WD TV
David Riddell
Post Tue Aug 20, 2019 12:10 pm
WD TV
Hi, I have just purchased the pro version, I have two wdtv units and a fetch tv box.
SErviio is being picked up by my fetch tv box but not the wd tv units. my apologies if this has been covered before but I have tried everything with no luck.
any advice greatly appreciated.
Post Tue Aug 20, 2019 10:34 pm
Re: WD TV
How are the WD boxes connected to your network? If via wireless, you might check your router settings and see if any privacy modes are enabled on the wireless that blocks access to your home network. Guest WiFi setups will do that by default, and sometimes even the non-guest connection are blocked from seeing other devices on your network.
David Riddell
Post Wed Aug 21, 2019 8:00 am
Re: WD TV
atc98092 wrote:How are the WD boxes connected to your network? If via wireless, you might check your router settings and see if any privacy modes are enabled on the wireless that blocks access to your home network. Guest WiFi setups will do that by default, and sometimes even the non-guest connection are blocked from seeing other devices on your network.
I have both units hard wired to the network, I can actually see the units in my network, I can actually see them in serviio and stating they are connected.
Post Wed Aug 21, 2019 7:28 pm
Re: WD TV
Well, we probably need to see your Serviio log for anything out of the ordinary. The developer would probably need to look at it.
