Stream issues with W650
s4tch
Post Sun Mar 16, 2014 7:00 pm
Hi All,
Two days ago, I purchased a Sony KDL-42W650A (2013 model) Bravia TV. I installed Serviio 1.4.1 to play movies and online streams (mostly football matches) on the TV. Serviio is a great tool, but I'm a newbie, so I could use some help.
I created a stream in the Servioo console using this guide. I have two issues:
- while the TV sees all video files shared via Serviio, the "Online" folder seems empty when browsing with the TV. I have a Sony Xperia P smartphone, I installed BubbleUPnP DLNA/Chromecast app, and the smartphone can open and play the stream with sound.
- I managed to play the stream on the TV using the smartphone by selecting the TV as a renderer device. Image quality is fine, but no sound is played on the TV. The stream does have audio when played on the phone. I tried to select the Bravia 2013 profile for the smartphone, too (see 2nd screenshot); sound plays on the phone, not on the TV.
To sum it up: the TV doesn't find the stream, and even when I stream the match to the TV, it does not have a sound.
Here's a log and two screenshots:
https://dl.dropboxusercontent.com/u/373 ... erviio.log
https://dl.dropboxusercontent.com/u/373 ... oard01.jpg
https://dl.dropboxusercontent.com/u/373 ... oard02.jpg
Any help would be much appreciated. Thanks!
s4tch
Post Tue Mar 18, 2014 7:32 pm
Re: Stream issues with W650
OK, I managed to get an Acestream working on the TV with sound, but I had to use the smartphone to select the TV as a renderer device. Sopcast stream still has no sound, and the "Online" folder still looks empty when browsed with the TV. On the smartphone, everything works just fine.
