Folder Grouping/Navigation
foggy
Post Tue Sep 13, 2011 7:56 am
Is it possible for Serviio to group folders into the first letter of their name.
For example I have in my Serviio library a folder that contains all my video files (M:\video) sorted into their own folders (M:\video\folder1\file1, M:\video\folder2\file2, etc). When I access the listing on my media player it can take a couple minutes to scroll through the list and select what I want to watch. If Serviio could sort the folders in my video folder and display them as being in a subfolder of its first letter, it would make navigating the list so much faster.
So instead of being presented with a structure similar to:
video\folder1\file1
video\folder2\file2
Serviio would present you with something similar to:
video\A\
video\B\
Video\F\Folder1\file1
video\F\Folder2\file2
I realize that I could incorporate this sort of sorting in my folder structure but I think that having an option to do this in Serviio would be a convenient thing. On my PC it is quite easy to view/navigate with everything in the one folder but unfortunately it just isn't as easy to navigate using Serviio when you have hundreds of items because you have to scroll through the full list from start to finish.
Cheers
Foggy
Post Tue Sep 13, 2011 8:52 am
Re: Folder Grouping/Navigation
the folder view is designed to follow the folder structure, by doing this we would break that. There are other views where you can achieve similar thing (Title, etc).
foggy
Post Tue Sep 13, 2011 9:18 am
Thanks for the reply. Yes, you are right it would break the folder view.
What I'm proposing is not necessarily only going to apply to the folder view, it is just what I use so what I based my post around. It could be optionally applied to all the different categories that can be set.
I have looked at the other categories as you suggested and they would all pose the same problem I am already having without a possible solution. The problem being that the list is so big that scrolling through it using my media player takes far too long as I have to go one item at a time. If the list was broken up by the first characters, it would be so much faster to scroll through to entries that are at the end off the alphabet.
I hope I am making sense in what I am saying because I doubt I am the only one that has noticed this small but rather annoying problem.
Cheers
Post Wed Sep 14, 2011 12:16 pm
foggy wrote:Thanks for the reply. Yes, you are right it would break the folder view.
Cheers
what device are you using ????
foggy
Post Thu Sep 15, 2011 12:46 am
I am using a Sony BDP-S580
Post Thu Sep 15, 2011 2:58 pm
foggy wrote:I am using a Sony BDP-S580
hmm ok dont know if the sony has this but samsung allow page up and down navigation in the menus, maybe illico or patter can answer this or you can try looking in teh SONY section as answer is more than liekly there too.
Return to Feature requests
