have a question about this program
cooltwou
Post Fri Jul 27, 2012 12:50 am
i like to know why this happens. Every time my computer resets this program does not work. When you put in the ip for the computer the ip for the PS3 & the ip for a Samsung Tv & you hit save & refresh it still does not work what is going on
Post Fri Jul 27, 2012 12:48 pm
Re: have a question about this program
I guess you're binding to a IP address, that changes once you restart the PC - so set up static IP addresses for both, your PC and the devices on your router
cooltwou
Post Fri Jul 27, 2012 2:13 pm
well how do you set up a set up static IP addresses & i have no problem when i reset the computer with the other program i use PS3 Media Server
Post Fri Jul 27, 2012 3:07 pm
try not binding to any IP address nd do not add any renderers into the console manually - they should appear autmatically.
cooltwou
Post Fri Jul 27, 2012 3:48 pm
well they appear but they have the wrong ip address for each one
Post Fri Jul 27, 2012 4:06 pm
Sounds like your router is giving a new ip address each time.
cooltwou
Post Fri Jul 27, 2012 6:09 pm
ok what do i do then
cooltwou
Post Sun Jul 29, 2012 12:40 am
still have no clue what to do here because this program will show back up sometimes when you restart the computer & sometimes it does not & i have no clue why i keep getting a different ip address when the computer restarts & i only have problems with this program the other program i use i have no problems with that one at & it is the PS3 Media Server
Post Sun Jul 29, 2012 1:07 am
cooltwou wrote:still have no clue what to do here because this program will show back up sometimes when you restart the computer & sometimes it does not & i have no clue why i keep getting a different ip address when the computer restarts & i only have problems with this program the other program i use i have no problems with that one at & it is the PS3 Media Server
what is the model of your router?
cooltwou
Post Sun Jul 29, 2012 12:49 pm
NetGear N600
cooltwou
Post Sun Jul 29, 2012 11:47 pm
i listed my router so what now & how & why does this program so compacted compared to the other program i use
Return to General discussion
