony Bravia 2011 tv (KDL-46HX729)
Watched a movie...works great....
Turn off computer/TV.....next day......
Sony TV does not see Serviio. Serviio appears to see Bravia (green light is on)
I uninstalled and install and it works again...
So my problem is that it works....and then it stops working...
Any ideas?
mdb139
Post Tue May 08, 2012 3:52 am
Problems getting serviio to work regularly with my Bravia
I found that I had a similar problem, albeit intermittently. I gave my PC a static IP and it works much better for me. (I didn't mind doing this bc my Serviio box is a desktop). I think the problem is the Sony device, not Serviio.
Post Tue May 08, 2012 8:25 am
Re: Problems getting serviio to work regularly with my Bravi
Confirm,
I suggest to fix IP address of all your devices (PC with Serviio, Sony, TV, etc).
sue27
Post Tue May 08, 2012 2:13 pm
How do I fix the IP address of all my devices?
I use http://unblock-us.com/ on both my PC and Sony Bravia if that makes a difference.
Thanks again
Post Tue May 08, 2012 3:11 pm
sue27 wrote:How do I fix the IP address of all my devices?
On a network, a server/rooter can automatically assign a IP address for all devices connected to the same network.
But if you restart a device, a new ip address can be assign, and you can lose serviio connection.
And for debugging its more easy to have a fix/static IP address for each devices (192.168.1.1(rooter), 192.168.1.2 (PC/Serviio),192.168.1.3(TV1); 192.168.1.4(TV2),192.168.1.5(Printer),etc)
sue27 wrote:I use http://unblock-us.com/ on both my PC and Sony Bravia if that makes a difference.
Not sure to anderstand...
sue27
Post Thu May 10, 2012 7:17 am
Just to be clear I understand, do you recommend I do this?
http://www.dummies.com/how-to/content/h ... ndows.html
Thanks for your help!!
Post Thu May 10, 2012 7:26 am
Yes
patters
Post Thu May 10, 2012 11:51 am
You may find that your broadband router allows you to tick a box to reserve addresses for each device in your home once they're connected. That's how I do it, then you can leave them all on DHCP (automatic settings). Setting them manually in the OS can be a pain if it's a laptop and you intend to use it elsewhere.
sue27
Post Wed May 16, 2012 4:05 am
Thanks to everyone that replied.
I created a static IP on my computer and serviio is working now on my Sony Bravia.
Thanks again.
sue27
Post Fri May 18, 2012 3:07 pm
Re: [SOLVED] How to work regularly with my Bravia ?
Posted deleted. Will post details (log file) in new post.
Post Sun May 20, 2012 3:25 pm
Problem did not come from Sony or Serviio, but from your network configuration.
