HDTRAILERS VIDEO WEBRESOURCE
Post Wed Dec 11, 2013 12:17 am
Re: HDTRAILERS VIDEO WEBRESOURCE
I don't know. It works OK for me except for those from YouTube.
powerpanzer
Post Thu Oct 30, 2014 2:28 pm
Hi
I have a problem with the plugins V12. I'm on Servvio 1.4.1.2.
Here is the erro message in seerviio log,
An error occured while parsing the online resource http://www.hd-trailers.net?start=1&res=1080&pref=apple, will try again soon: Unexpected error while invoking plugin (HDTrailers): The operation took more than 30000 ms and has been cancelled.
WHat's the problem ? Anyone can help me please ?
Regards
Post Thu Jun 09, 2016 2:49 am
V13 Posted to restore Movie Poster Thumbnails.
plittlefield
Post Thu Jun 09, 2016 3:02 pm
Hello Folks,
(please be gentle, first post)
I have copied the HDTrailers.groovy file to the /plugins/ directory.
I have logged in to the Web Console.
How do I add the feeds to the Online Sources?
Do I have to restart the server?
Thanks,
Paully
Ubuntu Server 16.04
Serviio 1.6.1
Post Thu Jun 09, 2016 5:53 pm
Instructions are in the first post of this thread. Also as comments at the start of the groovy.
josch.hh
Post Sat Sep 17, 2016 9:34 am
I am getting errors in the log.
Any idea?
2016-09-17 11:32:39,906 ERROR [IndexedDiskCache] Region [online_technical_metadata] Failure updating element, key: http://www.hd-trailers.net/movie/a-beautiful-now/_720 old: null
java.io.NotSerializableException: org.serviio.library.local.AudioTrack
        at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1184)
        at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:348)
        at java.util.ArrayList.writeObject(ArrayList.java:762)
        at sun.reflect.GeneratedMethodAccessor17.invoke(Unknown Source)
        at java.io.ObjectStreamClass.invokeWriteObject(ObjectStreamClass.java:1028)
        at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1496)
        at java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1432)
        at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1178)
        at java.io.ObjectOutputStream.defaultWriteFields(ObjectOutputStream.java:1548)
        at java.io.ObjectOutputStream.writeSerialData(ObjectOutputStream.java:1509)
        at org.apache.jcs.utils.serialization.StandardSerializer.serialize(StandardSerializer.java:50)
        at org.apache.jcs.auxiliary.disk.indexed.IndexedDisk.serialize(IndexedDisk.java:288)
        at org.apache.jcs.auxiliary.disk.indexed.IndexedDiskCache.doUpdate(IndexedDiskCache.java:430)
        at org.apache.jcs.auxiliary.disk.AbstractDiskCache$MyCacheListener.handlePut(AbstractDiskCache.java:603)
        at org.apache.jcs.engine.CacheEventQueue$PutEvent.doRun(CacheEventQueue.java:688)
        at org.apache.jcs.engine.CacheEventQueue$AbstractCacheEvent.run(CacheEventQueue.java:607)
        at org.apache.jcs.engine.CacheEventQueue$QProcessor.run(CacheEventQueue.java:575)
Post Sat Sep 17, 2016 7:09 pm
Looks like a bug in 1.7, will fix.
josch.hh
Post Sun Sep 18, 2016 6:34 am
zip wrote:Looks like a bug in 1.7, will fix.
Did also happen in 1.6
iliecsorin
Post Thu Jan 19, 2017 11:01 am
Hello.
I think the site has changed links, looks like now res=yyy and start=nn doesn't work anymore.
Also, the limit is 15, they are numbered and some of them are missing from the list, I think the ones from youtube.
I have only tried Most watched and Latest.
http://imgur.com/a/wWR0J
3 and 9 are missing from the list generated by Serviio.
josch.hh
Post Sat Oct 05, 2019 8:26 pm
Currently i get the follow issue when using this plugin:
Any idea?
2019-10-05 22:24:08,798 WARN  [FeedUpdaterWorker] Failed to retrieve online item information for http://movietrailers.apple.com/movies/independent/the-gentlemen/the-gentlemen-trailer                                           -1_h720p.mov. It might not play.
        at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveMetadata(FeedUpdaterWorker.java:321)
        at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveTechnicalMetadata(FeedUpdaterWorker.java:246)
        at org.serviio.library.online.metadata.FeedUpdaterWorker.run(FeedUpdaterWorker.java:120)
        at java.lang.Thread.run(Thread.java:748)
        at org.serviio.library.metadata.FFmpegMetadataRetriever.validateMandatoryMetadata(FFmpegMetadataRetriever.java:548)
        at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveMetadata(FFmpegMetadataRetriever.java:117)
        at org.serviio.library.metadata.FFmpegMetadataRetriever.retrieveOnlineMetadata(FFmpegMetadataRetriever.java:164)
        at org.serviio.library.online.metadata.FeedUpdaterWorker.retrieveMetadata(FeedUpdaterWorker.java:300)
        ... 3 more
2019-10-05 22:24:11,651 WARN  [FeedUpdaterWorker] Failed to retrieve online item information for https://movietrailers.apple.com/movies/independent/the-curse-of-buckout-road/the-curs                                           e-of-buckout-road-trailer-1_h720p.mov. It might not play.
        ... 3 more
Post Sun Oct 13, 2019 1:30 pm
What URL are you using?
josch.hh
Post Sun Oct 13, 2019 2:55 pm
zip wrote:What URL are you using?
http://www.hd-trailers.net?res=720
Paul C
Post Tue Jan 21, 2020 1:14 pm
Does the HDTrailers.groovy plugin work in Serviio v2 ?
I have got some to appear in the MediaBrowser playlist but it then clags it
e.g. http://www.hd-trailers.net/top-movies?res=480
But (other options do not appear at all) - it has now appeared but does not work as above - all clagged up
e.g. http://www.hd-trailers.net/coming-soon?res=720
Previous
Return to Available plugins
