zip wrote:Serviio doesn't care about extensions (for file type scanning), so this makes no sense
I have a Sony BDP-BX57 Bluray player and was having a similar issue. I used to just re encode the files with whatever encoder I could find and they worked. Tried renaming the file extension to MP4 like another poster suggested and now my file plays fine. I agree that it shouldn't matter as the only change was the extension but it does play now.
The ffmpeg-i of a working file follows:
Memphis Beat 7
libavutil 50.15. 1 / 50.15. 1
libavcodec 52.72. 2 / 52.72. 2
libavformat 52.64. 2 / 52.64. 2
libavdevice 52. 2. 0 / 52. 2. 0
libavfilter 1.19. 0 / 1.19. 0
libswscale 0.11. 0 / 0.11. 0
BTW I did not crop this, this really is all it says at the bottom and it worked fine.
The ffmpeg-i of the non working file is:
Memphis Beat 8
Input #0, avi, from 'Memphis.Beat.S02E08.Identity.Crisis.HDTV.XviD-FQM.avi':
ISFT : transcode-1.0.4
Duration: 00:41:33.84, start: 0.000000, bitrate: 1178 kb/s
Stream #0.0: Video: mpeg4, yuv420p, 624x352 [PAR 1:1 DAR 39:22], 23.98 tbr, 23.98 tbn, 23.98 tbc
Stream #0.1: Audio: mp3, 48000 Hz, 2 channels, s16, 128 kb/s
Can't find a difference myself except the obvious extra stream info but again the first file played just fine without it!
And again all I had to do was change the file extension to MP4 to make the second file play.
Weird Huh?
