Re: Comedy Central
Please note the new URL for Southpark.
EDIT:
Attachment updated again, found a bug with Southpark. Please try again
2012-10-26 05:28:54,504 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-10-26 05:28:54,529 DEBUG [OnlineLibraryManager] Resource http://www.southparkstudios.com/feeds/full-episode/carousel/16/dc400305-d548-4c30-8f05-0f27dc7e0d5c not in cache yet, loading it
2012-10-26 05:28:54,529 DEBUG [WebResourceParser] Parsing web resource 'http://www.southparkstudios.com/feeds/full-episode/carousel/16/dc400305-d548-4c30-8f05-0f27dc7e0d5c'
2012-10-26 05:28:54,530 DEBUG [WebResourceParser] Found matching url extractor (ComedyCentral) for resource http://www.southparkstudios.com/feeds/full-episode/carousel/16/dc400305-d548-4c30-8f05-0f27dc7e0d5c
2012-10-26 05:28:54,530 DEBUG [FeedItemUrlExtractor] ComedyCentral: Starting parsing resource: http://www.southparkstudios.com/feeds/full-episode/carousel/16/dc400305-d548-4c30-8f05-0f27dc7e0d5c
2012-10-26 05:28:55,394 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (ComedyCentral): No match found
at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.lang.IllegalStateException: No match found
at java.util.regex.Matcher.group(Matcher.java:468)
at java_util_regex_MatchResult$group.call(Unknown Source)
at ComedyCentral.getSouthPark(ComedyCentral.groovy:103)
at ComedyCentral$getSouthPark.callCurrent(Unknown Source)
at ComedyCentral.extractItems(ComedyCentral.groovy:50)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:680)
2013-06-05 20:41:17,512 DEBUG [WebResourceParser] Found matching url extractor (ComedyCentral) for resource http://www.colbertnation.com/full-episodes/
2013-06-05 20:41:17,512 DEBUG [FeedItemUrlExtractor] ComedyCentral: Starting parsing resource: http://www.colbertnation.com/full-episodes/
2013-06-05 20:41:17,903 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (ComedyCentral): index is out of range 0..-1 (index = 0)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:6202)
at org.codehaus.groovy.runtime.dgm$310.invoke(Unknown Source)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
at ComedyCentral.getFeeds(ComedyCentral.groovy:176)
at ComedyCentral$getFeeds.callCurrent(Unknown Source)
at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCallCurrent(CallSiteArray.java:46)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:133)
at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:141)
at ComedyCentral.extractItems(ComedyCentral.groovy:57)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)flancur wrote:Hi, I would like to push this request again. Is there anybody that can fix the plugin or give tips how to do it? It's basically the only plugin I really used and going back to watch Colbert Report and Daily Show on my PC again is really annoying.
Thanks a lot in advance!
Flancur
