Can't Add to library folders with Cyrillic
• Page 1 of 1
Then i try to do it over console i get the error "An unexpected error occurred (404). Check the log."
Re: Can't Add to library folders with Cyrillic
and did you check the log? what OS? What is the string you're adding?
Petr
Help translate Serviio
OS - WIN7 64.
I add d:\downloads\музыка
any cyrrilic folders - are error!
The previous old concole had no errors.
serviio.log:
2016-12-15 19:56:12,686 WARN [ServiioStatusService] FileNotFoundException occurred. Returning error code 404 to the REST layer. Message: 'D:\downloads\├┤├и├л├╝├м├╗' is not an existing folder or is not readable for the current user
2016-12-15 19:59:56,753 INFO [BrowsingCategoriesMessages] Loaded browsing categories message bundle for locale: ru
serviio.log:
Thanks, raised a ticket: https://bitbucket.org/xnejp03/serviio/i ... characters
Petr
Hello, I have same issue when it comes with Korean language.
I've seen the issue on bitbucket, I just wonder if you have considered with other language while fixing this issue.
Hopefully version 1.9 will be released soon
Thank you!
Thank you!
• Page 1 of 1
Users browsing this forum: No registered users and 57 guests
