WD TV
SErviio is being picked up by my fetch tv box but not the wd tv units. my apologies if this has been covered before but I have tried everything with no luck.
any advice greatly appreciated.
atc98092 wrote:How are the WD boxes connected to your network? If via wireless, you might check your router settings and see if any privacy modes are enabled on the wireless that blocks access to your home network. Guest WiFi setups will do that by default, and sometimes even the non-guest connection are blocked from seeing other devices on your network.
Users browsing this forum: Baidu [Spider] and 40 guests
