HULU strange problem
jorj
Post Sat Jan 04, 2014 11:10 pm
I have been using Serviio on a windoze box for a couple of months and decided I like it enough to dedicate a linux box to it. I installed Serviio on the linux box, compiled ffmpeg as per the instructions, exported data from the windoze box and inported it into the Serviio on the linux box... Now (on the linux box) everything works the same as before EXCEPT HULU will not play. It still plays episodes on the windoze box, but not the linux box. Since the data is an export/inport, I am assuming it is ok. The only thing I can think of is something in ffmpeg is failing to transcode properly. The Sony BluRay player can play from the server on windoze, but gives an error (the file is corrupt or unsupported) when receiving from the linux box. Any Ideas where I screwed the pooch on this one?
Here is the last 100 lines of the serviio.log file, the protocol not found, sounds like maby I didnt get something installed on the linux box?
2014-01-04 16:57:56,511 INFO [PlaylistMaintainerThread] Started looking playlist changes
2014-01-04 17:00:26,520 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEaUdXd.b_bWabdGbhcHdRcIaQbLbEcHdb-bsYjkh-c0-2qOEtDqZIxn&aifp=sll02152008&slist=hulu14/563/60303563;.international=false&hgt=OZU7Pvs7j27-nhteNno7wjy_tNb9uNj0hIQr2mV1DN2oZpMKHGEysBYBQF_vF8x1ukev99cKfZqtrh3y9I-97SGBqJOtxgmJrlRZ1ZnardLrDM6x4YTcNlrhgySbfmaUM9rnFHgZghUYXsw-2rk5t9Y3JQERKAadwto2Cf5B5EnfHSAxaWiDeveLCBkkVchkAaPA6VQqGW93afrGzp8T2ey6itQhYrR_xRW1i626Hnnq_C4_8GKZqdPQeqMKBweS&hgt_ver=331370278 playpath=mp4:hulu14/563/60303563/agave50521823_19609201_H264_400.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1 buffer=100000000: Protocol not fo
2014-01-04 17:00:51,445 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100002337-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100002337-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:134)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:110)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:153)
at org.serviio.delivery.GETMethodProcessor.retrieveResource(GETMethodProcessor.java:121)
at org.serviio.delivery.GETMethodProcessor.buildDeliveryContainer(GETMethodProcessor.java:48)
at org.serviio.delivery.AbstractMethodProcessor.handleRequest(AbstractMethodProcessor.java:100)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:81)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
2014-01-04 17:00:58,020 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEanbGaJdhb4cTciddc0bLdUdqdwdbb9cD-bsYjkN-c0-ZoHBwFuZGzr&aifp=sll02152008&slist=hulu8/957/60299957;.international=false&hgt=OZU7Pvs7j27-nhteNno7wosA0ak8No1d0dPRJRnhwqfQo-i1g6jfkZHvOcd00Ix8bdD-nv-NTRNQMFI4KbG6FVNzlxCAEOPG7RW6wnzW5m-Bm2wJYU0Xo34_iPGLVm3DsVBFc_1d6ro7TEh2K6LPMROu5lQBRluTTsVSpj8D0iBUcKo0fqJ7cIWy2tBsQT41goNGiBn04-t71YzgbuUnekQmhtJD_FYTmJZ9HSvkNSalwbmOGAMRlTOgQFFTpnts&hgt_ver=331370278 playpath=mp4:hulu8/957/60299957/agave50518247_19352520_H264_400.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1 buffer=100000000: Protocol not found
2014-01-04 17:01:22,952 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100003385-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100003385-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
2014-01-04 17:01:29,547 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEcTbXascWawdDaDdEaGdzbIbEbna1dUdd-bsYjlg-c0-1oOBzEvYCAv&aifp=sll02152008&slist=hulu12/136/60297136;.international=false&hgt=OZU7Pvs7j27-nhteNno7wmHvpn3kXoFBfoM6sBHxCGvbIvlwnBb9ZEl7eleP3S7ZJNcFwaBXay-B7iBgkZ8zkJNyXdXOANVz7Qde_ufNhMThQvzjEnKNQhoINVRLYnPrrTWN1Amqe_GwRvPOwdTie_udHPnXeJW1AH4FxL97ej1sV9fiNhd2i975ZKfttISLyZQgK1_jtHntKwlb4_mvO3A_nL-yrL_mBSydNvQrmsKDULBZpibCMgoaR7j6AdFJ&hgt_ver=331370278 playpath=mp4:hulu12/136/60297136/agave50515486_19243873_H264_400.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1 buffer=100000000: Protocol not fo
