Re: Must 'Force Refresh' to see new files. Pro Version 1.6
I downgraded to 1.6 but the error message is same: it is not Win32 application... (serviioconsole), not it worked before..
There is .NET 3.5 SP1
What's wrong?
MSGBen wrote:So we don't have any solution to it as yet?
atc98092 wrote:MSGBen wrote:So we don't have any solution to it as yet?
Ben, this thread has covered a couple of different areas. Exactly what isn't working for you, the forceserviiorefresh.exe app, or are your newly added files not appearing? If the latter, have you changed your polling method as explained earlier?
mariad wrote:Go on with changing your polling methods.
Users browsing this forum: Baidu [Spider] and 20 guests
