Stream the world
SLmanDR
Post Thu May 23, 2013 12:15 am
Stream the world
I'm looking for a solution to using this site:
http://player.streamtheworld.com/_playe ... /?sid=2059
Is this really not a stream address?
I get a X when I check stream URL in Serviio console.
I tried playing in VLC but no joy. I looked for a log in VLC but I don't know where it would be.
Used this: (http://wiki.serviio.org/doku.php?id=add_live_feeds) to study the problem.
Here's the output of CLI:
ffmpeg -i http://player.streamtheworld.com/_playe ... /?sid=2059
ffmpeg version 1.0.6 Copyright (c) 2000-2013 the FFmpeg developers
built on Apr 11 2013 18:03:32 with gcc 4.7 (SUSE Linux)
configuration: --shlibdir=/usr/lib64 --prefix=/usr --mandir=/usr/share/man --libdir=/usr/lib64 --enable-shared --disable-static --enable-debug --disable-stripping --extra-cflags='-fmessage-length=0 -O2 -Wall -D_FORTIFY_SOURCE=2 -fstack-protector -funwind-tables -fasynchronous-unwind-tables -g -fPIC -I/usr/include/gsm' --enable-gpl --enable-x11grab --enable-version3 --enable-pthreads --enable-avfilter --enable-libpulse --enable-libvpx --enable-libopus --enable-libass --enable-libmp3lame --enable-libvorbis --enable-libtheora --enable-libspeex --enable-libxvid --enable-libx264 --enable-libschroedinger --enable-libgsm --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-postproc --enable-libdc1394 --enable-librtmp --enable-libfreetype --enable-avresample --enable-libtwolame --enable-libvo-aacenc
libavutil 51. 73.101 / 51. 73.101
libavcodec 54. 59.100 / 54. 59.100
libavformat 54. 29.104 / 54. 29.104
libavdevice 54. 2.101 / 54. 2.101
libavfilter 3. 17.100 / 3. 17.100
libswscale 2. 1.101 / 2. 1.101
http://player.streamtheworld.com/_playe ... /?sid=2059: Invalid data found when processing input
Post Thu May 23, 2013 8:47 am
Re: Stream the world
It's a web page, not a stream URL. You will need a plugin.
Return to General discussion
