Stream issues with W650
s4tch
Post Sun Mar 16, 2014 7:00 pm
Hi All,
Two days ago, I purchased a Sony KDL-42W650A (2013 model) Bravia TV. I installed Serviio 1.4.1 to play movies and online streams (mostly football matches) on the TV. Serviio is a great tool, but I'm a newbie, so I could use some help.
I created a stream in the Servioo console using this guide. I have two issues:
- while the TV sees all video files shared via Serviio, the "Online" folder seems empty when browsing with the TV. I have a Sony Xperia P smartphone, I installed BubbleUPnP DLNA/Chromecast app, and the smartphone can open and play the stream with sound.
- I managed to play the stream on the TV using the smartphone by selecting the TV as a renderer device. Image quality is fine, but no sound is played on the TV. The stream does have audio when played on the phone. I tried to select the Bravia 2013 profile for the smartphone, too (see 2nd screenshot); sound plays on the phone, not on the TV.
To sum it up: the TV doesn't find the stream, and even when I stream the match to the TV, it does not have a sound.
Here's a log and two screenshots:
https://dl.dropboxusercontent.com/u/373 ... erviio.log
https://dl.dropboxusercontent.com/u/373 ... oard01.jpg
https://dl.dropboxusercontent.com/u/373 ... oard02.jpg
Any help would be much appreciated. Thanks!
s4tch
Post Tue Mar 18, 2014 7:32 pm
Re: Stream issues with W650
OK, I managed to get an Acestream working on the TV with sound, but I had to use the smartphone to select the TV as a renderer device. Sopcast stream still has no sound, and the "Online" folder still looks empty when browsed with the TV. On the smartphone, everything works just fine.
Users browsing this forum: Baidu [Spider] and 1 guest
