Connect to Linux 0.3 server from Windows client?
SiegeX
Post Fri Dec 11, 2009 9:24 pm
Now that you have separated the client and server code, would it be possible for me to run the server on my Linux box then connect to it from the Windows version of the client with a Windows laptop on the same LAN?
Post Fri Dec 11, 2009 11:43 pm
Re: Connect to Linux 0.3 server from Windows client?
It definitely will be possible, I'll have to write a bit of code and test it, but should be in the next release.
Post Tue Dec 15, 2009 10:46 pm
This will now be possible in 0.3.1.
SiegeX
Post Tue Dec 29, 2009 7:24 am
Heya zip. One thing I just realized is that if you connect to the Linux server via a Windows console and you click "ADD" to add a Shared Folder it will open up the Windows path browser and thus I cannot choose a Linux path. Not exactly sure how you can fix this, ideally it would browse the computer the console is connected to, not just localhost. But if that is way too hard then the path of least resistance is the option to manually type in a path (allowing for backslashes '\')
Post Tue Dec 29, 2009 7:14 pm
:-) true, I re-opened the issue and will be looking into it. Ta SiegeX
Post Wed Dec 30, 2009 3:19 pm
This is actually possible already, just tried it on the Windows console. Just type in '\\myserver\mysharedfolder' . Closing the issue.
fizze
Post Wed Dec 30, 2009 6:17 pm
Is it possible to type in paths like
/mnt/sdc1/path/to/files
too?
Intel SS4200 - Ubuntu Server 8.04
LG BD - 390
Post Wed Dec 30, 2009 11:24 pm
Not sure, you'll have to try when 0.3.1 is out ;-)
Return to Feature requests
