HULU strange problem
I have been using Serviio on a windoze box for a couple of months and decided I like it enough to dedicate a linux box to it. I installed Serviio on the linux box, compiled ffmpeg as per the instructions, exported data from the windoze box and inported it into the Serviio on the linux box... Now (on the linux box) everything works the same as before EXCEPT HULU will not play. It still plays episodes on the windoze box, but not the linux box. Since the data is an export/inport, I am assuming it is ok. The only thing I can think of is something in ffmpeg is failing to transcode properly. The Sony BluRay player can play from the server on windoze, but gives an error (the file is corrupt or unsupported) when receiving from the linux box. Any Ideas where I screwed the pooch on this one?
Here is the last 100 lines of the serviio.log file, the protocol not found, sounds like maby I didnt get something installed on the linux box?
2014-01-04 16:57:56,511 INFO [PlaylistMaintainerThread] Started looking playlist changes
2014-01-04 17:00:26,520 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEaUdXd.b_bWabdGbhcHdRcIaQbLbEcHdb-bsYjkh-c0-2qOEtDqZIxn&aifp=sll02152008&slist=hulu14/563/60303563;.international=false&hgt=OZU7Pvs7j27-nhteNno7wjy_tNb9uNj0hIQr2mV1DN2oZpMKHGEysBYBQF_vF8x1ukev99cKfZqtrh3y9I-97SGBqJOtxgmJrlRZ1ZnardLrDM6x4YTcNlrhgySbfmaUM9rnFHgZghUYXsw-2rk5t9Y3JQERKAadwto2Cf5B5EnfHSAxaWiDeveLCBkkVchkAaPA6VQqGW93afrGzp8T2ey6itQhYrR_xRW1i626Hnnq_C4_8GKZqdPQeqMKBweS&hgt_ver=331370278 playpath=mp4:hulu14/563/60303563/agave50521823_19609201_H264_400.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1 buffer=100000000: Protocol not fo
2014-01-04 17:00:51,445 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100002337-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100002337-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
at org.serviio.delivery.resource.transcode.FileBasedTranscodingDeliveryStrategy.createInputStream(FileBasedTranscodingDeliveryStrategy.java:47)
at org.serviio.delivery.resource.transcode.AbstractTranscodingDeliveryEngine.retrieveTranscodedResource(AbstractTranscodingDeliveryEngine.java:134)
at org.serviio.delivery.resource.AbstractDeliveryEngine.deliver(AbstractDeliveryEngine.java:110)
at org.serviio.delivery.MediaResourceRetrievalStrategy.retrieveResource(MediaResourceRetrievalStrategy.java:153)
at org.serviio.delivery.GETMethodProcessor.retrieveResource(GETMethodProcessor.java:121)
at org.serviio.delivery.GETMethodProcessor.buildDeliveryContainer(GETMethodProcessor.java:48)
at org.serviio.delivery.AbstractMethodProcessor.handleRequest(AbstractMethodProcessor.java:100)
at org.serviio.delivery.ResourceDeliveryProcessor.deliverContent(ResourceDeliveryProcessor.java:81)
at org.serviio.upnp.webserver.ResourceTransportRequestHandler.handleRequest(ResourceTransportRequestHandler.java:86)
at org.serviio.upnp.webserver.ServiioHttpService.doService(ServiioHttpService.java:77)
