[SOLVED] BDP-S590 not showing up in Serviio Console Status
bzserviio
Post Fri Mar 01, 2013 1:47 am
I have BDP-S590 at 192.168.1.3 and wireless MAC 00:a0:96:e4:df:0b with firmware M12.R.0430 which can stream from netflix fine (so network connectivity)
I have PC at 192.168.1.4 which can ping BDP-S590 via wireless
In wireshark, I see somewhat malformed ethernet broadcast from BDP-S590 to ethernet 01:00:5e:7f:ff:fa which I believe is a broadcast address
The type is IP (0x0800) but the IP version is 0? length 0?
However, the actual package content (based on ethernet frame length?) looks like SSDP
NOTIFY * HTTP/1.1
HOST: 239.255.255.250:1900
CACHE-CONTROL: max-age=1800
NT: upnp:rootdevice
NTS: ssdp:alive
SERVER: Linux/2.6 UPnP/1.0 Sony-BDP/2.0
USN: uuid:00000000-0000-1010-8000-5453edd6a2df::upnp:rootdevice
X-AV-Physical-Unit-Info: pa="Blu-ray Disc Player";
X-AV-Server-Info: av=5.0; cn="Sony Corporation"; mn="Blu-ray Disc Player"; mv="2.0";
This never seems to reach serviio (see log below - don't see any response to it's multicast which I also seen in wireshark).
Tried turning off windows firewall (in addition to making sure TCP / UDP are open for serviio first).
I searched this forum and found people with working S590 but this really looks like S590 firmware is broken.
I also have not been able to get xbmc working.
Has anyone seen this or found a workaround?
2013-02-28 18:47:30,879 INFO [MediaServer] ------------------------------------------------------------------------
2013-02-28 18:47:30,880 INFO [MediaServer] Serviio DLNA media streaming server v 1.1 (rev. 6ba0dd933a8e+)
2013-02-28 18:47:30,880 INFO [MediaServer] Petr Nejedly 2009-2012
2013-02-28 18:47:30,880 INFO [MediaServer] http://www.serviio.org
2013-02-28 18:47:30,880 INFO [MediaServer] Java 1.7.0_05-Oracle Corporation
2013-02-28 18:47:30,880 INFO [MediaServer] OS Windows Vista x86 6.0
2013-02-28 18:47:30,880 INFO [MediaServer] File encoding: windows-1252
2013-02-28 18:47:30,881 INFO [MediaServer] Headless mode enabled: true
2013-02-28 18:47:30,881 INFO [MediaServer] User: OWNER-PC$
2013-02-28 18:47:30,881 INFO [MediaServer] User home dir: C:\Windows\System32\config\systemprofile
2013-02-28 18:47:30,881 INFO [MediaServer] Temp dir: C:\Windows\TEMP\
2013-02-28 18:47:30,881 INFO [MediaServer] ------------------------------------------------------------------------
2013-02-28 18:47:31,043 INFO [WebServer] Socket buffer set to 65535 bytes
2013-02-28 18:47:31,045 INFO [RestletServer] Starting Restlet server (/rest) exposed on port 23423
2013-02-28 18:47:31,092 INFO [RestletServer] Starting Restlet server (/cds) exposed on port 23424
2013-02-28 18:47:31,092 INFO [RestletServer] Starting Restlet server (/mediabrowser) exposed on port 23424
2013-02-28 18:47:31,108 INFO [DBSchemaUpdateExecutor] Checking if DB schema needs to be updated
2013-02-28 18:47:35,667 INFO [MediaServer] ------------------------------------------------------------------------
2013-02-28 18:47:35,667 INFO [MediaServer] License: PRO (EVALUATION, id: 11111111-1111-1111-1111-111111111113)
2013-02-28 18:47:35,898 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-02-28 18:47:36,671 INFO [ProfilesDefinitionParser] Added profile 'Generic DLNA profile' (id=1)
2013-02-28 18:47:37,286 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (B-series)' (id=2)
2013-02-28 18:47:37,636 INFO [ProfilesDefinitionParser] Added profile 'Xbox 360' (id=3)
2013-02-28 18:47:38,179 INFO [ProfilesDefinitionParser] Added profile 'Playstation 3' (id=4)
2013-02-28 18:47:38,493 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV (A-series)' (id=5)
2013-02-28 18:47:38,726 INFO [ProfilesDefinitionParser] Added profile 'DirecTV HD-DVR' (id=6)
