HDTRAILERS VIDEO WEBRESOURCE
• Page 4 of 4 • 1, 2, 3, 4
I don't know. It works OK for me except for those from YouTube.
Re: HDTRAILERS VIDEO WEBRESOURCE
Hi
I have a problem with the plugins V12. I'm on Servvio 1.4.1.2.
Here is the erro message in seerviio log,
An error occured while parsing the online resource http://www.hd-trailers.net?start=1&res=1080&pref=apple, will try again soon: Unexpected error while invoking plugin (HDTrailers): The operation took more than 30000 ms and has been cancelled.
WHat's the problem ? Anyone can help me please ?
Regards
Regards
V13 Posted to restore Movie Poster Thumbnails.
Hello Folks,
(please be gentle, first post)
I have copied the HDTrailers.groovy file to the /plugins/ directory.
I have logged in to the Web Console.
How do I add the feeds to the Online Sources?
Do I have to restart the server?
Thanks,
Paully
Ubuntu Server 16.04
Serviio 1.6.1
Thanks,
Paully
Ubuntu Server 16.04
Serviio 1.6.1
Instructions are in the first post of this thread. Also as comments at the start of the groovy.
I am getting errors in the log.
Any idea?
Any idea?
- Code:
2016-09-17 11:32:39,906 ERROR [IndexedDiskCache] Region [online_technical_metadata] Failure updating element, key: http://www.hd-trailers.net/movie/a-beautiful-now/_720 old: null
java.io.NotSerializableException: org.serviio.library.local.AudioTrack
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1184)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:348)
at java.util.ArrayList.writeObject(ArrayList.java:762)
at sun.reflect.GeneratedMethodAccessor17.invoke(Unknown Source)
at java.io.ObjectStreamClass.invokeWriteObject(ObjectStreamClass.java:1028)
at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1496)
at java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1432)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1178)
at java.io.ObjectOutputStream.defaultWriteFields(ObjectOutputStream.java:1548)
at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1509)
at org.apache.jcs.utils.serialization.StandardSerializer.serialize(StandardSerializer.java:50)
at org.apache.jcs.auxiliary.disk.indexed.IndexedDisk.serialize(IndexedDisk.java:288)
at org.apache.jcs.auxiliary.disk.indexed.IndexedDiskCache.doUpdate(IndexedDiskCache.java:430)
at org.apache.jcs.auxiliary.disk.AbstractDiskCache$MyCacheListener.handlePut(AbstractDiskCache.java:603)
at org.apache.jcs.engine.CacheEventQueue$PutEvent.doRun(CacheEventQueue.java:688)
at org.apache.jcs.engine.CacheEventQueue$AbstractCacheEvent.run(CacheEventQueue.java:607)
at org.apache.jcs.engine.CacheEventQueue$QProcessor.run(CacheEventQueue.java:575)
Looks like a bug in 1.7, will fix.
Petr
Help translate Serviio
zip wrote:Looks like a bug in 1.7, will fix.
Did also happen in 1.6
Hello.
I think the site has changed links, looks like now res=yyy and start=nn doesn't work anymore.
Also, the limit is 15, they are numbered and some of them are missing from the list, I think the ones from youtube.
I have only tried Most watched and Latest.
http://imgur.com/a/wWR0J
3 and 9 are missing from the list generated by Serviio.
Currently i get the follow issue when using this plugin:
Any idea?
Any idea?
- Code:
2019-10-05 22:24:08,798 WARN [FeedUpdaterWorker] Failed to retrieve online item information for http://movietrailers.apple.com/movies/independent/the-gentlemen/the-gentlemen-trailer -1_h720p.mov. It might not play.
at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveMetadata(FeedUpdaterWorker.java:321)
at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveTechnicalMetadata(FeedUpdaterWorker.java:246)
at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:120)
at java.lang.Thread.run(Thread.java:748)
at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:548)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:117)
at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:164)
at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveMetadata(FeedUpdaterWorker.java:300)
... 3 more
2019-10-05 22:24:11,651 WARN [FeedUpdaterWorker] Failed to retrieve online item information for https://movietrailers.apple.com/movies/independent/the-curse-of-buckout-road/the-curs e-of-buckout-road-trailer-1_h720p.mov. It might not play.
... 3 more
What URL are you using?
Petr
Does the HDTrailers.groovy plugin work in Serviio v2 ?
I have got some to appear in the MediaBrowser playlist but it then clags it
e.g. http://www.hd-trailers.net/top-movies?res=480
But (other options do not appear at all) - it has now appeared but does not work as above - all clagged up
e.g. http://www.hd-trailers.net/coming-soon?res=720