2014-01-04 17:00:58,020 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEanbGaJdhb4cTciddc0bLdUdqdwdbb9cD-bsYjkN-c0-ZoHBwFuZGzr&aifp=sll02152008&slist=hulu8/957/60299957;.international=false&hgt=OZU7Pvs7j27-nhteNno7wosA0ak8No1d0dPRJRnhwqfQo-i1g6jfkZHvOcd00Ix8bdD-nv-NTRNQMFI4KbG6FVNzlxCAEOPG7RW6wnzW5m-Bm2wJYU0Xo34_iPGLVm3DsVBFc_1d6ro7TEh2K6LPMROu5lQBRluTTsVSpj8D0iBUcKo0fqJ7cIWy2tBsQT41goNGiBn04-t71YzgbuUnekQmhtJD_FYTmJZ9HSvkNSalwbmOGAMRlTOgQFFTpnts&hgt_ver=331370278 playpath=mp4:hulu8/957/60299957/agave50518247_19352520_H264_400.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1 buffer=100000000: Protocol not found
2014-01-04 17:01:22,952 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100003385-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100003385-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
2014-01-04 17:01:29,547 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEcTbXascWawdDaDdEaGdzbIbEbna1dUdd-bsYjlg-c0-1oOBzEvYCAv&aifp=sll02152008&slist=hulu12/136/60297136;.international=false&hgt=OZU7Pvs7j27-nhteNno7wmHvpn3kXoFBfoM6sBHxCGvbIvlwnBb9ZEl7eleP3S7ZJNcFwaBXay-B7iBgkZ8zkJNyXdXOANVz7Qde_ufNhMThQvzjEnKNQhoINVRLYnPrrTWN1Amqe_GwRvPOwdTie_udHPnXeJW1AH4FxL97ej1sV9fiNhd2i975ZKfttISLyZQgK1_jtHntKwlb4_mvO3A_nL-yrL_mBSydNvQrmsKDULBZpibCMgoaR7j6AdFJ&hgt_ver=331370278 playpath=mp4:hulu12/136/60297136/agave50515486_19243873_H264_400.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1 buffer=100000000: Protocol not fo
2014-01-04 17:01:54,496 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100004572-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100004572-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
2014-01-04 17:02:00,999 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEb_bVdNbnc9cqafalabcwcHaFdkcXbOaP-bsYjlM-c0-ZoMEADq0Bzs&aifp=sll02152008&slist=hulu2/301/60292301;.international=false&hgt=OZU7Pvs7j27-nhteNno7wsG82VUYMzPhSRFtWfmsvMSapHDBjrHgS47OOyO51LIPBZnHgzu6DTCIHXglr3DhNW0ACFlQeXL6gIwaxSj82vm8YFOEeEIEKmvlRmvDWu27dgI9VvtcfRfVSAp8K5WtU0m3VkDso3YrOI0aLTlEP4IsE7kVr9tQyRVWfIHKkFEhRGwXJwfGwpuNP7lUY3vPDLYrLT7pJuyxeRZSOmgjoc52r0mwzwSsd_eTOMvGTK3x&hgt_ver=331370278 playpath=mp4:hulu2/301/60292301/agave50511963_19120575_H264_400.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1 buffer=100000000: Protocol not found
2014-01-04 17:02:25,946 ERROR [ResourceTransportRequestHandler] Error while processing resource, sending back 500 error. Message: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100005583-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
java.io.IOException: Transcoded file '/tmp/Serviio/transcoding-temp-1000000100005583-bdp2010us-ORIGINAL.stf' cannot be found, FFmpeg execution probably failed
2014-01-04 17:02:32,502 WARN [ProcessExecutor] Process ffmpeg has a return code of 1! This is a possible error. Detailed output follows.
rtmpe://cp39466.edgefcs.net/ondemand?au ... =331370278 app=ondemand?auth=daEanc3ctazbWdlc9dvcob3dVcccQc9b1a5-bsYjmf-c0-ZpKDACsZIAn&aifp=sll02152008&slist=hulu3/952/60283952;.international=false&hgt=OZU7Pvs7j27-nhteNno7wtYbvmcqw-Qq3vcOkCSI4FuKJMclLTYTTUIcLWmIZJIbp2vsBpkMe9ObJuKjERgMD9plvtWpUef3Taonn9Rv0uefzDmm05GC5NId5O48--hIt3aj-nlZMvkAK7HMme2J3_hB7J46sJ8nB_m0MisDaCyn74ti5CUl8s5g7n8G-rKj_nQuiVk6FcK0C477ll1ofwfGjWyY77cEiqN0l3zy1QaZVop3-77IcBJC4lJbfcjU&hgt_ver=331370278 playpath=mp4:hulu3/952/60283952/agave50504162_18760413_H264_400.mp4 swfUrl=http://www.hulu.com/site-player/player.swf swfVfy=1 buffer=100000000: Protocol not found
