Must 'Force Refresh' to see new files. Pro Version 1.6
bematft
Post Sun Mar 26, 2017 6:32 am
Re: Must 'Force Refresh' to see new files. Pro Version 1.6
I was thinking buying license (I got fix IP and would like to use mediabrowser function) but I am dissapointed...
I downgraded to 1.6 but the error message is same: it is not Win32 application... (serviioconsole), not it worked before..
There is .NET 3.5 SP1
What's wrong?
Post Sun Mar 26, 2017 8:41 am
Ok - this has got confusing. Previous pots have been about my little app - forceserviiorefresh.exe - not being a valid Win32 application, which I can't really think why - it works for me when I download it including on my work laptop which is pretty locked down.Try downloading it again perhaps?
Now you are talking about ServiioConsole not being a valid app???? :?
btw: you dont need to use the ServiioConsole app - you can access it from your browser at the address http://<<IPaddress>>:23423/console where <<IPaddress>> is the IP address of the machine Serviio is installed on (you can also use http://localhost:23423/console from the same PC that Serviio is installed on).
bematft
Post Sun Mar 26, 2017 11:01 am
Thank you... Tha problem is same with serviio console and your forcerefresh app...
Yes I know the web based console...
The last try with 1.8 can't refresh forced also.
Alwayas when I logged in (web based) console - evrytime say the same message - The new added media is " a movie "... evrytime same...
MSGBen
Post Mon Apr 10, 2017 10:35 am
So we don't have any solution to it as yet?
Post Mon Apr 10, 2017 6:30 pm
MSGBen wrote:So we don't have any solution to it as yet?
Ben, this thread has covered a couple of different areas. Exactly what isn't working for you, the forceserviiorefresh.exe app, or are your newly added files not appearing? If the latter, have you changed your polling method as explained earlier?
MSGBen
Post Sat Apr 29, 2017 6:59 am
No I haven't tried. I was reading the comments and I got confused whether the method will solve the problem or not. I'll give it a try and hit you back. Newly added files are not appearing.
mariad
Post Tue May 30, 2017 12:14 pm
Go on with changing your polling methods.
MSGBen
Post Fri Jun 23, 2017 11:30 am
mariad wrote:Go on with changing your polling methods.
I did. Result was okay
Previous
Return to General discussion
Users browsing this forum: Google [Bot] and 23 guests
