Weeebtv External App
afterhours
Post Mon Jul 21, 2014 12:38 pm
A few days ago I started writing a Java application that allows you to watch video stream from weebtv.
The application logs on to the weebtv account, gets selected channel stream using rtmpdump, then make it on own server.
In addition generates a list of channels that can be imported to serviio.
Currently, all the data are entered rigidly in the code.
I need to create configuration file with settings such as login, password etc.
At the moment, works perfectly on my Samsung TV;)
Jyrki
Post Wed May 19, 2021 5:01 am
Re: Weeebtv External App
I thought I could also get clean addresses of all weebtv channels that I need for my project, but somehow it's easier and cheaper to pay someone to do my homework for me here. Or a livestreamer could work perfectly with vlc too.
I used an ORM library to speed up the process with my website for Video Streaming (using Java).
Will it be possible to watch weebtv channels then on some video players like, for example, PotPlayer?
