Comedy Central
insane822
Post Sun Oct 07, 2012 3:46 pm
Re: Comedy Central
I have attached an update to the original post -- it should be fixed now.
Please note the new URL for Southpark.
EDIT:
Attachment updated again, found a bug with Southpark. Please try again :)
flancur
Post Wed Oct 10, 2012 6:11 pm
Re: Comedy Central
Ah, the plugin is working again. At least Daily Show and Colbert report. Unfortunatly, I can not check South Park for you, as southparkstudios.com is geoblocked for me anyway.
Thank you so much for fixing it!
Serviio 1.3.1 Windows 7 Professional x64 Sony KDL-32EX705
insane822
Post Wed Oct 10, 2012 8:42 pm
Re: Comedy Central
SP is currently working for me, so it must be a geo block :(
jamitupya
Post Sat Oct 13, 2012 12:31 pm
Re: Comedy Central
im wondering if im missing something....
its a web resource and i use the url for the show i.e. URL is http://www.thedailyshow.com/full-episodes/ for daily show?
i can view these online, so wondering why they aren't showing up or just saying its empty on my PS3
any ideas?
insane822
Post Mon Oct 15, 2012 7:31 pm
Re: Comedy Central
That should work. Do you see anything in the debug logs for this plugin?
nmrx13
Post Fri Oct 26, 2012 11:32 am
Re: Comedy Central
I'm having the same problem with my PS3, nothing shows up for the Comedy Central shows, I've tested Daily Show, Colbert, and South Park and nothing shows up. I know a while back it was working fine but not sure what could be wrong. Here is the debug log I got trying to get South Park to work.
2012-10-26 05:28:54,504 DEBUG [FeedUpdaterThread] Checking for new and expired online resources
2012-10-26 05:28:54,529 DEBUG [OnlineLibraryManager] Resource http://www.southparkstudios.com/feeds/full-episode/carousel/16/dc400305-d548-4c30-8f05-0f27dc7e0d5c not in cache yet, loading it
2012-10-26 05:28:54,529 DEBUG [WebResourceParser] Parsing web resource 'http://www.southparkstudios.com/feeds/full-episode/carousel/16/dc400305-d548-4c30-8f05-0f27dc7e0d5c'
2012-10-26 05:28:54,530 DEBUG [WebResourceParser] Found matching url extractor (ComedyCentral) for resource http://www.southparkstudios.com/feeds/full-episode/carousel/16/dc400305-d548-4c30-8f05-0f27dc7e0d5c
2012-10-26 05:28:54,530 DEBUG [FeedItemUrlExtractor] ComedyCentral: Starting parsing resource: http://www.southparkstudios.com/feeds/full-episode/carousel/16/dc400305-d548-4c30-8f05-0f27dc7e0d5c
2012-10-26 05:28:55,394 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (ComedyCentral): No match found
   at org.serviio.library.online.WebResourceParser.parse(WebResourceParser.java:58)
   at org.serviio.library.online.OnlineLibraryManager.findResource(OnlineLibraryManager.java:171)
Caused by: java.lang.IllegalStateException: No match found
   at java.util.regex.Matcher.group(Matcher.java:468)
   at java_util_regex_MatchResult$group.call(Unknown Source)
   at ComedyCentral.getSouthPark(ComedyCentral.groovy:103)
   at ComedyCentral$getSouthPark.callCurrent(Unknown Source)
   at ComedyCentral.extractItems(ComedyCentral.groovy:50)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:32)
   at org.serviio.library.online.WebResourceUrlExtractor$1.executePluginMethod(WebResourceUrlExtractor.java:29)
   at org.serviio.library.online.PluginExecutionProcessor$1.call(PluginExecutionProcessor.java:50)
   at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
   at java.util.concurrent.FutureTask.run(FutureTask.java:138)
   at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
   at java.lang.Thread.run(Thread.java:680)
Any help would be greatly appreciated.
