List of test media files
Post Wed Sep 01, 2010 11:52 am
In order to test profiles, transcoding and playback of files for your device, try some of these files:
FFmpeg samples repository:
http://samples.ffmpeg.org/ (link failed)--> http://samples.mplayerhq.hu/
VLC samples
http://streams.videolan.org/streams/
Other resources:
http://www.nextcomwireless.com/R5000/samples.htm
http://www.divx.com/en/electronics/solu ... s-hd/video
http://a1408.g.akamai.net/5/1408/1388/2 ... es.mov.zip
Post Fri Dec 10, 2010 10:12 am
Re: List of test media files
yule
Post Fri Dec 31, 2010 9:56 am
The Blender foundation movies Sintel and Big Buck Bunny are available in varying resolutions and formats. I quite like them for testing capabilities.
http://www.sintel.org/wp-content/content/download.html
http://www.bigbuckbunny.org/index.php/download/
Post Fri Feb 11, 2011 8:23 am
VOB with closed caption:
http://samples.ffmpeg.org/MPEG-VOB/Clos ... oopers.vob
This (Starship_Troopers.vob) is a piece of VOB file from a Region 1 DVD containing Closed Captions.
It contains English soundtracks (aid 129 is AC3-5.1), and a commentary, plus subtitles in DVD format (sid 0 is English).
Post Mon Feb 14, 2011 8:45 am
A transport stream which nicely displays pre-rendered subtitles on Viera (via Serviio):
http://streams.videolan.org/streams-vid ... +dvbsub.ts
MediaInfo
Complete name                    : H:\Serviio\video_subs_ttxt+dvbsub.ts
Format                           : MPEG-TS
File size                        : 102 MiB
Duration                         : 2mn 21s
Start time                       : UTC 2006-11-08 14:15:14
End time                         : UTC 2006-11-08 14:17:24
Overall bit rate                 : 6 019 Kbps
Network name                     : ASTRA
Original network name            : Astra Satellite Network 28,2'E
Menu ID                          : 6301 (0x189D)
Format                           : MPEG Video
Format version                   : Version 2
Format profile                   : Main@Main
Format settings, BVOP            : Yes
Format settings, Matrix          : Default
Format settings, GOP             : M=3, N=12
Codec ID                         : 2
Duration                         : 2mn 20s
Bit rate                         : 5 204 Kbps
Nominal bit rate                 : 7 980 Kbps
Maximum bit rate                 : 31.7 Mbps
Width                            : 720 pixels
Height                           : 576 pixels
Frame rate                       : 25.000 fps
Standard                         : PAL
Scan type                        : Interlaced
Scan order                       : Top Field First
Bits/(Pixel*Frame)               : 0.502
Stream size                      : 87.3 MiB (86%)
Audio #1
Format                           : MPEG Audio
Format version                   : Version 1
Format profile                   : Layer 2
Codec ID                         : 3
Duration                         : 2mn 21s
Bit rate                         : 256 Kbps
Channel(s)                       : 2 channels
Delay relative to video          : -139ms
Stream size                      : 4.31 MiB (4%)
Language                         : English
Audio #2
Format                           : MPEG Audio
Codec ID                         : 3
Duration                         : 2mn 21s
Bit rate                         : 256 Kbps
Delay relative to video          : -85ms
Language                         : nar
Text #1
ID                               : 5003 (0x138B)-100
Format                           : Teletext
Language                         : English
Text #2
ID                               : 5003 (0x138B)-888
Format                           : Teletext Subtitle
Language                         : English
Text #3
Format                           : DVB Subtitle