2013-02-28 18:47:39,583 INFO [ProfilesDefinitionParser] Added profile 'Samsung TV / player (C/D/E-series)' (id=7)
2013-02-28 18:47:39,629 INFO [ProfilesDefinitionParser] Added profile 'LG TV / player' (id=8)
2013-02-28 18:47:40,720 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012)' (id=sony2012)
2013-02-28 18:47:41,883 INFO [ProfilesDefinitionParser] Added profile 'Sony BD Player / SMP' (id=10)
2013-02-28 18:47:42,512 INFO [ProfilesDefinitionParser] Added profile 'Toshiba REGZA' (id=13)
2013-02-28 18:47:42,825 INFO [ProfilesDefinitionParser] Added profile 'WDTV Live' (id=14)
2013-02-28 18:47:42,875 INFO [ProfilesDefinitionParser] Added profile 'LaCie LaCinema Media Player' (id=15)
2013-02-28 18:47:43,121 INFO [ProfilesDefinitionParser] Added profile 'Manta WIFI Centre' (id=16)
2013-02-28 18:47:43,214 INFO [ProfilesDefinitionParser] Added profile 'Pure Flow' (id=17)
2013-02-28 18:47:43,642 INFO [ProfilesDefinitionParser] Added profile 'Sharp Aquos' (id=18)
2013-02-28 18:47:43,832 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011)' (id=sony2011)
2013-02-28 18:47:44,472 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2010)' (id=sony2010)
2013-02-28 18:47:45,127 INFO [ProfilesDefinitionParser] Added profile 'Philips' (id=20)
2013-02-28 18:47:45,383 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2009)' (id=sony2009)
2013-02-28 18:47:45,531 INFO [ProfilesDefinitionParser] Added profile 'Denon AVR' (id=22)
2013-02-28 18:47:46,387 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera G/GT/DT/UT/VT (2011/2012)' (id=viera2011a)
2013-02-28 18:47:46,543 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera E/S/ST/VT (2011)' (id=viera2011)
2013-02-28 18:47:46,680 INFO [ProfilesDefinitionParser] Added profile 'Panasonic Viera (2010)' (id=viera2010)
2013-02-28 18:47:46,964 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2012) - US' (id=sony2012us)
2013-02-28 18:47:47,182 INFO [ProfilesDefinitionParser] Added profile 'Sony Bravia TV (2011) - US' (id=sony2011us)
2013-02-28 18:47:47,472 INFO [ProfilesDefinitionParser] Added profile 'Sony AVReceiver STR' (id=SonySTR)
2013-02-28 18:47:47,649 INFO [ProfilesDefinitionParser] Added profile 'Sony Audio CMT' (id=SonyCMT)
2013-02-28 18:47:47,669 INFO [ProfilesDefinitionParser] Parsing Profiles definition
2013-02-28 18:47:48,197 INFO [ProfilesDefinitionParser] Added profile 'Flash player' (id=flv_player)
2013-02-28 18:47:48,499 INFO [ProfilesDefinitionParser] Added profile 'ServiiGo' (id=serviigo)
2013-02-28 18:47:48,757 INFO [ProfilesDefinitionParser] Added profile 'Windows Phone 8' (id=wp8)
2013-02-28 18:47:48,878 INFO [Device] Created UPnP Device with UUID: 4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0, bound address: 192.168.1.5
2013-02-28 18:47:48,902 INFO [PluginCompilerThread] Looking for plugins at C:\Program Files\Serviio\bin\..\plugins
2013-02-28 18:47:48,903 INFO [PluginCompilerThread] Started looking for plugins
2013-02-28 18:47:48,905 INFO [UpdateChecker] Checking if a new version is available
2013-02-28 18:47:49,184 INFO [AbstractTranscodingDeliveryEngine] Cleaning transcode engine and its data
2013-02-28 18:47:49,227 INFO [WebServer] WebServer starting on port 8895
2013-02-28 18:47:49,235 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-02-28 18:47:49,237 INFO [EventDispatcher] Starting EventDispatcher
2013-02-28 18:47:49,238 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-02-28 18:47:49,252 INFO [RendererExpirationChecker] Starting RendererExpirationChecker
2013-02-28 18:47:49,348 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (Intel(R) Wireless WiFi Link 5100) and address 192.168.1.5, timeout = 0
2013-02-28 18:47:55,580 INFO [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