DeathBeforeDawn
Post Sun Dec 09, 2012 6:43 pm
Re: Comedy Central
Any Chance you could add support for the Tosh.0 Page. I tried myself but couldn't get it to work.
http://tosh.comedycentral.com/full-episodes
Thank You, And Awesome Plugin!
flancur
Post Wed Jun 05, 2013 6:52 pm
Re: Comedy Central
Comedy Central introduced a new webplayer and now it seems like the plugin is not working anymore. Here an extract from the debug log:
2013-06-05 20:41:17,512 DEBUG [WebResourceParser] Found matching url extractor (ComedyCentral) for resource http://www.colbertnation.com/full-episodes/
2013-06-05 20:41:17,512 DEBUG [FeedItemUrlExtractor] ComedyCentral: Starting parsing resource: http://www.colbertnation.com/full-episodes/
2013-06-05 20:41:17,903 WARN  [FeedUpdaterThread] An error occured while scanning for online item information, will continue
java.io.IOException: Unexpected error while invoking plugin (ComedyCentral): index is out of range 0..-1 (index = 0)
Caused by: java.lang.IndexOutOfBoundsException: index is out of range 0..-1 (index = 0)
   at org.codehaus.groovy.runtime.DefaultGroovyMethods.getAt(DefaultGroovyMethods.java:6202)
   at org.codehaus.groovy.runtime.dgm$310.invoke(Unknown Source)
   at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite$PojoMetaMethodSiteNoUnwrapNoCoerce.invoke(PojoMetaMethodSite.java:271)
   at org.codehaus.groovy.runtime.callsite.PojoMetaMethodSite.call(PojoMetaMethodSite.java:53)
   at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCall(CallSiteArray.java:42)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:108)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.call(AbstractCallSite.java:116)
   at ComedyCentral.getFeeds(ComedyCentral.groovy:176)
   at ComedyCentral$getFeeds.callCurrent(Unknown Source)
   at org.codehaus.groovy.runtime.callsite.CallSiteArray.defaultCallCurrent(CallSiteArray.java:46)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:133)
   at org.codehaus.groovy.runtime.callsite.AbstractCallSite.callCurrent(AbstractCallSite.java:141)
   at ComedyCentral.extractItems(ComedyCentral.groovy:57)
   at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
   at java.util.concurrent.FutureTask.run(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
   at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
   at java.lang.Thread.run(Unknown Source)
Is somebody able to fix it? Unfortunately, I have no clue how to edit a groovy file and I don't even know where to retrieve the necessary links and other infos.
Thanks a lot!
josiok
Post Wed Jun 05, 2013 8:45 pm
Re: Comedy Central
I'm having similar problems. Comedy Central programming doesn't even show up. Any ideas??
My debug file (excerpt)-
2013-06-05 16:41:48,235 INFO [PluginCompilerThread] Added Web Resouce plugin ComedyCentral (ComedyCentral.groovy), version: 1
2013-06-05 16:41:56,971 INFO [ServiioConsole] Starting Serviio Console
2013-06-05 16:41:57,041 INFO [ServiioConsole] Connecting to Serviio REST on localhost:23423
2013-06-05 16:41:57,695 INFO [Messages] Loaded console message bundle for locale: en
2013-06-05 16:42:10,412 INFO [FeedUpdaterThread] Started looking for information about online resources
2013-06-05 16:42:10,413 INFO [LibraryUpdatesCheckerThread] Started looking for updates to currently shared files
2013-06-05 16:42:10,413 INFO [LibraryAdditionsCheckerThread] Started looking for newly added files
2013-06-05 16:42:10,414 INFO [PlaylistMaintainerThread] Started looking playlist changes
2013-06-05 16:42:37,970 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
at ComedyCentral.getFeeds(ComedyCentral.groovy:168)
at ComedyCentral.extractItems(ComedyCentral.groovy:54)
2013-06-05 16:42:38,326 WARN [FeedUpdaterThread] An error occured while scanning for online item information, will continue
flancur
Post Thu Jun 13, 2013 9:45 pm
Re: Comedy Central
is there nobody that can fix the plugin? It's basically the only way I can enjoy Daily Show and Colbert Report on my television as Hulu is geoblocked for me and my PC is too far away from my TV to connect via HDMI.