Codec ID                         : 6
Language                         : English
Menu
Duration                         : 2mn 21s
List                             : 2306 (0x902) () / 2308 (0x904) () / 2311 (0x907) () / 5000 (0x1388) (MPEG Video) / 5001 (0x1389) (MPEG Audio, English) / 5002 (0x138A) (MPEG Audio, nar) / 5003 (0x138B) () / 5004 (0x138C) (DVB Subtitle, English)
Language                         :  /  /  /  / English / nar /  / English
Maximum bit rate                 : 411805200
UTC 2006-11-08 14:35:00          : en:†Murder, She Wrote‡ / en:The Monte Carlo Murders: Jessica is looking forward to a rest in a Monte Carlo hotel owned by a friend. But her sojourn is interrupted when a businessman is found murdered in one of the suites. [S] /  /  / 00:45:00 / Not running
ffmpeg
C:\Serviio\lib>ffmpeg.exe -i "H:\Serviio\video_subs_ttxt+dvbsub.ts"
  configuration: --enable-static --disable-shared --disable-shared --disable-ffplay --disable-ffserver --enable-memalign-hack --enable-libmp3lame --arch=x86 --enable-runtime-cpudetect --enable-w32threads --target-os=mingw32 --cross-prefix=i686-mingw32-
  libavutil     50.36. 0 / 50.36. 0
  libavcore      0.16. 0 /  0.16. 0
  libavcodec    52.108. 0 / 52.108. 0
  libavformat   52.92. 0 / 52.92. 0
  libavdevice   52. 2. 3 / 52. 2. 3
  libavfilter    1.72. 0 /  1.72. 0
  libswscale     0.12. 0 /  0.12. 0
[mpeg2video @ 016fba20] mpeg_decode_postinit() failure
    Last message repeated 3 times
[mpegts @ 015fd910] max_analyze_duration reached
[NULL @ 016e7570] start time is not set in av_estimate_timings_from_pts
[NULL @ 016fd6f0] start time is not set in av_estimate_timings_from_pts
[NULL @ 016ff3b0] start time is not set in av_estimate_timings_from_pts
[NULL @ 017010a0] start time is not set in av_estimate_timings_from_pts
[NULL @ 01702f10] start time is not set in av_estimate_timings_from_pts
[NULL @ 01704db0] start time is not set in av_estimate_timings_from_pts
[NULL @ 01706c20] start time is not set in av_estimate_timings_from_pts
[NULL @ 01708a90] start time is not set in av_estimate_timings_from_pts
Input #0, mpegts, from 'H:\Serviio\video_subs_ttxt+dvbsub.ts':
  Duration: 00:02:21.72, start: 458.712200, bitrate: 6010 kb/s
  Program 6301 BBC 1 London
      name            : BBC 1 London
      provider_name   : BSkyB
    Stream #0.0[0x1388]: Video: mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], 7980 kb/s, 25.40 fps, 25 tbr, 90k tbn, 50 tbc
    Stream #0.1[0x1389](eng): Audio: mp2, 48000 Hz, 2 channels, s16, 256 kb/s
    Stream #0.2[0x138a](NAR): Audio: mp2, 48000 Hz, 2 channels, s16, 256 kb/s
    Stream #0.3[0x138b](eng): Subtitle: [6][0][0][0] / 0x0006
    Stream #0.4[0x902]: Data: [5][0][0][0] / 0x0005
    Stream #0.5[0x903]: Data: [5][0][0][0] / 0x0005
    Stream #0.6[0x904]: Data: [5][0][0][0] / 0x0005
    Stream #0.7[0x905]: Data: [5][0][0][0] / 0x0005
    Stream #0.8[0x907]: Data: [5][0][0][0] / 0x0005
    Stream #0.9[0x908]: Data: [5][0][0][0] / 0x0005
    Stream #0.10[0x909]: Data: [5][0][0][0] / 0x0005
    Stream #0.11[0x90a]: Data: [5][0][0][0] / 0x0005
    Stream #0.12[0x138c](eng): Subtitle: dvbsub
  Program 6318 CBeebies
  Program 6319 BBC THREE
  Program 6331 BBC 1 NI
      name            : BBC 1 NI
  Program 6363 BBC R Cymru
      name            : BBC R Cymru
  Program 6302 BBC 2 England
      name            : BBC 2 England
  Program 6304 BBC NEWS 24
      name            : BBC NEWS 24
  Program 6306 ETV
  Program 6308 BBC TES Test
      name            : BBC TES Test
  Program 6309 BBC TES 2
      name            : BBC TES 2
  Program 6315 BBC TES 3
      name            : BBC TES 3
  Program 6316 BBC FOUR
  Program 6317 CBBC Channel
Post Wed Aug 03, 2011 3:24 pm
The http://samples.ffmpeg.org seems to be done...
Use
This is the MPlayer/FFmpeg samples collection.