2013-02-28 18:48:21,603 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-02-28 18:48:21,604 INFO [FeedUpdaterThread] Started looking for information about online resources
2013-02-28 18:48:21,620 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-02-28 18:48:21,621 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-02-28 18:49:11,233 INFO [ServiioConsole] Starting Serviio Console
2013-02-28 18:49:11,351 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-02-28 18:49:12,252 INFO [Messages] Loaded console message bundle for locale: en
2013-02-28 18:49:14,493 INFO [ContentDirectoryDefinitionParser] Parsing ContentDirectory definition
2013-02-28 18:49:15,322 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: en
2013-02-28 19:17:10,716 INFO [WebServer] WebServer shutting down
2013-02-28 19:17:10,717 INFO [DiscoveryAdvertisementNotifier] Leaving DiscoveryAdvertisementNotifier
2013-02-28 19:17:10,718 INFO [EventSubscriptionExpirationChecker] Leaving EventSubscriptionExpirationChecker, removing all event subscriptions
2013-02-28 19:17:10,718 INFO [DiscoverySSDPMessageListener] Leaving DiscoverySSDPMessageListener
2013-02-28 19:17:10,721 INFO [EventDispatcher] Leaving EventDispatcher
2013-02-28 19:17:14,262 INFO [RendererExpirationChecker] Leaving RendererExpirationChecker
2013-02-28 19:17:19,033 INFO [Device] Updated bound IP address of Device with UUID: 4e97ce0c-21f3-3bf7-a94b-ac43c325a2c0, bound address: 192.168.1.4
2013-02-28 19:17:19,036 INFO [WebServer] WebServer starting on port 8895
2013-02-28 19:17:19,040 INFO [EventSubscriptionExpirationChecker] Starting EventSubscriptionExpirationChecker
2013-02-28 19:17:19,041 INFO [EventDispatcher] Starting EventDispatcher
2013-02-28 19:17:19,041 INFO [DiscoveryAdvertisementNotifier] Starting DiscoveryAdvertisementNotifier
2013-02-28 19:17:19,144 INFO [DiscoverySSDPMessageListener] Starting DiscoverySSDPMessageListener using interface net4 (Intel(R) Wireless WiFi Link 5100) and address 192.168.1.4, timeout = 0
2013-02-28 19:17:25,029 INFO [RendererSearchSender] Searching for Renderer devices, will multicast on 1 NICs
...etc
patters
Post Fri Mar 01, 2013 9:42 am
Re: BDP-S590 not showing up in Serviio Console Status Tab
Does your wifi router allow broadcast and multicast traffic? I was testing Serviio from a wifi-connected PC and had similar problems until I realised that due to a bug on the O2 Wireless Box V the "Allow multicast from Broadband Network" setting is in fact disabled when enabled in the GUI.
bzserviio
Post Fri Mar 01, 2013 12:15 pm
patters wrote:Does your wifi router allow broadcast and multicast traffic? I was testing Serviio from a wifi-connected PC and had similar problems until I realised that due to a bug on the O2 Wireless Box V the "Allow multicast from Broadband Network" setting is in fact disabled when enabled in the GUI.
The fact that I am seeing these \packets (albeit malformed) from the blue ray box on the PC running wireshark implies to me that the wireless router is allowing them. I will try and double check the settings though for multicast/broadcast. It's a netgear WGT624 in case it is relevant. What traffic should I be seeing?
bzserviio
Post Sat Mar 02, 2013 1:52 am
Update:
I changed Advanced , Lan IP setup, RIP direction (None->Both), RIP Version (Disabled->RIP_2M) on the web GUI of the WGT624v3
I was also experimenting with a C# proggie to manually distribute the info that looked garbled in wireshark but further testing appears to indicate this was extraneous. Now, the S590 shows up in Serviio, Serviio shows on the S590, and I can at least play one WMV from the PC on the S590 via Serviio. :D
Users browsing this forum: Baidu [Spider] and 8 guests