Please!
Tobias
insane822
Post Sun Jun 16, 2013 4:13 pm
Re: Comedy Central
Comedy Central changed their websites, so I'll have to work on this some time in the next few days.
I didn't realize it was broken, but trust me, I miss it just as much lol! I'll post asap once I fix it.
flancur
Post Thu Jun 20, 2013 4:43 pm
Re: Comedy Central
Great, thanks in advance!
If it worked out, could you please also write where you found the necessary links? I would like to learn how to fix it myself. I read zips guide for the groovy files, but I couldn't find a hint where to look for the relevant stuff I actually need to add to the file.
insane822
Post Wed Jun 26, 2013 2:23 am
Re: Comedy Central
I'll post that stuff later, but for now here is a test feed I made for the daily show at 3500kbps:
http://streamparse.appspot.com/streams/thedailyshow
Just add the above link to serviio as a regular atom/rss -- I'll work on the other CC stuff soon, I just haven't had much free time.
flancur
Post Fri Jun 28, 2013 4:14 pm
Re: Comedy Central
Thanks, works great! I really appreciate your effort!
flancur
Post Wed Jul 24, 2013 4:05 pm
Re: Comedy Central
is there any news on the plugin? The RSS-feed is broken, as it seems to not find the right titles anymore (it displays all idems as unknown) and therefor is totally messing up the order of elements on my Sony Bravia. Another advantage of the plugin was, that I could change the quality in order to adapt it to the current internet connection. And I also miss Stephen. ;)
Thanks!
flancur
Post Tue Oct 01, 2013 5:04 pm
Re: Comedy Central
Hi, I would like to push this request again. Is there anybody that can fix the plugin or give tips how to do it? It's basically the only plugin I really used and going back to watch Colbert Report and Daily Show on my PC again is really annoying.
Thanks a lot in advance!
Flancur
josiok
Post Tue Oct 01, 2013 5:20 pm
Re: Comedy Central
flancur wrote:Hi, I would like to push this request again. Is there anybody that can fix the plugin or give tips how to do it? It's basically the only plugin I really used and going back to watch Colbert Report and Daily Show on my PC again is really annoying.
Flancur
You can also access Daily Show / Colbert through Hulu:
Source Type: Online RSS
Daily Show: http://www.hulu.com/feed/show/902/episodes
Colbert: http://www.hulu.com/feed/show/903/episodes
Though, frankly, I often have trouble with this plugin, too. (No Content Available)
flancur
Post Tue Oct 01, 2013 5:38 pm
Re: Comedy Central
Hi josiok,
thanks for the fast resonse. I guess Hulu is the reason why nobody misses this plugin, because most people can watch CR and DS over Hulu.
The problem is, that Hulu is completely geoblocked for me as I live in Europe, no matter if the content itself is blocked by the content owner. That's why this plugin was great for me, as it took the episodes directly from the colbertnation.com & dailyshow.com pages, that are not geoblocked for me at all.
Maybe I really have to dive into this whole proxi server thing to fake I'm in the US. :cry:
Thanks a lot anyway!
Flancur
loulouki
Post Tue Nov 26, 2013 4:34 am
Re: Comedy Central
Hey Same problem here, Southpark works fine but Colbert report won't even show up, I have tried to take a look myself at the source of colbert webiste and the groovy plugin but since I have never done this before I m a bit lost I must say..
Anyone can give a hand at fixing this plugin, I really wish I could watch Colbert on my TV without setting up a proxy or a vpn..
Previous
Return to Available plugins
Users browsing this forum: Google [Bot] and 5 guests