You can find samples of various common and uncommon
multimedia formats here. The size of the collection
currently is 53GB and growing.
You are free to download any samples you want, but
if you want to download more than just a few or want
to mirror the whole collection please send a mail to
webmaster(AT)mplayerhq(DOT)hu *before* you start
and ask for permission.
We can also ship the samples collection to you for a
reasonable fee, inquire for details.
The best way to download samples is with rsync. If you decide
to fetch a large amount (more than 1GB), please limit the rate
to no more than 50 kBps (use the --bwlimit option of rsync).
Please be aware that this samples collection contains a lot
of files that are very obscure, broken in various ways or
are just simply out of use. Hence, it doesn't make sense
to download all of them, unless you are developing a player
application that will support all and every file format
that was ever conceived.
sunnyday
Post Mon Jan 16, 2012 7:25 am
A set of 8 different sample files from the creators of the Matroska specifiation:
http://matroska.org/downloads/test_w1.html (176 MB zip archive)
Quote from included documentation:
"The files presented here represent the minimum support a player should have to fully qualify as a Matroska player."
Samsung UE46D5005XXE | Samsung BD-C6500
jlcooke
Post Thu May 31, 2012 1:52 pm
Post Mon Jun 24, 2013 3:14 pm
Some samples : http://www.divx.com/en/devices/profiles/video
-- MKV --
Mike Wiegele Heliboarding
Video Wiegeles
DivX Plus HD
1920x1080
Length: 00:03:40
Advanced Features: Smooth FF/RW, authored chapters
Download
Sintel
DivX Plus HD (MKV)
1920x1080
Length: 00:15:08
Advanced Features: multiple subtitles and tracks, smooth FF/RW, authored chapters
Download
-- DIVX (HD) --
Micayala Gatto
DivX HD 1080p
1920x1080
Length: 00:02:17
Download
Helicopter Flight
DivX Home Theater
720x576
Length: 00:01:48
Download
Elephants Dream
DivX HD
1920x1080
Length: 00:11:14
Features: multiple subtitles and audio tracks, chapter points
Download
Big Buck Bunny
DivX HD
1280x720
Length: 00:10:17
Features: multiple audio tracks, chapter points
Download
Amos TV
DivX Home Theater
720x576
Length: 00:10:02
Features: chapter points
Download
Post Tue Aug 20, 2013 12:04 pm
Post Tue Aug 20, 2013 12:15 pm
http://download.wavetlan.com/SVV/Media/ ... -index.htm
Audio format:
3GP
AAC
AMR
ASF
FLAC
MIDI
MP3
OGG
QCELP
WAV
WMA
Video format :
3GP
ASF
AVI
MOV
MP4
WMV
MKV
paniko
Post Tue Sep 17, 2013 8:50 am
is it possible to add these link like online resources on serviio?
Paniko
Sumsung EU46D6500 | XBox 360 | Samsung Galaxy S 6 Edge | Windows 10 - i7 64bit | Serviio 1.5.2 Pro
Beta Tester
Post Tue Sep 17, 2013 12:24 pm
paniko wrote:is it possible to add these link like online resources on serviio?
Ye, I already think about this...probably with a groovy plugin. But need time to test it.
ViverraXX
Post Fri Nov 29, 2013 8:25 am
zip wrote:In order to test profiles, transcoding and playback of files for your device, try some of these files:
Do you can to do multiple deletion in the resources list? I have do Import playlist with 350 channels, but it has some mistake, and I was forced to delete each in turn - not comfortable.
wiak
Post Fri Apr 03, 2015 5:14 am
Big Buck bunny (CC License) 4k@60fps with 3d videos can be found here
http://bbb3d.renderfarming.net/download.html
Torence
Post Mon Sep 11, 2017 5:48 am
Thanks for you sharing. I will add these files to my list to try.
Paul C
Post Thu Mar 01, 2018 12:57 pm
There is a list of 168 working Internet Radio stations that can be loaded into Library/Online sources. The file is at viewtopic.php?f=42&t=24378
The files as test media are generally similar but there are mp3, aac+ files of differing bit rates.
trafo
Post Mon Jul 20, 2020 2:26 am
Users browsing this forum: No registered users and 88 guests
