Can't Add to library folders with Cyrillic
shan
Post Wed Dec 14, 2016 5:31 pm
Then i try to do it over console i get the error "An unexpected error occurred (404). Check the log."
Post Thu Dec 15, 2016 10:08 am
Re: Can't Add to library folders with Cyrillic
and did you check the log? what OS? What is the string you're adding?
shan
Post Thu Dec 15, 2016 5:02 pm
OS - WIN7 64.
I add d:\downloads\музыка
any cyrrilic folders - are error!
The previous old concole had no errors.
serviio.log:
2016-12-15 19:56:12,686 WARN [ServiioStatusService] FileNotFoundException occurred. Returning error code 404 to the REST layer. Message: 'D:\downloads\├┤├и├л├╝├м├╗' is not an existing folder or is not readable for the current user
2016-12-15 19:59:56,753 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: ru
Post Thu Dec 15, 2016 9:10 pm
Austin
Post Mon Mar 06, 2017 7:00 am
Hello, I have same issue when it comes with Korean language.
I've seen the issue on bitbucket, I just wonder if you have considered with other language while fixing this issue.
Hopefully version 1.9 will be released soon :)
Thank you!