2014-01-04 17:01:54,496 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100004572-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100004572-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
2014-01-04 17:02:00,999 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEb_bVdNbnc9cqafalabcwcHaFdkcXbOaP-bsYjlM-c0-ZoMEADq0Bzs&aifp=sll02152008&slist=hulu2/301/60292301;.international=false&hgt=OZU7Pvs7j27-nhteNno7wsG82VUYMzPhSRFtWfmsvMSapHDBjrHgS47OOyO51LIPBZnHgzu6DTCIHXglr3DhNW0ACFlQeXL6gIwaxSj82vm8YFOEeEIEKmvlRmvDWu27dgI9VvtcfRfVSAp8K5WtU0m3VkDso3YrOI0aLTlEP4IsE7kVr9tQyRVWfIHKkFEhRGwXJwfGwpuNP7lUY3vPDLYrLT7pJuyxeRZSOmgjoc52r0mwzwSsd_eTOMvGTK3x&hgt_ver=331370278 playpath=mp4:hulu2/301/60292301/agave50511963_19120575_H264_400.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1 buffer=100000000: Protocol not found
2014-01-04 17:02:25,946 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100005583-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100005583-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
2014-01-04 17:02:32,502 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEanc3ctazbWdlc9dvcob3dVcccQc9b1a5-bsYjmf-c0-ZpKDACsZIAn&aifp=sll02152008&slist=hulu3/952/60283952;.international=false&hgt=OZU7Pvs7j27-nhteNno7wtYbvmcqw-Qq3vcOkCSI4FuKJMclLTYTTUIcLWmIZJIbp2vsBpkMe9ObJuKjERgMD9plvtWpUef3Taonn9Rv0uefzDmm05GC5NId5O48--hIt3aj-nlZMvkAK7HMme2J3_hB7J46sJ8nB_m0MisDaCyn74ti5CUl8s5g7n8G-rKj_nQuiVk6FcK0C477ll1ofwfGjWyY77cEiqN0l3zy1QaZVop3-77IcBJC4lJbfcjU&hgt_ver=331370278 playpath=mp4:hulu3/952/60283952/agave50504162_18760413_H264_400.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1 buffer=100000000: Protocol not found
Xmantium
Post Sun Jan 05, 2014 12:14 am
Re: HULU strange problem
More than likely youve not compiled ffmpeg properly with librtmp
In future can you post the related plugin issue in the relevant post.
Please can the moderators move this post to the HULU section
jorj
Post Sun Jan 05, 2014 2:48 pm
Xmantium wrote:More than likely youve not compiled ffmpeg properly with librtmp
Yes I am using the HULU (us only) plugin, and sorry if posted in wrong section.
I didnt determine this to be a HULU plugin problem since the SAME file works in windows.
I compiled ffmpeg with the following (excerpt of the) shell script. and using the version of ffmpeg downloaded from the serviio.org/download page.
cd ~/src
git clone git://git.ffmpeg.org/rtmpdump
cd rtmpdump
make SYS=posix
checkinstall --pkgname=rtmpdump --pkgversion="2:$(date +%Y%m%d%H%M)-git" --backup=no \
--deldoc=yes --fstrans=no --default
# -- ffmpeg
cd ~/src
#git clone --depth 1 git://git.videolan.org/ffmpeg
cd ffmpeg
./configure --enable-gpl --enable-libfaac --enable-libmp3lame --enable-libopencore-amrnb \
--enable-libopencore-amrwb --enable-libtheora --enable-libvorbis --enable-libx264 \
--enable-nonfree --enable-postproc --enable-version3 --enable-x11grab --enable-librtmp \
--enable-libxvid --enable-libass
make
checkinstall --pkgname=ffmpeg --pkgversion="99:$(date +%Y%m%d%H%M)-git" --backup=no \
jorj
Post Tue Jan 07, 2014 3:49 pm
I am tired of re-compiling ffmpeg and related packages without any success. I have downloaded and installed the pre-compiled ubuntu packages from user kuhrram23 's sig - again without any success. Does anyone know of a WORKING linux configuration? I would like to find a live cd or something to see it work on linux. I am not opposed to reformatting and installing a different distro if that would work. I really hate to scrap this project, but can no longer live with using the windows version (uses too much resource to co-exist with other things I am doing on that box).
FWIW: Veetle, Crackle & youtube work on the linux box, HULU & SYFY do not load any episodes.
EDIT:
For anyone having the same problem... I dont know exactly what the problem was, but I installed "ps3mediaserver.org"'s media server and the included ffmpeg etc solved the problem. It even fixed some inconsistancies with the syfy channels. Dont like this type of messy kludge, but it worked for me.
Return to Available plugins
