AVI issue with Windows 10
NellyTheWise
Post Mon Aug 31, 2015 7:23 pm
Hi. I have a new odd problem. I have both Windows 7 and 10 on my machine (dual boot). Serviio plays avi files when I use Windows 7 but will not play any avis when using Windows 10. Same files connected to same Sony KD49X8505 but different results. Am I missing something on the Windows 10 side that I need to run ?? Thanks for your help.
Post Tue Sep 01, 2015 12:53 pm
Re: AVI issue with Windows 10
I'm not sure I have any AVI files, but I'll check.
I have the Shark 007 advanced codecs installed on my server, but that should have no effect on Serviio. I only have them so I can play MKV files directly on the computer if necessary.
Post Tue Sep 01, 2015 11:03 pm
The obvious but - are you selecting the same profile in both versions? Do the files appear on the device?
NellyTheWise
Post Fri Sep 11, 2015 7:54 pm
Hi. Thanks for your replies. Yep, the problem was a profile one. I copied the profile from the Win 7 side to the Win 10 side. Problem solved. Thanks again for your help .
