Connect to Linux 0.3 server from Windows client?
• Page 1 of 1
Now that you have separated the client and server code, would it be possible for me to run the server on my Linux box then connect to it from the Windows version of the client with a Windows laptop on the same LAN?
Re: Connect to Linux 0.3 server from Windows client?
It definitely will be possible, I'll have to write a bit of code and test it, but should be in the next release.
Petr
Help translate Serviio
This will now be possible in 0.3.1.
Petr
Heya zip. One thing I just realized is that if you connect to the Linux server via a Windows console and you click "ADD" to add a Shared Folder it will open up the Windows path browser and thus I cannot choose a Linux path. Not exactly sure how you can fix this, ideally it would browse the computer the console is connected to, not just localhost. But if that is way too hard then the path of least resistance is the option to manually type in a path (allowing for backslashes '\')
Petr
This is actually possible already, just tried it on the Windows console. Just type in '\\myserver\mysharedfolder' . Closing the issue.
Petr
Intel SS4200 - Ubuntu Server 8.04
LG BD - 390
LG BD - 390
Not sure, you'll have to try when 0.3.1 is out
Petr
• Page 1 of 1
